I'm experiencing CSS issues with IE5 with my site www.remconsulting.com.au -- essentially the padding/margins all appear correctly in IE6+, Firefox, Safari, Opera...etc but IE5 throws everyth...
this is my style css
STYLE
TYPE="text/css"><!--
#container { background-color : transparent;
width : 100.0%;
position: absolute;
I crated a transparent bar using <div class="transparentbar"></div>. My problem is with IE. I set the height to 3px, but in IE it shows much thicker.
Trying to fit the login-box element inside the round corner box, but having trouble understanding how to have the side-box stretch according to the length of the login-box. The only way to ge...
Hello:
I have a page that looks fine in FF and has huge gaps on the left hand column in IE7, please see:
http://www.precisionsurgical.com/store/manufacturers.aspx
What is causing this...
what sizes are the images in this css rounded corner example.
i want to use the css and create images to create my own rounded corner
http://www.vertexwerks.com/tests/sidebox/
This is one of those sites completed when I was learning CSS... Oh boy!
How can I align the text within the link?
h##p://quintinjohnstone.com/QJ_updated_site/faq_copy1.htm
All comments ...
Hi: Can any one please tell me how to i adjust table so that it shows all the steps of direction
http://www.southeastneurology.com/testsite/sitemap.html
Hi
I have some data in a table
its a two column 10 row table
For SEO purposes I would like to replace it with some kind of div tags and css so that I can
have the same effect without a...
Hi: Can any one please tell me how to i remove the errors from fire fox? Also it dont shows the javascript menu right in firefox
http://www.southeastneurology.com/testsite/testtable.html
I have built a header that works perfectly in IE7, but I can't seem to make it fit other browsers properly. I have played around with the code and I can't even get it to work properly in Firef...
Hi: Can any one please tell me how to i adjust the text scrolling so that it dont start from the bottom of the page
http://www.southeastneurology.com/testsite/test2.html
Thanks.
Hi: Can any one please tell me how to i handle the browser issue as when i open the site on different computers which have microsoft platform but different size of monitors the page dont shows...
Hi Experts,
I'm making use of the CSS 'sliding doors' technique for tabs on a main navigation. The main navigation is a simple unordered list. The 'tabs' are only in place on the page that ...
Hi: Can any one please tell me what i do change in the css code or in the page so that it shows colored border on both sides?
Thanks.
http://www.southeastneurology.com/testsite/indexnew....
I am trying to work on a site, converting tables to XHTML/CSS only. And I am starting with the wrap structure and then work to make the left bar, right, then the fine print in the middle. I ca...
Hi: Can any one please tell me what i do change in the program so that it will show correctly on every computer? I enclose the picture which i save it from another computer and it not show rig...
Please take a look at this file and let me know how to alter the appearance of the default scroller as described; http://www.discretedata.com/Ex-Ex/scrollTest.html
Thanks!
John
We are using absolute positioning [with a large minus left value] to hide some text for screen readers.
BUT ... when someone copies large amount of text, the hidden text also gets co...
I have an ASP.NET App, with ASP membership. The system uses master pages and telerik controls.
There is a central customer login, and a session is stored for users CompanyID, RoleID and UserI...
I have a background image that I use as a header at the top of a webpage. I want the height of the div to be equal to the height of the image. I have used a height option, but find I am gett...
Hi
i have a result from php mysql and i want to display them professionally using html css
and i want to display them like this :
company :$variable ...
Having a few issues..... If you view this site in IE7, Opera, Safari or Firefox it looks right : http://www.robertb.co.uk/eliteedge/test.php
but when I test it in older versions of I...
Can someone point me int he right direction here:
http://cms.07th.com/temp.asp
It looks right in IE, but not FF...
I am trying to place a java applet below all other content in a page how can i do this because
in Firefox the z-index wont work, it stays on the top layer.
How can this be done?
Thx!
