Top CSS Solutions: 701 - 725 of 725
Hi: Can any one please tell me what i do change in the css code or in the page so that it shows colored border on both sides? Thanks. http://www.southeastneurology.com/testsite/indexnew....
I am trying to work on a site, converting tables to XHTML/CSS only. And I am starting with the wrap structure and then work to make the left bar, right, then the fine print in the middle. I ca...
Hi: Can any one please tell me what i do change in the program so that it will show correctly on every computer? I enclose the picture which i save it from another computer and it not show rig...
Please take a look at this file and let me know how to alter the appearance of the default scroller as described; http://www.discretedata.com/Ex-Ex/scrollTest.html Thanks! John
Experts, We have a gift websites which are only focussing UK customers at the moment, my boss wants to make the US version out of it just by changing the pounds currency to dollars. Which ...
Hi, We are using absolute positioning [with a large minus left value] to hide some text for screen readers. BUT ... when someone copies large amount of text, the hidden text also gets co...
I have a background image that I use as a header at the top of a webpage.  I want the height of the div to be equal to the height of the image.  I have used a height option, but find I am gett...
Hi, Having a few issues..... If you view this site in IE7, Opera, Safari or Firefox it looks right : http://www.robertb.co.uk/eliteedge/test.php but when I test it in older versions of I...
Hi, I am really new to CSS, I did up a site in HTML and it is all over the place in different browsers, so I now have it in CSS, but i have 2 small problems. 1. You will see at the site th...
Hi i have a result from php mysql and i want to display them professionally using html css and i want to display them like this :                                   company  :$variable    ...
If you take a look at the following page in IE6, and then compare it to how it displays in IE7 or FF3, .. you'll notice right away that there's a problem with those 3 bottom boxes.  Why are th...
Can someone point me int he right direction here: http://cms.07th.com/temp.asp It looks right in IE, but not FF...
Hi, When I have a drop down on firefox, when the content of the drop down is wider than the width of the drop down, firefox adusts the size of the content so it expands to an exact fit, is th...
I would like assistance on how to code a CSS verification script like the one on the sign-up screen on Expert Exchange with the highlighted form fields, comments and checkmark icon.  If you ca...
Hi, I've in the middle of developing a new site, and I'm regularly checking to ensure the site passes w3c validation. I normally don't have any issue, with most sites passing as strict firs...
I am trying to place a java applet below all other content in a page how can i do this because in Firefox  the z-index wont work, it stays on  the top layer. How can this be done? Thx!
Hi Is it possible to create a style which gives a div variable padding (or min or maximum padding) depending on the div's width as a percentage? Thanks
Hello, Hopefully someone can assist me in fixing this problem.   1 - Doesn't look right in FF, see screen shots. 2 - the hovering opacity's doesn't work in FF either.  Below is my code, ...
Hello I am working on a site and when I test it on firefox and safari the top right navigation area all lines up fine. in IE the floated elelements are droped down to the next line rather t...
