HI - can anybody explain why this DIV is pushing down what's below it
http://91.103.220.151/index.php
Should both be the same gaps
Ta
@ http://tiny.cc/GNHEH I have added a new clickable button in the right sidebar with the name bestelformulier. It works fine in Firefox 3.5, but not in IE7 nor 8. In IE the button is not funct...
How can I get this page to work so that
- the div's are horizontal
- the left and right div's are fixed width
- the middle div fills the space between the left and right div's
- the mi...
http://artspan-join.cjehost.com/join_ie7.php
see the quotes in the right column - they work great in the lastest ff and ie8. however, ie7 doesn't support these pseudo-elements.
i found ...
Can someone give me the lowdown on Drop Down Menu best practice in words of one syllable please - I'm getting pretty confused with this.
I've been playing around with Dreamweaver and their ...
I have an photo within a float right div. It should top align with the first H1 tag text on the page, but its dropping several paragraphs down. Additionally it is somehow linked with t...
What's the best way to stack (on top of each other) 2 DIVs or SPANs so they are centered?
Example: 1 DIV contains an image/icon, and then another DIV on top contains text for the icon (hope...
I am doing some intermediate level web page development and want a really good HTML editor, one that will allow me to increase the level of sophistication of my work.
I love CoffeeCup's HTM...
Hey guys,
Am getting an annoying thing happening in both ie and ff. I have my body BG colour/image set and inside the body i have a container with id wrapper which contains the whole site. ...
Hello Experts,
Ok, so I am a novice web designer. I am really not that talented graphic wise (I wish I was so if anyone knows of some good tutorials, let me know), I am a beginner at PHP an...
Hi All,
I have pretty heavy page in terms of functionality and design. I need it in tableless format.
My designer insisted me to design layout using UL LI rather than DIVs, as they are m...
I'm trying to make a features box like the one on the CDC web site - http://cdc.gov/ (the box right below the a-z horizontal bar). The CDC uses Flash, but I only want to use JavaScript and CSS...
I have no idea why this won't work any ideas it works fine in FF3 but not in IE.
I have used the SPRY tabbed panel within my site see http://www.clickitsystems.co.uk/standards.php but I have two small wrinkles that I cant get to the bottom of.
i) The page body is withi...
<DIV ID="image1" STYLE="position:absolute; left: 100px; top: 50px; z-index: 2">
I locate a image to the left of the screen +100px... it works ok, but how can I do something like align it ...
Dear Experts,
If I have 2 <a> tags on my page. How do I change the color of both the first and second <a> tags simply by overing over the second <a>? Then when I hover off the second <a>,...
I am trying to figure out a way to remove the gap between my nav bar and my top header image. There is also a strip of white at the bottom of the page, possibly related, but I'm not sure.
A...
I am having problems with the aligment of the submenu to the main menu. It moves when screen width is adjusted, I know it has something to do with the offset created by the Javascript but...
I've got a page with a table and some rows and some cells ..
I want a uniform background and a solid underline across the whole row but no matter what I do I still have a lttle bit of white...
I need to dynamically disply a <span>something</span> immediate after a <table> or a <td> in the <table>. Problem is the <span> should overlap any other content on the page.
Any idea?
I have a web page that supports a modal pop-up div over a transparent div. It works perfectly in IE7, and fails hard in FF and Chrome. I'm looking for a way to make this cross-browser.
Th...
I am trying to get approximately this look:
http://ctasik.com/ftp/IPTC/test/look.jpg
that is what i have so far
html -
http://ctasik.com/ftp/IPTC/test/menu.html
css
http://ctasik.com/f...
I am new to CSS and I think this is a matter to learn from observation and I observed one thing today which I would like to share.
I have 5 text boxes, which belong to a class which I have...
I want to have two panels side by side, as though I did a table, with two columns, vertically aligned at the top.
Sometimes I will make the first panel invisible, so I don't want any space...
Please see attached HTML/CSS and screenshot.
You'll note that the brown image is adjusted to match the font-size by using height:1em.
But images used in background (orange wave) as well as i...
