Flex 3 - How Do I Display dynamic icons in each row of datagrid (ex. PDF, Word,Excel)
This is for a list of files that the user uploads, I need to show the proper Icon based on all of the dif...
Hi guinius,
I am new to flex3.I am trying to prepare a client server database architecture using PHP.I tried to prepare the application through wizard Click-->Data->Create application from ...
Hi Experts,
I want to create flex hover menu using reference from sites like http://www.sony.com/index.php or http://www.htc.com.
Can you please provide me something useful in the form of ...
How do I get the size of a flash movie written in Flex to automatically change its size when the web browser user changes the text size? Everything else on the page seems to resize automatica...
This one has to be fairly obvious, but I am very rusty in flex. I am trying to loop through all the reports in my this.reports ArrayCollection and export it into an excel sheet that is popped ...
How to add a java plugin 1n FLEX Builder3 and integrate flex3 with tomcat
I'm pulling my hair out on this one...
I've got a plot chart and an advanced datagrid both supplied by the same dataProvider - an arraycollection. My goal is to have the row in the adg highl...
Flex 3 - How to Create / Export Word, Excel, CSV and other formats from ArrayCollection???
Hi All,
I have implemented Number sorting as mentioned in the below(code).
I have placed the function that i am setting for the column that is to be sorted.
This column contains forma...
Is there source code for a Flex image editor that will allow the user to save their work and have it persist for editing when they come back to the site?
This site: http://www.bookemon.com...
In a Flex 3 example, I send a text via httpservice using POST. The debugger shows the server response reads and recognizes the sent text by acknowledging it in the response body. The PHP file ...
i able to send the email go through via flex 4 (backend java). but i fail to send an attachment . Please. Help.
I want to include flash swf file inside my flex application.Also I have to pass xml file as a input to this flash file from flex. Can some one explain how to do this?
I am returning a java.awt.image and want to view it in flex but get implict coercion errors.....Below id the java code used to acquire the image from DB.......
I am attempting to set the depth of certain elements.
When an image is hovered over, it increases in size, but other images might be in front of the larger image.
I want the larger image...
Hi there,
I am finding a peculiar problem with Advanceddatagrid while column grouping.
I am creating grouped columns on the fly. Every time the number of columns exceeds 30 (10 groups * ...
I'm using a custom TitleWindow component that animates the opening and closing of a TitleWindow. The code example and custom component, 'AnimatedTitleWindow', can be found on this guy'...
I am currently trying to develop a 3-state ItemRenderer for a grouped AdvancedDataGrid component that will show me a CheckBox before the group title which will have one of these three s...
I am using a striaghtforward for loop to add a set of checkboxes. tracing the numChildren shows they have been added, but (a) they don't appear visually; and (b) accessing them by name results...
Hi i have a project which was sent to be by another developer. The project has a huge images folder.
When i try to run the application the first time, it takes a long time in the build befo...
I have a ADG. when i moving from screen to screen, the columns in ADG are resizing. but i dont want to resize them automatically.
i want the column widths to be the original column widths.
I have a component mxml that defines a generic comboBox and some associated functions. I have a parent mxml that uses the component comboBox. I want to be able to clear any previous selectio...
I would like my Flex 3 DataGrid's columns to have a width that is equal to the width of the longest element in that column. For example, an "id" column may have a width of 10 while a ...
I have an item with a series of packages, with one package being set as active. I am populating the full series of packages in a radio button group through a repeater, but I do not know how to...
I have an Adobe Flex web application built. This application runs from a local website managed via Portable Firefox (all to make it accessible on a USB Flash drive). A new requirement for th...
