Time Tested Web Languages/Standards Solutions: 1 - 25 of 428
  I have an aspx form from which I would like to pop up a new window. I can do that using an ASP.Net hyperlink control with the Target value set to "_blank". How can I control the dimensions ...
Hi, I have a form, and in this form, there's a drop down menu, two buttons (labelled "add" and "remove") and finally, a listbox. The question is, when the user clicks on the add button, ...
Hi All The code below is not doing as I want it to. I took the code from another place and modified to suit my needs. When Yes is Selected I want the whole table to show, but it shows is the...
Hi I am designing a DHTML menu. When sombody selects an item in the menu I want another table to drop down under the menu. I use a javascript function for this which inserts the html table int...
Hi, I have a table where the data in a particular cell to be wrapped at 15th character. I tried the option of <td width=15 > but it won't work. I need the text to wrapped at every 15t...
Can someone point me in the right direction to find a list of swear words.  The filter-program part is easy but the list could be very very long.  All I'm looking for is a link. Thanks. Ne...
Is there a way to put a character within HTML so when someone prints the HTML form/screen I can force a page break. I want to develop a new HTML form/screen for an employee to fill out, and wh...
Hi I don't know much java script, here is some code I'm trying out function validate(){      var user = document.optionsForm.user.value;      alert(user); ->     if(isWhitespace(user)){           warnInvalid...
Hello Experts I am looking at the question and answer: http://www.experts-exchange.com/Web/Web_Languages/Q_20916437.html I created a web form (.aspx) playing around with the examples g...
Hi, I am trying to read data from a flat text file using ASP and convert it to Binary, before writing the binary to an MS SQL 2000 DB record. I know how to read flat files using ASP and als...
I'm new here....Hello. Gotten a lot of search results pointing here...Excited to join. How can you call a javascript function in asp. <% ... %> jsFunc() <% ... %> doesn't work bec...
Hi, I am having a main window and I am opening a pop-up window from this main window. From the pop-up window I need to open another pop-up as a modal window. When I open this model window a...
Hi all experts, I'd like to know how to create a hyperlink (javascript or other techniques are also welcome) so that when client clicks on the link, web browser (only IE is fine, but workin...
I am creating a webform that includes a button to delete a record.  I would like to have the user confirm the record deletion by displaying and yes/no message box.  It is possible to display a...
Hi all, I want to create a table that has a long width because I want to show as many as columns that I want. So I want to make my table width as big as I can but I don't want to see a hori...
I have users uploading files of up to 50MB or more through the website I maintain.  The problem is, many users are apparently getting frustrated without seeing feedback on the progress of thei...
HI Experts, I am creating a web page that is going to be a sideways scrolling page. the background image is about 1500px wide. This page is going to have a user login textbox at the top of ...
Hi ,   Unable to call the VBscript function location() from JScript function LocateUser() <script language="JScript">  function LocateUser(NoofUser)  {   var i;   if(document.frmM...
I previewed my html in my browser and copied and pasted it into the body of my email, but I'm having some display issues. I know there is a more technical way to do this, but I don't know how ...
What can be used in place of 10: . . GoTo 10 in VBscript? Thank you
Here is the Vbscript I am trying to run and I get this following error: Error  :"Arguments are of the wrong type, are out of acceptable range  or are in conflict with one another". Code  : 8...
Hi guys, I didn't know whether this question belonged to CSS or HTML, so I'm posting it here :) how do I make the font of the link of a page I'm currently on bigger? I have a news archi...
I am try to create a webpage that is frame based.  The 'left' frame is used to display a table of contents.  In the 'right' frame, I want to be able to show that word document without having t...
i would like to protect Copy&Paste  and Print functions in a web application. How do i disable  Ctrl+C,Ctrl+V,Ctrl+P,Ctrl+N and Alt+PrintScreen keys. i am using win2k and IE browser. Can an...
Hi, I have an ASP page that draws up a report and display it to the user. If the user wishes to do so, he can click a "print" button which activates the printer dialog via javascript. This ...
