I have a static IP and 2 different names: www.mysite1.com www.mysite2.com.
Is it possible to host them on one IP ?.
Hi
How would I go about making the values in my third field in an access table "1" if the first value is greater than the second, or "0" if the reverse is true. All fields are numbers.
Th...
I have virtual hosts set up on my machine and all is working fine.
I want more than one virtual host to point to 1 URL
root@tropical:/etc/apache2/sites-enabled# ls
000-default
pc...
I have websphere running on a windows 2003 server with four different web applications running. When I change settings in the web.xml file for an application, stop the application, then start...
Hello, I have got a Web Server due to go in at my home in the UK (Burgess Hill Area) from co-location. I have all the equipment as well as 48 Hour UPS Back up, firewalls e.t.c But I am now try...
How can I run the regsvr32 /u fusion.dll without raising this exception...
We have a website hosted by another hosting company. If I type in their public IP from a computer on our internal network I can access the website just fine. This is not my problem.
We are...
I'm having an issue with my dedicated server suddenly. It worked yesterday and nobody touched.
Please see it here :
www.thesportsanalysts.com
Any idea what happened?
I've...
My client is running Apache 2.2.6 on RHEL 5 on i686 arch. I've been tasked with doing a redirect to an external URL if a user connects to our site using a WAP device (or a third site if they'r...
I'm new to Plesk. I want to back up my server and the instructions are
Log in as root to your server.
Change to the directory, where Plesk is installed:
cd /plesk_installation_directory/...
I am building a web server to serve external facing web apps. a couple of these web apps use windows authentication to control who access the sites. these site are used by our domain users, bo...
I am getting the error while trying to deploy in weblogic..
Failed to parse application descriptors: java.util.zip.ZipException: No such file or directory
weblogic.management.Application...
Our small business currently uses a business DSL connection for internet. We have one public IP.address. Currently we have a server running Exchange 2003 and it is the host for Outlook Web A...
I am having problems servering up any .aspx page. So I tried some testing by creating a very simple "hello" .html, then .asp and both of these come up. But when I change the extens...
Hi expers!
I have more than 200 sites and I am trying to look for a palce to host it ..Which one will you recommend and why? Cluester Hosting or Dedicated Server?
Each of my sites have a ...
Hi all,
My software says for my server:
Please check that the server has: magic quotes OFF and PHP allows set_time_limit() function or to be configured in php.ini.
Hi, i created a new website using VWD 2005.
I can run it in the browser if i type http://localhost:2522/WebSite1/Default.aspx .
but how do i configure my pc so others can run it.
Tha...
When using IIS I am getting this error message when I try to access a web page on this server using IE.
Whats wrong?
Thanks, Don
I want to rewrite the URL for a certain subfolder in my website called search with two parameters, could you help with the syntax?
I'm trying to take ...
mysite.com/search/new/3/
and r...
I have a virtual private server and have had th servic suspended a a result of "illegal activity" that I know nothing of. The report to me from the service provider included the report below.
I have installed IIS on my local machine (running XP Professional x64).
When I just try to view the iisstart.htm page in my browser, it is coming up with the following message:
Under Con...
I'm having trouble setting variables to this XML response I'm receiving from a web service. The xml is below.
I have this so far:
<cfscript>
XMLContent = trim(objGet.FileContent);
I want to know if there is software that can monitor network problems
Situation #1
Recently my web server had an issue where we were not receiving any e-mail.but we could send so this is w...
One of our employees want to use MS Frontpage to develop web-pages. We have installed an Ubuntu Server version 8 with Apache 2 web-server. How do I set up my Apache-server so that this employe...
I rebooted our exchange server and after it restarted the OWA site is down. In the exhange server are blackberry BES, our owa hosting server (virtually) . I am not familiar with Exchange She...
