Hello Experts,
I've run into this problem before, but was able to solve it with steps I found here, but this time it is not working.
The problem is from a new website that was created. ...
I'm have developed a form using classic asp. After form is submitted it runs an asp script that opens, writes to, and saves data to the same .csv file. Then it runs another script tha...
I am new to Cold Fusion and have been asked to install Cold Fusion vesrion 7.02 application on Unix? Does any one know what version of Unix ( Solaris)? is needed to run Cold Fusion versionn 7....
I'm going to be speccing up a web server up for a website i'll be developing. The website will expect around 20k hits per day, possibly rising and will be very database driven.
what ...
I have the following code in my .htacess file to prevent hotlinking. However, I now need to allow linking from OTHERDOMAIN.com. I suspect it is a second rule?
RewriteEngine on
RewriteCo...
An engineer I work with recommended we use GZIP for our web pages.
A service tech at our web hosting company said we could set our server to use GZIP but that doing so will probably overl...
Hello experts
I have very limited point. so i cant assign to much points.
i need some tutorial for name server configuration.
thanks in advance
I have installed Exchange 2007 SP 1 on Windows 2008 Server. Everything is going well, except SPAM. I did NOT install Edge Transport YET (on second server).
I have read articles and learne...
Hi, i want to understand 1 thing about some syntax of apache webserver
<Directory "/var/www/html">
AllowOverRide All
Order allow,deny
Allow From all
</Directory
And
<VirtualH...
HI
We are a standard cat5 networked business with servers running 2003 , separate firewall etc etc.
We are thinking about hosting our own web site for www access - never having done th...
I've set up an html web page from xp a long time ago, and am just not remembering all the steps I went through. I've created my page and have turned on IIS 7 and can see the page from:
http:/...
Hi, for security reasons i need to check a log file in IIS, i need to see if someone changed a page that resides in the inetpub. Is there a way to achieve this?
Hi gurus,
I have the following questions about Virtualhost settings.
Here 's my case:
https://secured.mysite.com (with SSL)
http/www.mysite.com (without SSL)
There are two paths ...
I'm playing with a test site, and I can't figure out why the FAVICON won't display. The coding is in, the favicon.ico is uploaded, and yet it refuses to display.
www.aOasisDesign.com
Hi gurus,
Here I got a problem to solve. There are two domains on my web server (e.g. domain S and domain W). Domain S will use the JSPs on application server.
Let's assumed I have a ne...
I am able to see our internally hosted website by entering its IP address into the address field in any browser. I am unable to see this site by entering the FQDN or URL, however the site can ...
I'm attempting to make a website that is available to the general public. I'm testing on IIS 5.1 on my local machine, but it will end up being posted to IIS 6.0 on a windows 2003 ...
