Time Tested Web Servers Solutions: 1 - 25 of 608
I am getting DCOM errors every 5 minutes with the following error message:It appears the error is in IIS, that's why I posted here. If it is not, let me know and I'll post in OS section. Er...
This is the message I am getting. You are not authorized to view this page You might not have permission to view this directory or page using the credentials you supplied. I have a ...
Does anyone know how to create and install a self-signed secure transaction certificate for IIS6? I'm running Windows XP Professional and need it in order to add realism the situation of a ...
Hi, I have a XAMPP-system, and now there is a need to change the port from 80 to something else. Tried Port and Listen, but the links break. I have phpBB, Moodle, MediaWiki running under X...
How can I check if a string contains symbols or weird characters like !@#$%^%^&&*(())-+=?><,.'"}{[]| etc?
am using Windos XP on local machine cdomessage.send does not function and gives error CDO.Message.1 error '80040220' The "SendUsing" configuration value is invalid. /aaa/bbb.asp,...
when Jboss starts it give shows following info - INFO  [AprLifecycleListener] The Apache Tomcat Native library which allows optimal performance in production environments was not found on th...
I am NewBie to asp.net and creating a webserver database. I am using MS Visual web developer and SQl express. I have manage to configure the ASP.net on server to work, meaning if you access th...
Google.com runs GWS/2.1 as their Web server (at least that's how their server reports) under Linux.  I've never heard of this Web server software before and I'd like to find out more informati...
How can i configure Apache 2.x.x with Single Sign On through NTLM authentication so that Windows users can use their Domain Controller - Active Directory Credentials to logged into intranet we...
Hi, there! I am using Tomcat as webserver, and I am using spring MVC and hibernate build web applications. My IDE is Eclipse. Does someone could point me to how to make my controller called...
Is there a way to find the MIME types for all the below mentioned application:      Word Document (.docx) - Default format        Word Macro-enabled Document (.docm)        Word Template (....
i would like to play wmv file on my web page How setup streaming video ? example : mms://file.wmv thank you so much
I have tried many methods before, but I'm looking for a great method to forward my Hotmail emails to my Gmail account. I want to be able to do this all online, so I don't have to rely on an...
How do I change IIS from 32 bit mode to 64bit mode?  The metabase editor seems to be only be built for IIS 4... I am running Exchange 2007 on 64 bit hardware.
I currently have one domain pointing to my web server's IP address. My friend owns a restaurant an i told him i would host his site for him.. So How do I set this up so I can host two web site...
Hi All, We're currently attempting to launch a new website but have stumbled across quite a huge block. When we try and access the new website from another LAN pc or from the WAN, we get...
I am running a website on a Windows 2003 SP1 machine with IIS 6.0.  Anyone from within our network, or outside who uses http://site_name.org can access the site with no problem.  However, if a...
I'm a PHP developer switch over to JAVA. In php, I can do url rewrite with apache, and I want to do the same thing for tomcat. I did some digging with google, and seems like some people use mo...
Hello, I have Tomcat 4.1.30 and I was asked to increase the memory.  I read somewhere that to do that just add a parameter to CATALINA_OPTS.  I run Tomcat as a Windows 2003 Service (yes, it...
I want to open free ftp server for small grp of people. CAn u tell me some good free ftp server, that's easy to config and use. Regards
When I try to send email by PHP function mail(). The server return this error message: Warning: mail() [function.mail]: SMTP server response: 550 Account is not local, relaying disallowed. M...
Hi There, I have installed my web application in a server using IIS. When I try to browse the web application in IIS, I get the following error message: "System.Net.WebException: The re...
On my Apache2.2 error logs for one of my virtual hosts, I am receiving all sorts of "File does not exist" for things like "/blog" which doesn't exist - nor do I want it. What is causing all th...
blue/purple screen when accessing www.rr.com  (not the security issue covered by link on that page) Cable modem to Linksys WRT54GS router to Dell Dimension 4400 with up to date XP Go to www....
