I'm thinking of setting up a couple of webservers for my companie's sites in our office. We currently have commercial cable modem service and several routable IPs.
I am a bit confused about...
Installed ver 1.8 of easy php and received the error when starting it. How do I see what is using the web port. As far as I know I don't have anything other webservers active on my laptop. ...
I am developing a web site with ASP Pages. My PC is running Windows XP Pro.
To be able to test my work, I have installed IIS, so my PC is acting as a Server and client.
I want to us...
On my Apache2.2 error logs for one of my virtual hosts, I am receiving all sorts of "File does not exist" for things like "/blog" which doesn't exist - nor do I want it. What is causing all th...
I have a webservice running on our web server. We have a win forms app that consumes the web service which runs internally on the local network. I am trying to capture the IP address of...
Hi Expert,
I have apache 2 on Windows and I need to change the system's time ZONE.
Please advice !
Thanks !
Hi all..
I have a few cPanel accounts.. all with SSH access..
I wanted to backup, something, and make it upload to another account on the server..
Now I want to restore that backup......
MS Office users receive a File Sharing Violation when trying to save the file they are currently working on. The issue happens in both Word and Excel programs. Problem is sporadic. They open a...
Not sure where to ask this, I have a Redhat linux box running apache webserver. I have a large video file (1 hour mpeg2) it is about 650mb. The file is on the linux box. I am trying to use wi...
Environment: Office: running Windows Server 2003 (server and 6 workstations). My workstation is running XP. On my PC I have a software called VirtualBoss loaded locally. One of its features...
I was wondering if it is possible to set-up some type of anonymous proxy that would work like the following:
Instead of a perl script it would be something that runs on my linux server and to...
Can a DNS record resolve to a port number along with an IP Address?
Our web site admin put a hyperlink on our public web site that exposes a departmental web application server's IP Address...
I am difficulty accessing some of our web sites within IIS6.0
Currently we have a couple configured like
Website A 192.168.1.90
WebSite B 192.168.1.91
WebSIte C 192.168.1.95
On Webs...
hi,
we switched to a new server with a new ip address - and we dont need the old one anymore..
how do we transfer our SSL certificate to the new server
old server is win2k with IIS5 -...
I've come very close to making Apache 1.3.37 on Linux case-insensitive with the following RewriteRule's in an .htaccess file in my document root. However, the rules apparently get stuck in a l...
I have a .net application that makes a SOAP call the causes the website to timeout sometimes. I am not the familiar with SOAP but is there a way to debug the call once it is made? or is there ...
I am hosting my own website at work and I need to hide url details from the general public. So someone navigates to http://online.kindertons.co.uk this then displays default.asp. Is the...
Hello -
I'd like some best practices for hardening/securing an installation of Apache Tomcat 5.0.27.
Also, I need to know how to remove the default "If you're seeing this page via a web ...
What is the best way to accurately determine the hardware requirements I need to meet for a new web server? I know the amount of anticipated unique visitors per day and daily visits, etc. Is...
Apache/2.0.55
Tomcat 5.5
different machines, Linux OS.
When configuring Apache 2.0 as a reverse proxy server for Tomcat, we are able to redirect correctly. However, the session informati...
I have a Web-App using Struts on Tomcat. When I configure my welcome-file-list as follows:
<welcome-file-list>
<welcome-file>index.html</welcome-file>
</welcome-file...
Is it possible to setup HTTPS on a w2k3 server running IIS and not have a certificate installed? I am doing this on OWA but whenever I change it to HTTPS it says page can not be found. Right...
I having some problems setting up a an internal website. There must a network setting to indicate the parent directory. I am getting an error on my include files that reference the parent di...
What's the most accurate IP geolocalization service on the web?
See for example this: http://www.ipligence.com/geolocation/?lang=en
On our server, we have a JVM that runs 3 applications. Some of the threads are hung. Is there anyway to trace the below thread error to the application that is causing it?
[1/13/06...
