Time Tested Web Servers Solutions: 601 - 625 of 739
We are running a special application on a windows server that requires iPlanet to host.  We are trying to move the logs from this server automatically to another server but the only way to do ...
Hi I have installed 1. 2003 server 2. VS6 3. VS.NET VS.NET is work properly but InterDev (VS6) Can't create New project In the last stage of wizard I get error message "...
Hi Can anybody help me in giving step by step guidelines for installing .NET in windows 2003 server ? what permission do i have to set to run .net/asp.net files ? What grps n users etc ? ...
Have Resin downloaded to c:/resin-pro-3.0.14  At the Command prompt I installed it as a service C:\resin-pro-3.0.14> http.exe -install Resin Wed Service Start... I go to the browser a...
I have server 2003 IIS6 and I'm trying to isolate users in FTP.  I have followed the microsoft tutorials, but I can't get it to work.  I'm just trying to use the non-AD user isolation.  Can so...
This might be a little off the beaten path.  I transferred my DNS address from one hosting site to another.  After having my domain name on another hosting site for about  6 months the old hos...
Where does IIS 6 store the config files for the websites that you create in it?  I am looking to do a mass edit of a root directory path across several websites.  I would like to edit the file...
Hi, Wonder if someone can help. I've got a site, say mydomain.com and I'd like to setup various 301 redirects all in the same .htaccess file: 1. canonical form to www form - so - http://...
I am getting ready to purchase SSL certificate for a web server. We want to be able to access the website by type in either url: www.mywebsite.com or mywebsite.com I was told that I have to...
I want to share authentication between two iis web sites.  The websites are on the same domain but on separate sites on IIS 6.   https://Reports.website.com https://Portal.website.com T...
I have created a Servlet and use HTTPSession getAttribute and setAttribute method. HttpSession session = request.getSession(true); ChgSIBean SI = (ChgSIBean) session.getAttribute("ChgSIBea...
Hi gurus, Here I got a problem to solve. There are two domains on my web server (e.g. domain S and domain W). Domain S will use the JSPs on application server. Let's assumed I have a ne...
Hi gurus, I have the following questions about Virtualhost settings. Here 's my case: https://secured.mysite.com   (with SSL) http/www.mysite.com  (without SSL) There are two paths ...
I'm playing with a test site, and I can't figure out why the FAVICON won't display.  The coding is in, the favicon.ico is uploaded, and yet it refuses to display. www.aOasisDesign.com
I have installed Exchange 2007 SP 1 on Windows 2008 Server.  Everything is going well, except SPAM.  I did NOT install Edge Transport YET (on second server). I have read articles and learne...
Hello experts I have very limited point. so i cant assign to much points. i need some tutorial for name server configuration. thanks in advance
An engineer I work with recommended we use GZIP for our web pages.   A service tech at our web hosting company said we could set our server to use GZIP but that doing so will probably overl...
I have the following code in my .htacess file to prevent hotlinking. However, I now need to allow linking from OTHERDOMAIN.com. I suspect it is a second rule? RewriteEngine    on RewriteCo...
Hi, I'm going to be speccing up a web server up for a website i'll be developing. The website will expect around 20k hits per day, possibly rising and will be very database driven. what ...
I'm looking for Linux cPanel offshore hosting, possibly in one of the following locations: Gambling friendly, tax free. Zone eg Malta, Cyprus, Panama, Antigua or similar. Does anybody ha...
I am hosting 300 sites using WebHostManager (WHM) and Cpanel on a single Serverbeach server. Each of these sites has it's invidual statistics analysis package available to view the number of v...
Hi, I am having a problem with my Windows 2003 IIS 6 web box.  My local smtp is not sending out the e-mails.  However, when I change the application pool to the default one using network se...
Hi, I have an assistant that I want to share my office calendar, client contacts, some MS Word documents with, and task lists (to do items, etc.) so we can both know what we're doing in the of...
If I have a website that needs to be hosted on our network, but PORT 80 is already opened & being forwarded to our exhange server for webmail. How do I host the site with PORT 8 taken up alrea...
I have a domain name say (.com) which expired, but the company did not let me know. However, the domain is now showing:    Lock Status: pendingDelete   with the same people i registered with. ...
