I am in the process of installing xampp on windows 2000 pro and was wondering about ssl...Ive read in a book somewhere that setting up a self signed certificate was not good....Can i get away ...
I want to create a video server that does live video streaming. Kind of like setting up a video camera and streaming video to the web in real time.
Any suggestions for the server, the came...
I want to configure Apache httpd 2.2 to have one Tomcat webapp use SSL. The current setup passes everything to Tomcat, via SSL. I would like to have SSL only for one webapp or subdirectory, li...
blue/purple screen when accessing www.rr.com (not the security issue covered by link on that page)
Cable modem to Linksys WRT54GS router to Dell Dimension 4400 with up to date XP
Go to www....
hi ,
am trying to create consume web service(s) using Axis2 Eclipse plugin (namely Codegen WSDL2JAVA) and Eclipse 3.2.
When ever i create a web service, deploy a web service using Axis2(...
I have around 13,000 image files on a UNIX web server of which, around 1,000 have to be renamed. All files with *nd.* must be renamed to *tn.*. Any ideas how I can do this? I don't have access...
When i try to connect to FSRM i have the following error:
Unable to connect to the file server resource manager service on computer \\grkfs1. The file Server Resource manager service is not...
Hi experts, i just started deal with debian eth server , connecting it with putty and have some questions about it ;
1) How can i create FTP User ?
2) Found some 3hd party tools to man...
i have 2 web server running on my windows 2003 server
1) apache- 66.98.188.23 port 80
2) IIS-66.98.188.237 port 7000
when i type : http://66.98.188.237 it should go to IIS
this wor...
When I run IIS Admin on the server, when I right-click on the Default Website and choose Properties, a box pops up which says:
ASP.NET Management Extension
MMC has detected an error in a s...
Experts,
Im interested in installing AWSTATS for my windows 2003 server. I downloaded and ran the latest supported .exe file, during setup it asked for the location of my apache server.... ...
Hi I am trying to implement a website security system. It works on the bases of cookies beeing set by login.php
i.e login.php will setcoookie(...) and send the user to the homepage. Every p...
I can manually open cmd.exe and type the below command and it shuts down Windows 2003 Server ok.
shutdown /s /f /t 00
I've created a shutdown.bat file using notepad and typed those same co...
IIS 6.0 metabase export / import with IISCNFG.vbs
I used the examples on MSDN to export the metabase without any issue. I then copied the .xml file to another server on another network as a...
I'm running Windows 2003 IIS 6.0 ASP.NET applications. We're trying to enable the REMOTE_USER header while still allowing anonymous access. I know that Microsoft doesn't popoulate the ...
Running CentOS 5, Apache 2.2.3, PHP 5.1.6, and Webmin 1.370....
I downloaded and installed: ZendOptimizer-3.3.0a-linux-glibc21-i386.tar.gz
Purpose of this server is to run Kayako Support...
I'm using hosting service of a hosting provider. And i want to connect to mysql db from my pc. But i don't know how to know hostname and mysql port.
My Hosting Cpanel is DirectAdmin.
To...
I'm working with .net 1.1, c#, and IIS 6.0. If you go into IIS and look at the properties of a virtual directory, on the virtual directory tab theres a configuration button. Click that and t...
We have a windows 2003 webserver and using the Iusr_machinename users is not working, we get an access denied or 401 you are not authorized to used this. I haved checked the NTFS security on ...
How do you find the POP server name for an email server.
I am able to retrieve the SMTP names from www.eyeonsecurity.org tools.
I am looking for the POP server names for an email server.
I have a website setup on a SBS 2003 machine. The website was put together in Frontpage. I am a novice at this.
Here is what I would like to do:
1. Create a Folder called clients on the se...
Hello Experts,
I have a Web Portal (www.myportal.com) and i also have a video aplication (videoapp.myportal.com).
When anyone type www.myportal.com.br/video i need to redirect the reques...
We have domain name abccompany.com which we use for our email so it contains our mx records which points to Message Labs then to us. We also have domain www.xyzcompany.com which is our web se...
I have two computers, a Windows XP laptop with a verizon wireless card and a web server. I am trying to configure the laptop to run internet connection sharing and forward all requests from th...
I would like to configure mail() to send automated email to a user who registers with my site. I am currently developing the system with PHP and IIS on widnows vista and am using Com...
