How exactly does a site like seologs take the input of a single IP, then tell me exactly how many other websites are being hosted on that IP.
For example input a shared IP into this page. A...
When I try to login into Mercury Quality center it was hanging and it was not allowing me to proceed further. I can able to login into another's profile but not in my profile.
I tried by re...
trouble setting up website in iis7
I am trying to setup a website in iis. I feel like I have done everything correctly, but when I type in the header name www.mywebsite.com, IE cannot find ...
Hi all,
We've got a Windows 2003 Server running Plesk 7.6
Everything works fine until you decide to look at the stats for the website.
The stats open up fine, but when you want to loo...
I have a web service, implementied using JBboss, which I am calling from a Windows Forms application, created using Visual Studio 2005. I am able to call the web services successfully, except ...
I have installed RAD 6 on my machine and that works fine.But when I start the Was server (from the IDE)
it fails with the message
"The java class is not found: "
Thanks for your time
I have a server configured with Apache 2.0.something, Tomcat, and mod_jk2.
Apache is configured to require SSL client certificates.
Almost everything seems to be working, but I wa...
I have a dedicated server. I am using plesk 8.3.0 I am very new to this. Now my need is to create an ftp account for myself so I can upload the files after I finish working on them on my local...
reetings All,
I am having a issue with a production web server. (Windows2000 IIS5)
It has been running fine for over a year. The server now stops working several times a day
I have put th...
I'm trying to set my IIS up to only accept secure connections.
o I created a crt file on my Linux box using openssl.
o I started MMC and the Certificates snap in and imported this ce...
I am using windows 2003 server with IIS 6.0 and virtual directories using UNC paths to applications. In IIS I am using an AD account to map to the UNC share. I also use the same account for th...
I want to add 5 new IP addresses to my server, with a specified gateway and netmask, but cPanel only provides the option for the netmask. How can I provide the gateway?
Jay
P.S. I...
how to set up cron jobs in a website running on windows server. or is there any thing else that will work like the corn job opertion in a windows server
some one please help
Hey all, here's what i'm trying to do. I have IIS 5 and now i'm trying to move to IIS 6.0. I have a whole bunch of websites in IIS 5.0 and i got metaedit, and exported the websites to a txt fi...
What is weblogic? What does it do?
Hi all,
We host email internally on an Microsoft Exchange Server. We also have a web server (at an external hosting company) that uses its own SMTP engine to send emails to website visito...
Recently installed a godaddy ssl certificate. It's working fine in FF and IE, but in Safari we get the error "Safari can't verify the identity of the website ... ". After clicking continue and...
I have an ASP.NET application taht looks into a database and displays some information on an aspx page.
It works well on a windows 2000 server and IIS 5.0. how ever i recently tried to port i...
I want to implement Tomcat5.5 server with SSL access in my office for an application developed by our office. Server will be accessed from internet by our clients. Currently we teste...
On a Windows XP SP2 sony vaio laptop witih DSL modem and linksys WRT54G router, we connect to the internet fine for all websites, except:
We can't can't connect to:
www.lulu.com
with ping...
Hi..
I have Windows 2003 STD Server and I have IIS 6.0
the problem is that I already have a internal website called: www.intrafrisa.com using port 80.
and one of my users request me a...
At the moment we have a problem on our web server. Following message is logged in System log file as info and source is W3SVC.
"A worker process with process id of '3312' serving ap...
I was having a problem on my computer and had to uninstall and re-install iis. Now I am trying to re-register asp.net using
aspnet_regiis.exe -i
but the computer just gives me the e...
When I start Apache2
as
$ httpd2 -d /usr/local/ensembl
(98)Address already in use: make_sock: could not bind to address [::]:80
(98)Address already in use: make_sock: could not bin...
Hi guys, MAJOR problem! Our web server won't server ASP pages! We're running Windows Server 2K3 Web Edition fully patched w/ IIS 6.0.
Basically, when a user accesses an ASP web page, the p...
