We are in the process of setting a Company intranet up this is what we have done so far
Server 1
Windows 2003 SP1
The server contains two physical disks
C:\ OS, IIS and Virtual ...
We are running Apache 2.2.3 with proxy and caching on Windows Server 2003. It is proxying to an external site. When the external site is access directly we do not get 503 HTTP Response Codes...
What does the error "The directory '/Yield/App_Code/' is not allowed because the application is precompiled." mean when I move a web application to another server and try to access the server?
When I run the attached code snippet from the command line (php mysqltest.php) the code works and a connection to the remote DB is successful. When I run this same code snippet via apache I g...
Hi All,
I have 2 apache servers that are load balanced. I need to share the sessions between them as a short term solution to writing a php handler. I want to share them via NFS whilst I ...
I have a new small web development company. I am a web developer and I have a very good experience in building websites.
I want to make a proposal for building an intranet system for a compan...
I am installing a web server built on IIS on Server 2003. I have recently installed the OS, and installed all the updates. My problem is that I cannot see the .net 2.0 configuration ...
This is my situation: I have a home network with a router and serveral computers all sharing in internet connection. One of the computers is a laptop with Windows XP Pro and IIS installed. I w...
Hi, I have configured a apache Tomcat server on my linux box. Can some one tell me how I can check to see how much memory has been allocated to Tomcat and how I can increase the memory size? T...
I have IIS 5.1 on xp
I try to goto ip and get message
under construction
How do i make a default page?
Hello guys,
I have just rebooted after a format of my Vista Pro PC.
I'm trying to launch my first test site on the IIS 7 server of Vista but I'm getting the following error:
I am trying to Enable/Disable Internet Explorer Browser Menus, e.g. "Save as.." "Open" "Closing" and so on. Actually these functions are all disabled because there is a policy on users propert...
I've googled and contacted every moodle dev tech that I could and I still have no answer to my problem...
Here is my error in moodle:
unicode must be installed and enabled
It is requ...
The title pretty much says it. I've read every single piece of documentation about this and no matter what I do, all my records are either dropped or corrupted. When I run each individual log ...
What is a Web Server that I can run on my machine. It meets all the minimum requrements (It is fairly new) but I can't find any web server software that runs under Windows XP home. IIS, for ex...
Hello Experts,
We have upgraded our web servers and gone from IIS4 to IIS5. We are now running windows 2000 server and all the components that go along with it. We were and are still usin...
Ok i have a strange problem.
I have a proxy pac file running on my network.. its a very basic pac file that basicaly says
If there is a blank host name or a host name with our domain n...
Hello Experts,
How can configure or code so that my site when access by any web user he gets prompt to add it in the trusted site?
Anybody know this configuration on IIS so that web user g...
We maintain a production and development web site. We store users W2 forms. To open the forms on the web site, we use a .pdf template that gets filled in with the pertinent data for the user...
Experts-
How does one stop a specific IIS website by name (not IIS altogether) via the command line? ( I don't need iisreset /stop and /start ). I have a website named "foo.com" that needs ...
Can I block user from accessing website based on his ip address?
I am using apache 2.0 and I want to do this real time ie
read from a growing list of ip's to be banned by apache.
I have a requirement to use auth ldap authentication within IIS 6, on W2k3 SP1.
Currently we have this authentication running on Apache using the modauthldap module, and would like to know ...
When I start Tomcat5.0.25, I got an error message:
SEVERE: Error reading tld listeners java.io.EOFException
at java.io.ObjectInputStream$PeekInputStream.readFul...
Hello
I have set up Apache 2.2 on my Win XP PC. It is running ok.
I am running some web authoring software that when testing pages uses this sort of format for the URL for the pages.
Hi, I'm writing a program to get the html of a jsp page that uses a sessionid. I'm hoping to post to this page and get the resluts back in html. I establish a connection to the page with this:...
