HI,
I am running an application in my webserver. I restarted my OS (SUSE Enterprise linux 10.1) and then when I tried to run apache2 I get this error.
bioch2022:/usr/local/ensembl # httpd...
I have a site hosted on a windows server. It uses plesk.
Is it possible to upload a zip file then unzip on the server.
I am fairly sure I cant do it with plesk.
Is there any other way??
What port do I need to set on my firewall to enable the SBS remote web workplace 'To connect to a computer' functionality?
I've already pointed HTTPS to the server and can get OWA etc but ca...
Hi Experts,
I'm using IIS6 on server 2003 and getting four errors in my system log, As soon as they come everyone connected to the server disconnects and they have to login again.
First ...
I configure Apache 2.2 to validate users in OPenLDAP but I allways getting the following error:
[Thu Aug 02 16:29:43 2007] [notice] Digest: generating secret for digest authentication ...
We have configured SSL on TOMCAT 5.0. The application works perfectly except for file downloads. A hyperlink to any PDF or any other file type does not display the file in the browser. It give...
I would like to use Apache's VirtualHost directive to respond to any hostname passed, with the exception of one. For example:
files.foobar.com => static files.
*.foobar.com => straight to ...
I have a website running on IIS 6.0 that is tied to a SQL database that holds the content. They both reside on my local network. I would like to have the website mirrored too and hosted on the...
I have an Apache reverse proxy in front of my OWA server, and that is working. Currently, the OWA authenticates the end user with the standard pop-up box.
I would like to add another laye...
Hi, we are behind a firewall and we are hosting our website on IIS server. When ever the users types in www.company.com inside the LAN we cannot access our website . But this works fine for us...
I am using the following script which I got off the internet to send a confirmation e-mail to clients after they have filled in my form. The problem is that though the script report no errors...
Im trying to run an ASP ping script on IIS 5.0 However I keep on getting this error message when I try to execute ping.exe from the ASP:
WshShell.Exec error '80070005'
Access is denied.
/t...
How do I resolve this eror?
Need to install a Wildcard Certificate for a company in their Windows Server 2003 Standard Edition box.
I purchased the *.companyname.com wildcard certificate today. Previous to today we h...
I have a dedicated server. I use cPanel / Web Host Manager to administer it. cPanel is sending me scores of notices headed "Massive Amount of Failures from IP". The body of the message states ...
when you compare and contrast the boot process of a computer to that of a cisco router. what types of memory is on the router, and how can the back-up configurations be saved.
I have a block of 8 static IP addresses from Qwest. They gave me something that looks like this.
111.111.111.111 Reserved Network
111.111.111.112 User-assignable
111.111.111.113 User-ass...
We are running an web-based application on Linux ES 4.0 with Tomcat 4.1 which is accessed by more than 100 users simultaneously from different geographical locations over the internet.
Duri...
Hello.
I have made a portal using ASP.NET 2.
I have a login page, the user name must be in the active directory to login.
When the user is successfully authenticate on the LDAP, a pag...
We are facing a problem with session cookies in our website - www.tmn.pt. The problem is that after we login, if we type the url www.tmn.pt again in the address bar, the session is lost...
Hello. I develop a project with JDeveloper 9i and i wanna deply with tomcat. I got :
When i tried to see it with tomcat.
type Exception report
message
descri...
I have a server that I use to host about 50 or so domains. I use plesk 8.3 (windows) to manage the server and about half of the domains use Dotnetnuke (4.8) for their sites (plesk for email)....
I am using a php web program that requires that all char sets for the file system, mysql, php, and ampache match so that it can provide valid xml. I noticed I can change everything but windo...
I have just moved some web applications from my older Plesk/RedHat to a new Plesk/CentOS server and I'm having some file access problems.
Problem Definition:
1) PHP script creates files on...
This is a revised version of my previous question. Hopefully this time it will be simplier and someone will be able to answer it.
In my web root folder there is an .htacces file. In it is...
