Top Web Services Solutions: 1 - 25 of 30
Hi, I need a very simple squid.conf file. I would like to have a file that would represent allowed ip addresses, a file representing Restricted ip addresses and a file that represents allow...
Hi there. My Linksys WRT54G is connected to the Internet on the 2nd floor of the house. I have 3 desktops that need Internet access on the first floor. Cabling is not an option because the ...
Hello Experts I have a Web Service with one WebMethod for which return value is boolean. It accepts XML file as string and process data. How can I first return status as true and then ca...
we need to implement a web service in java, to return a pdf file, this service is cosumbed by siebel application could you suggest me how to do and give me link which gives samples and explan...
Hello! I have some test orders/invoices laying around in Magento which I'd like to delete before going live with the shop.   I've seen lots of scripts to delete data from certain databas...
Dear Experts, Ideally, I would like to make an api which takes in a value and returns results in a nice format like JSON.  Is it possible to make an api with php which can consumed by all w...
To create my Java webservices, we were using Code first approach. First write the code and then run some ANT tasks to generate the XSD and WSDL from it. Now I have been asked to follow the co...
Hi, I'm looking at using Amazon's S3 Simple Storage Solution.  I have about 100Gb of data i need to backup offsite and a regular basis from my severs (images, SQL data etc).  Is this servic...
I need to set up two separate websites on two separate servers in the same network.  I need requests for websiteA.com to be handled by serverA and requests for websiteB.com handled by serverB....
hello to the expert, pls advise how to solve this err? CLS-compliant err compliling window service with class from web service. thank you
I have a large set of data that I'm trying to expose to outside clients via a web service.  And to allow the most use, I was trying to allow them to select which (of the approx 20 fields) the ...
Hi, I try to call a WebService dynamically, I got all the code but when i InvokeMember "GetLanguage", I get an HTTP 401 error (access denied). I try to set the directory security to Anony...
I deployed a webservice successfully but when I try to invoke the service, I am getting the following exception. Could any body tell me hwat cud went wrong?? WSWS3422E: Error: Can not insta...
Hello I am looking for plugin like Send 2 phone which can help me send SMS from my website . I am looking specially for Indian users Please check Send 2 phone at http://mumbai.burrp.co...
I have remote wsdl, it can be accessed in browser, but i need tio aunthetificate, i can call it from soapui, same here i need to fill in details into Aut tab how to generate axis2 client...
Hi, i have created the webservive ejb statelession session bean server side stubs, wsdl files etc and tested successfully as well by right clicking from same project folder. Later i am crea...
Hi, Experts, What are the top two or three things to consider, aside from cost, before entering a website maintenance agreement?  What type of credentials should one ask for from the company/...
I have a web site that calls a web service during the login process for it's members.  Currently, if the service is experiencing an outage or otherwise unavailable the login process fails.  Th...
Dear Experts, I need to send data to many different environments, e.g. desktop applications, web browsers, mobile devices, html websites, flash websites etc etc.  How I want to code it in s...
 I have 2 webservices (asp.net) that I recently inherited from another developer. For some reason one of them returns an xml reponse that contains.. <string xmlns= (see below) I'm not sur...
Hi all, I have a couple webservices (not soap but good old .NET 2.0 asmx webservices) which I want to give a stresstest.   All webservices are available from a single url (but multiple met...
Hi, I want to access and use my class from a web service client like i access and use the same class in an ordinary c# project. So i want to define FoodDataImportSrv myFood = new Foo...
Hi, I have just created a simple default ASP.NET web service called MyWebSerive. (hello World) Putting the following link: ttp://localhost/MyWebService/Service.amxs in the browser gener...
HI, I am trying to generate source files using wsdl2java tool and I need to do more than what is already provided in the given tools? Where do I start from? Are the source code of these too...
I have created a disjointed rollover effect here: http://justduckydesigns.com/test2/women.html  This is working exactly the way I want it to with one exception. When you rollover the text on ...
