I found this question asking how to do this in many different forums, so I will describe here how to implement a solution using PHP and AJAX.
The logical flow for the problem should be:
It sounds difficult. What is an "event handler"? In fact, every user action performed on the web page triggers an event. To handle those events, we need to write a Javascript function, and we call these javascript functions "event handlers". To handle the user's selection of an item in the drop-down box, we need to capture the onchange event. Here is a sample code:
<select id=type name="type" onchange="updateData(this)">
The above code means that a function named "updateData" would be triggered when a user selects an item from this drop-down box. Here the variable "this" means the dropdown box itself. Let's see what happens in the "updateData" function:
function updateData(dropDownBox)
var value=dropDownBox.options[dropDownBox.selectedIndex].value;
if (value!="") //Ensure no empty value is submitted to server side
jQuery.post("getResult.php","type="+value,updateNumber);
The statement:
retrieves user input from the first drop down box. The following statement means user input is sent to server side PHP script "getResult.php".
where we use the Jquery lib to simplify the sending data to the server process. The second parameter is the format of a normal query string and the third parameter is a function that processes the server response.
The server-side program in our case is "getResult.php". For demonstration purposes we do not connect to a database; we just use the user input to generate a different result and then send that to the client.
<?php
$type=htmlspecialchars($_POST["type"]);
if ($type=="1")
echo "1-one\n";//Ends-with \n for client side getting data from server side response
echo "3-three\n";//Ends-with \n for client side getting data from server side response
echo "5-five\n";//Ends-with \n for client side getting data from server side response
echo "7-seven\n";//Ends-with \n for client side getting data from server side response
else
if ($type=="0")
{ echo "2-two\n";//Ends-with \n for client side getting data from server side response
echo "4-four\n";//Ends-with \n for client side getting data from server side response
echo "6-six\n";//Ends-with \n for client side getting data from server side response
echo "8-eight\n";//Ends-with \n for client side getting data from server side response
As described above, we need to specify a function that processes the server response and updates the other drop down box.
So, we need to write a Javascript function named "updateNumber" to get the job done.
function updateNumber(data)
var numberData=jQuery.trim(data).split("\n");//split server side response by "\n"
var number=document.getElementById("number");
$("#number").empty(); //empty the 2nd drop down box
for (i=0;i<numberData.length;i++)
value=numberData[i].split("-")[0];//get value from server response
text=numberData[i].split("-")[1]; //get text from server response
option=new Option(text,value); //for better IE compatibility
number.options[i]=option;
The first two lines of the function parse server response and the third line empty the target drop down box; the for loop is adding options to the target drop-down box.
I have attached the sample code for your reference.
Comments (1)
