web interface for wsh vbs vbscript
Serge FournierAnalyst Programmer
Updated:
PROBLEM:
When developping tools to manage simple tasks in an enterprise or a network, I often use vbscripts
I wanted a way to centralize all thoses scripts, in a user friendly interface that can zoom, print and copy paste easily
As a network administrator, I do not have the time to program theses tools in visual basic
DESCRIPTION:
That is a VBS script that use internet explorer as user interface, divided in 3 frames
control (LEF)
input (MID ok i could have called this one top)
output (BOT)
FUNCTIONALITIES:
right now it's just an interface where you can:
change the control buttons
and insert your own scripts for each button to ask for certain inputs and execute a command
POSSIBLE USES:
creation of a user in LDAP
creation of folders for a new contrat that have just oppened
setting permissions for folders
manage a small access or sql database like a phone list
creation of public folders in outlook ora sharepoint folder in outlook
All these things i will add in the futur updates
They are currently in some of my scripts that are not merged yet with this interface
GUIDE TO ADD A SCRIPT IN THIS INTERFACE:
1. add a button for your script
first part is to add a button to call your scriptit can be done here: (line 86 approx)
x=x+1
ReDim Preserve arabutnam(x): ReDim Preserve arabutdes(x): ReDim Preserve aradepnam(x): ReDim Preserve aradepcol(x)
arabutnam(x)="test2"
arabutdes(x)="test2 my own script"
aradepnam(x)="test"
aradepcol(x)="cccccc"
arabutnam - array of button names
name of the button is just a string (preferably without space or uppercase letters)
arabutdes - description of the button
text inside the button
aradepnam - department or category name
just a category that will appear before a group of buttons
aradepcol - color of the category
just a 3 hexadecimal color code for thml to color the buttons of a category
when the button is added, the script will automatically generate it in internet explorer when run
2. add script
second part is to add the sub/script you want the button to runlet's say we want the button to say "hello world!
we will scroll to the section starting in line 176 approx here is the line to look for:
do
   '=== if the button named this is pressed we do this
   '=== resbutlefstr: result from pressing a button in the left frame (control frame, flef object)
   '=== its a string that contain the programmable name of the button that was pressed in the left frame (arabutnam)
so, after the DO we add the sub we want to execute by pressing the button:
when you press the test2 button, the resbutlefstr will contain the text "test2"
before the code is executed, we must clear resbutlefstr and the frames or the main loop will act like if the button was still pressed
do '=== already in the code do not put two "do" there!
   if resbutlefstr="test2" then
      '=== clear 2 frames (input: fmid, and result: fbot)
      '=== also clear the result button name for all frames and the key pressed on all frames
      a = clefra(array("fmid","fbot"))
      fbot.WriteLn("Hello world<br><br>") '=== write hello world in frame
   end if
after hello world is displayed, nothing will happen until you press another button in the control frame (left)
3. How does the input form work
third part is to explain how the input form generator work
as you can see in the other subs executed by the buttons, there is also a form ready to input something to process something more complicated than "hello world"
The sub to call to generate this from is called:
dynforgen dynamic form generator
It's input are:
distmp - description displayed in front of the field
namtmp - name of variable for programming purpose
deftmp - default value inside the form (the form will be 20 char long if no value here, but you can enter more)
typtmp - type of data: textbox password (futur: more to come)
errtmp - text to display after the formm if error string is in it the interface will generate red text
Here is the code to prepare the input field for the form:
      x=0
      redim preserve distmp(x) :redim preserve namtmp(x) :redim preserve deftmp(x) :redim preserve typtmp(x) :redim preserve errtmp(x)
      distmp(x)="Database name"      '===== description displayed in front of the field
      namtmp(x)="dbnam"                 '===== name of variable for programming purpose and to be able to retrive it in VBS
      deftmp(x)="testmdbaccess2000"     '===== default value inside the form (the form will be 20 char long if no value here, but you can enter more)
      typtmp(x)="textbox"               '===== type of data: textbox password (futur: more to come)
      errtmp(x)=".MDB enter name of DB file" '===== text to display after the form "facultatif" blue text "error" red text are special keywords
Each element of this matrix will be an input field, that have a name and it's value can be accessed in the vbs script after the user
entered something and pressed "ok" (string value "ok" in resbutmidstr or "enter" (code 13) in reskeymid
Some sub are premade to "scan" button values and keyboard values in the internet exploer object and put them in the results variables reskeymid and resbutmidstr
a sub have been programmed for each frame and each event (button and key)
'=== sub to call when something is pressed
'=== called for many buttons, return the button name or a keyboard code (Ascii)
sub buttonlef
   set src = flef.parentWindow.event.srcElement
   resbutlefstr = src.name
end sub
reskeymid - containt the key code (Ascii) pressed by the user in middle frame (fmid object)
resbutmidstr - is a string that will contain the name of the button that was pressed by the user
4. How to insert a form and use it's input value
Fourth part is to insert the code to input something then display it
Finally, here is the code we have to insert to make a better "Hello World" with an input from the user:
   if resbutlefstr="test" then
      '=== this was a test with multiple button value (one for each line)
      x=0
      distmp(x)="what do you want to display"      '===== description displayed in front of the field
      namtmp(x)="text01"                  '===== name of variable for programming purpose
      deftmp(x)="hello world"           '===== default value inside the form (the form will be 20 char long if no value here, but you can enter more)
      errtmp(x)="enter a text to display" '===== text to display after the form "facultatif" blue text "error" red text are special keywords
      buttmp=array("ok","cancel")       '===== at the end, there will be an "ok" button and a "cancel" button
      a = dynforgen (distmp,namtmp,deftmp,typtmp,errtmp,buttmp,tit)
      do
         '=== flag to tell if the input is not valid
         err01=0
         '=== flag to say input is done, since there might be a defaut value, we must validate if user was finished
         inpdon=0
         '=== "ok" button or "enter" key are the same
         '=== and nothing was pressed on left frame (control frame)
         if resbutlefstr="" and (resbutmidstr="ok" or reskeymid=13) then
            '=== User has clicked the OK button, retrieve the values
            text=fmid.form01.text01.Value '=== namtmp is the variable name used earlier,before we call the dynamic form generation for input
            if len(text) < 1 then
               err01=1
               '=== error message for the first form (if the keyword "error" is in this string, its displayed in RED)
                  errtmp(0)="error - must be 1 char long at least"
               end if
               '=== if the value was not good, we generate the dynamic input for again, with an error message after the form in red
               a = dynforgen(distmp,namtmp,deftmp,typtmp,errtmp,buttmp,tit)
               '=== there was an invalid input so we reset the key or button pressed to nothing so the loop can continue
               reskeymid=0
               resbutmidstr=""
            else
               '=== the input was validated, we flag err01 to none, and flag inpdon to exit the loop
               inpdon=1
               err01=0
            end if
         end if
         wscript.sleep 100
         '=== while we wait for input value, user can press "escape" key, "cancel" button or close internet explorer
         if resbutmidstr="cancel" or reskeymid=27 or bready=true or resbutlefstr<>"" then
            '=== if user pressed escape or cancel, we clear the frames
            if resbutmidstr="cancel" or reskeymid=27 then
            end if
            exit do
         end if
      '=== if there was an input error and no one used left control frame to exit, we keep asking for input
      loop while err01<>0 or inpdon=0
      '=== if internet explorer was not closed (bready), a button was not pressed on left frame, and no excape or cancel in middle frame
      if bready=false and resbutlefstr="" and reskeymid<>27 and resbutmidstr<>"cancel" then
         fbot.WriteLn(text & "<br>")
      end if
      reskeymid=0
      resbutmidstr=""
   end if
I know this is a bit complicated for a beginner, but a simple copy paste to make another operation is not really hard once you have a base in VB
Here are the main lines to change:
Here is the name of the button that will make the action happen:
Name of the variable that will containt the text result from the interface:
Code where we will get this result to validate it: (text01)
Length validation and error message (errtmp(0), matrix element 0 for error message is for the first box, 1 for second etc)
               err01=1
               end if
And finally the action to do after all input are done and validated: (and there is nothing that hapenned before, like a cancel or closing internet explorer)
      end if
CHANGE LOG:
2010-04-12 added some delay in internet explorer operation (frame clear) it was making ie crash
2010-04-10 correction in the input loop, left frame now have a better control
2010-04-09 added dabatase creation with a masterkey based on an integer column autoincrement
 dynamic web interface
'=== Ultimate dynamic web interface 2.0
'=== this script:
'=== generate dynamically a web interface to manage virtually anything
'=== control (left frame), input (middle frame), and output (bottom frame) from vbs/wsh (windows host scripts)
'=== the first version was a simple interface made by a programmer
'=== the second version have more explanations
'=== more dynamism than ever
'=== more functions to clean up main loop code
'=== easier array display coding to add stuff more easily
'=== MDB (access type database) management (creation, edition, search/edit)
'=== futur: mdb import, mdb export, sql sync, excel export
'=== by: SergeFournier(at)hotmail.com
'=== tested on windows vista 64, internet explorer 7
Set objFSO    = CreateObject("Scripting.FileSystemObject")
Set objshe    = CreateObject("WScript.Shell")
Set objNet    = CreateObject("WScript.Network")
Const hkcr = &H80000000 'HKEY_CLASSES_ROOT
Const HKCU = &H80000001 'HKEY_CURRENT_USER
Const hklm = &H80000002 'HKEY_LOCAL_MACHINE
Const hku  = &H80000003 'HKEY_USERS
Const hkcc = &H80000005 'HKEY_CURRENT_CONFIG
'=== actual drive, actual directory, and "\"
thepath=WScript.ScriptFullName
p = instrRev(thepath,"\")
basedir  = left(thepath,p)
filnam = right(thepath,len(thepath)-p)
'=== windows dir
WinDir = objfso.GetSpecialFolder(0)
'=== restart the script in 32 bits if we are on a 64 bits system
'=== (databases drivers issues)
a64 = windir & "\syswow64\wscript.exe"
if objFSO.fileEXISTS(a64) and instr(lcase(wscript.fullname),"syswow64")=0 then
   '=== 64 bits system
   a = """" & a64 & """ """ & basedir & filnam & """"
   objshe.Run a,0, false
   wscript.quit
end if
'============================================== main loop =============================================
'=== name of the user logged in window (network or not)
usenam=lcase(objnet.username)
'=== menu items on left side (control side, frame: flef)
'= arabutnam: name of button, purely programmation name, used later to execute functions in main loop
'= arabutdes: description of button, text inside it actually
'= aradepnam: departement name, each departement (Section) is separated by a space
'= aradepcol: color of departement, blue = computer, brown = accounting, etc will follow a standard on internet (vague)
'=== button at the start for control frame (flef object)
'=== you can add as many buttons as you want, it's all dynamic (extendable)
x=0
arabutnam(x)="newdb"
arabutdes(x)="Create new database"
aradepnam(x)="Change"
x=x+1
arabutnam(x)="edtdb"
arabutdes(x)="Edit database"
x=x+1
arabutnam(x)="srcdb"
arabutdes(x)="Search database"
aradepnam(x)="View"
x=x+1
arabutnam(x)="test"
arabutdes(x)="test multiple buttons"
aradepnam(x)="test"
x=x+1
arabutnam(x)="quit01"
arabutdes(x)="Quitter"
aradepnam(x)="All"
'=== old code for ref
'arabut=array("stristas", "striunig", "desarchive", "infocomp", "cretasks", "renamecomputer", "test", "clrframes", "quit01")
'arabutdes=array("Crée Structure i: Stas", "Crée Structure i: Unigec", "Désarchivage", "Info computer", "Create tasks", "Rename computer", "test divers",  "Clear Frames",    "Quitter")
'aradep=array("All", "All", "Informatique", "Informatique", "Informatique", "Informatique", "Other", "All")
'aradepcol=array("cccccc", "cccccc", "6699ff", "6699ff", "6699ff", "6699ff", "6699ff", "cccccc")
'=== i dont remember this one
lasdep=""
'=== web interface, internet explorer
'=== set the objects before calling functions, so they are global objects/variables, accessibles in all the program
set oIE = wscript.CreateObject("InternetExplorer.Application", "IE_")
dim flef, fmid, fbot
'=== title of internet explorer window
doctit = "titre de la page"
'=== title to display inside the left frame (control frame, flef object)
maitit = "SKYNET interface<br><br>STAS "'=== title inside the left frame
'=== create the main web interface with 3 frames, objects: flef, fmid, fbot
a = crewebmai(oie, doctit, maitit, arabutnam, arabutdes, aradepnam, aradepcol)
'=== defaut menu option for certain name logged
'=== example: a certain user will use always the same function
'=== so the interface will start, by executing this function at first, not an empty frame
'=== simply enter the name of the button that should be pressed for this user when interface start
if usenam="wildboy" or usenam="fournier.serge" then
   '=== defaut choice when program start
   'resbutlefstr = "stristas"
end if
'=== sub to call for each button
'=== here we define a sub to be called when a button in the web page is pressed
Do While (oIE.Busy)
   wscript.sleep 100
loop
do while oie.readystate<>4
   wscript.sleep 100
loop
'=== set up a return value on click of each button on the left frame
'=== the returned value is the name (programmable name) of each button (arabutnam)
'=== later any action will be taken according to this value
'=== i use this method because i dont want to call a sub when a button is pressed
'=== to remain in a loop for the main program, that is standard procedure in programming (to have a main loop)
for i=0 to ubound(arabutnam)
   flef.forms(0).elements(arabutnam(i)).onclick = getref("buttonlef")
next
'=== we also chek the key presse in each frame
'=== we do this cause we want "enter" key to be used instead of pressing "ok" button with the mouse
set flef.onkeypress = GetRef("Checklef")
set fmid.onkeypress = GetRef("Checkmid")
set fbot.onkeypress = GetRef("Checkbot")
'=== if bready = true, it mean they closed internet explorer, see the sub on internet explorer closing later in this code
'=== we have to chek this value often to stop the wscript.exe from interpreting this code, when internet explorer is closed
bReady=false
      resbutlefstr = ""
      resbutmidstr = ""
      resbutbotstr = ""
      reskeylef = 0
      reskeymid = 0
      reskeybot = 0
WScript.sleep(100) ' .1 seconds
'=== main loop, infinite
'=== unless someone press QUIT button
'=== or close internet explorer (bready = true)
do
      x=0
      do
         err01=0
         inpdon=0
               err01=1
               else
                  errtmp(0)="ok"
               end if
               reskeymid=0
               resbutmidstr=""
            else
               inpdon=1
               err01=0
            end if
         end if
         wscript.sleep 100
            end if
            exit do
         end if
      end if
      reskeymid=0
      resbutmidstr=""
   end if
   if resbutlefstr="newdb" then
      '=== create a new database mdb type (Access 2000)
      tit="new database" '=== title to display in fmid frame (input frame)
      '=== dynamic generation of input form, and control buttons in fmid (middle or up frame, called "input" frame for more clarity, fmid object)
      '=== inputs to do before processing
      '=== you can add more input forms, at the end, there will be an "ok" button and a "cancel" button
      x=0
      x=x+1
      distmp(x)="Table name"      '===== description displayed in front of the field
      namtmp(x)="tabnam"                 '===== name of variable for programming purpose
      deftmp(x)="table01"     '===== default value inside the form (the form will be 20 char long if no value here, but you can enter more)
      errtmp(x)="enter name of first table" '===== text to display after the form "facultatif" blue text "error" red text are special keywords
      do
         inpdon=0
         err01=0
            dbnam = fmid.form01.dbnam.Value '=== namtmp is the variable name used earlier,before we call the dynamic form generation for input
            dbnam=lcase(dbnam)
            tabnam = fmid.form01.tabnam.Value '=== namtmp is the variable name used earlier,before we call the dynamic form generation for input
            tabnam=lcase(tabnam)
            if len(dbnam) < 1 or len(tabnam)<1 then
               err01=1
               if len(dbnam) < 1 then
                  errtmp(0)="error - name must be 1 char long at least"
               else
                  errtmp(0)="ok"
               end if
               if len(tabnam) < 1 then
                  errtmp(1)="error - name must be 1 char long at least"
               else
                  errtmp(1)="ok"
               end if
               reskeymid=0
               resbutmidstr=""
            else
               inpdon=1
               err01=0
            end if
         end if
         wscript.sleep 100
            end if
            exit do
         end if
         '=== all value were validated, we continue
         dbnam = dbnam & ".mdb"
         '=== chek if the file already exist
         Set objFolder2 = objFSO.GetFolder(basedir)'=== dir
         Set objFiles2 = objFolder2.files '=== fichiers
         found=0
         For Each objFile3 in objFiles2
            nomfile=objfile3.name
            nomfile=lcase(nomfile)
            if nomfile=dbnam then
               found=1
            end if
         next
         if found=1 then
            a = clefra(array("fmid"))
            fbot.WriteLn("The file: <br>" & dbnam & "<br>Already exist<br><br>Please use EDIT DATABASE to manage it<br><br>")
            fbot.WriteLn("FIN<br><br>")
            fbot.WriteLn("LIST of table in the existing database:<br><br>")
            Set objcat = CreateObject("ADOX.Catalog")
            Set objcon = CreateObject("ADODB.Connection")
            constr = "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & dbnam
            objcon.open constr
            objcat.activeconnection=(objcon)
            for each tab in objcat.Tables
               If tab.Type = "TABLE" Then
                  fbot.WriteLn("<br>TABLES:<br><br>")
                  fbot.WriteLn(tab.name & "<br>")
                  fbot.WriteLn("<br>COLUMNS:<br><br>")
                  for each col in tab.columns
                     c = lcase(col.name)
                     fbot.WriteLn(c & "<br>Type: " & col.type & "&nbsp&nbsp&nbspAutoincrement: " & col.Properties("AutoIncrement") & "<br>")
                  next
               end if
            next
            objcon.close
            set objcat=nothing
            set objcon=nothing
         else
            '=== formats: jet10 = 1 Jet11 = 2 Jet20 = 3 Jet3x = 4 Jet4x = 5 (Access 2000)
            Dim Catalog
            fbot.WriteLn("Creation ADOX catalog (adox.dll, access required)<br><br>")
            format = 5
            fbot.WriteLn("database creation: " & dbnam & "<br><br>")
            constr="Provider=Microsoft.Jet.OLEDB.4.0;" & "Jet OLEDB:Engine Type=" & Format & ";Data Source=" & dbnam
            objcat.Create constr
            '=== add a table in the database
            fbot.WriteLn("table creation: " & tabnam &"<br>")
            Set objtab = CreateObject("ADOX.table")
            objtab.name = tabnam
            objcat.Tables.Append objtab
            objcat.Tables.refresh
            '=== add a columns in the only existing table
                  fbot.WriteLn("table existing: " & tab.name & "<br>")
                  '=== add column in database
                  Set objcol = Nothing
                  Set objcol = CreateObject("ADOX.Column")
                  'typdat=202   '=== string adVarWChar
                  'maxlen=250
                  'typdat=131   '=== float adnumeric
                  'maxlen=10
                  typdat=3     '=== integer adinteger
                  maxlen=10
                  if typdat=3 then a="adinteger"
                  if typdat=202 then a="adVarWChar"
                  if typdat=131 then a="adnumeric"
                  colnam="codint"
                  objcol.name = colnam
                  objcol.type = typdat
                  if typdat = 3 or typdat = 202 then
                     objcol.DefinedSize = maxlen
                     if typdat=3 then
                        '=== must set parent catalog before setting autoincrement
                        Set objcol.ParentCatalog = objcat
                        objcol.Properties("AutoIncrement")=true
                     end if
                  elseif typdat = 131 then
                     objcol.precision = 28
                     objcol.numericscale = 8
                  end if
                  fbot.WriteLn("column creation: " & colnam & "<br>")
                  Tab.Columns.Append objcol
                  fbot.WriteLn("primary key creation: " & colnam & "<br>")
                  Set objkey = CreateObject("ADOX.key")
                  objkey.name="Primary"
                  objkey.columns.append colnam
                  tab.keys.append objkey
                  'Set aIndex = New ADOX.Index
                  'aIndex.Name = "ByField2"
                  'aIndex.Clustered = False
                  'aIndex.Columns.Append "Field2"
                  'aIndex.Columns.Append "Field1"
                  'aTable.Indexes.Append aIndex ' save the index
                     c = lcase(col.name)
                     fbot.WriteLn("column existing: " & c & "&nbsp&nbsp&nbspautoincrement status: " & objcol.Properties("AutoIncrement") & "<br>")
                  next
               end if
            next
            set objcat=nothing
            fbot.WriteLn("<br>You database have been created with 1 table and a defaut column named " & colnam & "<br>")
            fbot.WriteLn("<br>END<br>")
         end if
      else
      'msgbox(resbutlefstr & "   " & resbutmidstr & "   " & resmidkey & "   " & bready)
      end if
      reskeymid=0
      resbutmidstr=""
      dbnam=""
   end if
   if resbutlefstr="edtdb" then
      resbutlefstr = ""
      '=== value
      Set objFol01=objFSO.GetFolder(basedir)'=== dir
      Set objfol02=objFol01.files '=== files
      x=0
      redim ara01(0)
      dimnum=1
      For Each objFil in objFol02
         filnam=objfil.name
         filnam=lcase(filnam)
         if right(filnam,4)=".mdb" then
            redim preserve ara01(x)
            ara01(x)=filnam
            x=x+1
         end if
      next
      '=== title of the columns
      aratit = array("Name of the database")
      '=== array to put in table, choice button, header, middle line, bottom line, reload
      a = dynbotcho(fmid, "choose the database to edit", aratit, ara01, 1 ,1, 1, 1, 1)
      do
         wscript.sleep 100
         '=== while we wait for input value (or button press), user can press "escape" key, "cancel" button or close internet explorer
            end if
            exit do
         end if
      loop while resbutmidstr=""
         '=== convert the choice made with the button to a number (remove "but" from left side)
         a=right(resbutmidstr,len(resbutmidstr)-3)
         resbutmidstr=""
         '=== get the array that contain the choice in dbnam (database name)
         dbnam=ara01(a-1)
         '=== open the database
         Set objcon = nothing
         objcon.open constr
         '=== pressing left control button while in a function will call a sub make internet explorer crash
         '=== so i have to put the table choice in main loop, cant do a sub
         '=== choose the table to edit
         aratit=array("Table name")
         x=0
         redim ara01(0)
               c = lcase(tab.name)
               ara01(x)=c
               x=x+1
            end if
         next
         a = dynbotcho(fmid, "Choose the table to edit", aratit, ara01, 1 ,1, 1, 1, 1)
         do
            wscript.sleep 100
               end if
               exit do
            end if
            resbutmidstr=""
            tabnam=ara01(a-1)
            fbot.WriteLn(tabnam)
                  if tabnam = lcase(tab.name) then set objtab=tab
               end if
            next
            '=== list columns in table
            for each col in objtab.columns
            next
         end if
      end if
      '========================== caca
      'msgbox("exit on left button" & resbutlefstr)
      'resbutlefstr = ""
      resbutmidstr = ""
      resbutbotstr = ""
      reskeylef = 0
      reskeymid = 0
      reskeybot = 0
   end if
   if resbutlefstr="srcdb" then
   end if
   if resbutlefstr="test33" then
      fmid.WriteLn("<html><body>TEST</html></body>")
      '=== bottom section
      fbot.WriteLn("<html><body>TEST mid section")
      fbot.WriteLn("<html><body><form method='post' name='form1'>")
      butnam = "buttonbot"
      for ii=0 to 10
         fbot.WriteLn("<input type=""button"" style=""height:50px;font-size:14px;width:50%;"" name=""" & butnam & ii &""" value=""" & butnam & ii & """ ")
         fbot.WriteLn("style=""background-color: #cccccc; color: #000000;""><br>")
      next
      fbot.WriteLn("</form>")
      fbot.WriteLn("</html>")
      fbot.WriteLn("</body>")
      for ii=0 to 10
         fbot.forms(0).elements(butnam & ii).onclick = getref("buttonbot")
      next
      '=== loop until a button is pressed on left frame or ie is closed
      do
         wscript.sleep 100
         if resbutbotstr<>"" then
            fmid.WriteLn(resbutbotstr)
            resbutbotstr=""
         end if
      loop while resbutlefstr="" and bReady=false
      '=== ie is still open and but come button was pressed on left frame
      if bready=false and resbutlefstr<>"" then
         '=== we remove the actions on the buttons
         for ii=0 to 10
            fbot.forms(0).elements(butnam & ii).onclick = nothing
         next
         '=== clear frames, reset button value and keyvalue
         if resbutlefstr<>"quit01" then
         end if
      end if
   end if
   '=== desarchivage (move files from archives to temp folder and pop outlook message)
   '=== here as reference onlym not working, missing a sub
   if resbutlefstr= "desarchive" then
      tit="Désarchivage"
      '=== refresh menu (chek button = 0)
      distmp=array("Login","Password","Numéro(s) de contrat")
      namtmp=array("login","password","connum")
      deftmp=array("","","")
      typtmp=array("textbox","password","textbox")
      errtmp=array("Facultatif","Facultatif","")
      do
         err01=0
            connum = fmid.form01.connum.Value
            if len(connum) < 5 then
               a = "error - contrat doit avec 5 caractères"
               err01=1
               errtmp(2)=a
            end if
         end if
         wscript.sleep 100
         if resbutmidstr="cancel" or reskeymid=27 then exit do
      loop while (err01<>0 and resbutlefstr="") or (connum="" and resbutlefstr="")
         '=== doing the job, all input are ok
         a = desarchive2(connum,fbot)
         fbot.WriteLn("done<br>")
         resbutmidstr=""
         reskeymid=0
      elseif resbutlefstr="" and (resbutmidstr="cancel" or reskeymid=27) then
         '=== nothing was pressed on left, but cancel was used or escape
      elseif resbutlefstr<>"" then
         '=== sometthing hapenned with the buton on the left side (menu/control)
      end if
   end if
   '=== .1 seconds
   wscript.sleep 100
'=== we loop until internet explorer was closed or the quit button was pressed
loop until bReady or resbutlefstr="quit01"
'====================== end of main loop
'=== someone pressed "quit" on left frame (control frame, flef object)
'=== at the end, if internet explorer was not closed, we close it
if bready=false then
   oie.quit
   set oie=nothing
end if
'=== we end wscript.exe, exiting all running code interpretation
wscript.quit
'=== many subs
'=== if internet explorer is closed (event) we change bready value to TRUE
sub IE_onQuit()
   bReady=true
end sub
'=== database creation, mdb, access 2000
function credb()
   '=== Create Access2000 database
   CreateNewMDB basedir & "test.mdb", 5
   '=== list of tables to create
   alltab(0) = "tab01"
   alltab(1) = "components"
   alltab(2) = "diagnostic"
   alltab(3) = "causes"
   '=== with a column for identification, numerical, autoincremental
   '=== 0 creation columns
   '=== 1 search in thoses columns
   '=== 2 fast/short results columns
   '=== 3 detail results columns
   '=== columns to create (first numner is table number, second is array number, 0 = creation)
   allara(0,0) = array( _
   "[codeint]", _
   "[test01]")
   '=== columns to search in
   '=== short result (What columns to display if the result should be short)
   '=== detailed results (almost all columns with data)
end function
'============================================== subs and functions ====================================
Sub CreateNewMDB(FileName, Format)
  Dim Catalog
  Set Catalog = CreateObject("ADOX.Catalog")
  Catalog.Create "Provider=Microsoft.Jet.OLEDB.4.0;" & "Jet OLEDB:Engine Type=" & Format & ";Data Source=" & FileName
End Sub
'=== frames clear content by navigating to a blank
'=== input is an array containing name of frames as "flef" = frame left
'=== this sub generate a code and execute it in a string (cc)
'=== fully dynamic programming at it's best ;)
function clefra(aara)
   cc=""
   for each aa in aara
      cc = cc & "Do While (oIE.Busy) " & vbcrlf
      cc = cc & "   wscript.sleep 200" & vbcrlf
      cc = cc & "Loop" & vbcrlf
      cc = cc & "Do While oie.readystate<>4" & vbcrlf
      cc = cc & aa & ".location.reload(true)" & vbcrlf
      cc = cc & aa & ".WriteLn(""&nbsp;"")" & vbcrlf
   next
   execute cc
   '=== we also clear the variables used to control the action buttons and the key pressed in each frames
   '=== so the action wont be taken twice (or infinitly) in the main loop
   'set flef = oie.document.frames("left").document
   'set fmid = oie.document.frames("middle").document
   'set fbot = oie.document.frames("bottom").document
'for i=0 to ubound(arabutnam)
'   flef.forms(0).elements(arabutnam(i)).onclick = getref("buttonlef")
'next
'set flef.onkeypress = GetRef("Checklef")
'set fmid.onkeypress = GetRef("Checkmid")
'set fbot.onkeypress = GetRef("Checkbot")
   resbutlefstr = ""
   resbutmidstr = ""
   resbutbotstr = ""
   reskeylef = 0
   reskeymid = 0
   reskeybot = 0
end function
'=== form dynamically generated =========================================================================
function dynforgen (distmp, namtmp,deftmp,typtmp,errtmp,buttmp,title)
   '=== generate a form for input in the input frame (fmid object)
   '=== focus on the first field with no default value
   '=== display suffix message in red if "error" (or "erreur" - french) keyword is in it
   fmid.WriteLn("<h3><span class=SpellE>" & title & "</span></h3>")
   '=== default focus on empty field (with no default value)
   deffoc=0
   for ii=0 to ubound(namtmp)
      if deftmp(ii)="" then
         if instr(lcase(errtmp(ii)),"facultatif")=0 then
            fmid.WriteLn("<BODY onLoad=""document.form01." & namtmp(ii) & ".focus()"">")
            deffoc=1
         end if
      end if
      '=== no default value empty, we focus on first field
   next
   if deffoc=0 then
      fmid.WriteLn("<BODY onLoad=""document.form01." & namtmp(0) & ".focus()"">")
   end if
   fmid.WriteLn("<div class=MsoNormal align=center style='text-align:center'>")
   fmid.WriteLn("</div>")
   fmid.WriteLn("<form name=form01>")
   '=== button and error message
      fmid.WriteLn(distmp(ii) & ": ")
      '=== we disable "enter" to submit form because we manage this event as a onkeypress in the parent frame of the form later
      '=== we had to do this, because the web page form is not run on a server, and the web page dont have control, the VBS script outside the page have control
      fmid.WriteLn("<input type=""" & typtmp(ii) & """ id=" & namtmp(ii) & " NAME=""" & namtmp(ii) & """ size=""" & max(20,len(deftmp(ii))) & """ value=""" & deftmp(ii) & """ onKeypress=""return event.keyCode!=13""")
      'fmid.WriteLn("")
      if instr(lcase(errtmp(ii)),"error")<>0 or instr(lcase(errtmp(ii)),"erreur")<>0 then
         col="red"
      else
         col="blue"
      end if
      fmid.WriteLn("&nbsp; <b><span style='color:" & col & "'>&nbsp" & errtmp(ii) & "</span></b><br style='mso-special-character:line-break'>")
   next
   fmid.WriteLn("<![if !supportLineBreakNewLine]><br style='mso-special-character:line-break'>")
   fmid.WriteLn("<![endif]></p>")
   for ii=0 to ubound(buttmp)
      typ01 = "button"
      fmid.WriteLn("<input type=""" & typ01 & """ name=""" & buttmp(ii) & """ value=""&nbsp;" & buttmp(ii) & "&nbsp;"">")
      fmid.WriteLn("&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp")
   next
   fmid.WriteLn("</form>")
   fmid.WriteLn("</body>")
   fmid.WriteLn("</html>")
   fmid.location.reload(true)
   '=== wait for internet explorer to be ready after we refresh the page with the new form
      Do While (oIE.Busy)
         wscript.sleep 100
      loop
         wscript.sleep 100
      Loop
      '=== value to return for each button in the form
      fmid.forms(0).elements(buttmp(ii)).onclick = getref("buttonmid")
   next
   '=== regenerate the event that call a sub if a button is pressed
   '=== clear button pressed and key pressed for this frame
   resbutmidstr=""
   reskeymid=0
end function
'===  max
Function max(a, b)
	If a > b Then max = a Else max = b
End Function
function crewebmai(oie, doctit, maitit, arabutnam, arabutdes, aradepnam, aradepcol)
'=== create an internet explorer object (oie) that will be in 3 frames (flef, fmid, fbot), acting at the main interface for all this program
oie.FullScreen = False
'.ToolBar   = False
'.StatusBar = False
'.Navigate("About:Blank")
'.visible = true
oIE.left=0 ' window position
oIE.top = 0 ' and other properties
'.ParentWindow
'        .resizeto 640,300
'        .moveto (.screen.width
oIE.height = 500
oIE.width = 500
oIE.menubar = 1 '=== no menu
oIE.toolbar = 1
oIE.statusbar = 1
oIE.RegisterAsDropTarget = True
oie.Navigate("about:blank")
oie.document.title = doctit
oiewid = oie.document.parentwindow.screen.width
oiehei = oie.document.parentwindow.screen.height
sizwidpercent = 100
sizheipercent = 95
loswid = 100-sizwidpercent
loshei = 100-sizheipercent
newwid = oiewid*sizwidpercent*.01
newhei = oiehei*sizheipercent*.01
oie.document.parentwindow.resizeto newwid,newhei
newx = oiewid * loswid * .01 /2
newy = oiehei * (loshei/2) * .01 /2
oie.document.parentwindow.moveto newx, newy
oIE.visible = 1 '=== visible on
oie.addressbar=false
'=== we will always have 3 frames, control, input and output (flef, fmid, fbot)
'=== used an array to have a good view of the line of html and possibility to add something else easily
aratmp=array(_
"<HTML>",_
"<HEAD><TITLE>" & doctit & "</TITLE>",_
"<meta content=""text/html; charset=utf-8"" http-equiv=""Content-Type"">",_
"<meta http-equiv=""X-UA-Compatible"" content=""IE=8"">",_
"</HEAD>",_
"<FRAMESET id='main' COLS=""13%, *"">",_
"<FRAME SRC=""About:Blank"" NAME=""left"" id=""left"">",_
"<frameset id='main2' rows=""30%,70%"">",_
"<FRAME SRC=""About:Blank"" NAME=""middle"" id=""middle"">",_
"<FRAME SRC=""About:Blank"" NAME=""bottom"" id=""bottom"">",_
"</FRAMESET>", _
"</frameset>", _
"</HTML>")
'oie.Navigate("About:Blank")
'=== send the array content in internet explorer to create 3 frames
for i = 0 to UBound(aratmp, 1)
   oie.document.WriteLn(aratmp(i))
next
oie.refresh
Do While (oIE.Busy)
   wscript.sleep 100
Loop
'=== wait till document loaded
   wscript.sleep 100
Loop
'=== vista activate
'=== make internet explorer the main active window
a = objShe.AppActivate("http:/// - " & doctit & " - M")
a = objShe.AppActivate(doctit & " - M")
'=== theses objects are used to send data to the 3 different frames
'=== if you dont define them as object, the access to them is very slow when we use the names instead of the objects
'=== object used to write in a frame with writeln
fileversion = objFSO.GetFileVersion("C:\program files\internet explorer\iexplore.exe")
finddot = instr(fileversion,".")
fileversion2 = left(fileversion,finddot-1)
if fileversion2 = "10" or fileversion2 = "11" then
	'=== ie10 frame access
	set flef = oie.parent.document.getElementByid("left").contentdocument
	set fmid = oie.parent.document.getElementByid("middle").contentdocument
	set fbot = oie.parent.document.getElementByid("bottom").contentdocument
else
end if
'=== object used to navigate an empty page in a frame
'set flefl = oie.document.frames("left").location
'set fmidl = oie.document.frames("middle").location
'set fbotl = oie.document.frames("bottom").location
'=== string result for a button press in a frame (lef = left frame, mid = middle frame (up))
resbutlefstr=""
resbutmidstr=""
resbutbotstr=""
reskeylef=0
reskeymid=0
reskeybot=0
'=== all the chek to be made in first page (1 at the moment, since ready have many values)
nbrbut=UBound(arabutnam, 1)
redim buttag(nbrbut)
form = "flef"
flef.WriteLn("<html><body>")
flef.WriteLn("<body background=""" & basedir & "LOGO-STAS-FOND.jpg"">")
flef.WriteLn("<h3><span class=SpellE>" & maitit & "</span></h3>")
flef.WriteLn("<form name='form1'>")
   '=== convert xls to mdb button appear for stas only
   if ((usenam="wildboy" or usenam="fournier.serge" or usenam="fortin.jp" or usenam="lavoie.daniel" or usenam="doucet.gm") and arabutnam(i)="excel2mdb") or arabutnam(i)<>"excel2mdb" then
      'style="background-color: #cc0000; color: #ffffff;" /
      b = "<input type=""button"" style=""height:50px;font-size:14px;width:100%;"" name=""" & arabutnam(i) & """ value=""" & arabutdes(i) & """"
      i2=i
      if i>ubound(aradepnam) then
         i2=ubound(aradepnam)
      else
         a=aradepnam(i2)
      end if
      if a<>lasdep then
         '=== new departement name
         flef.WriteLn( "<br>" & a & "<br>")
         lasdep=a
      end if
      b = b & " style=""background-color: #" & aradepcol(i2) & "; color: #000000;""><br>"
      flef.WriteLn(b)
   end if
next
flef.WriteLn("</form>")
flef.WriteLn("</body>")
flef.WriteLn("</html>")
'=== we dont refresh this frame, its the first one
end function
sub buttonlef
end sub
sub buttonmid
   set src = fmid.parentWindow.event.srcElement
   resbutmidstr = src.name
end sub
sub buttonbot
   set src = fbot.parentWindow.event.srcElement
   resbutbotstr = src.name
end sub
sub Checklef
   reskeylef = flef.parentWindow.event.keycode
end sub
sub Checkmid
   reskeymid = fmid.parentWindow.event.keycode
end sub
sub Checkbot
   reskeybot = fbot.parentWindow.event.keycode
end sub
'=== chek in the actual folder if a file exist
function filsea(filname)
'=== chek also actual folder for a "Rappel_LOG" file (instr)
found=0  '=== fichier de rapport pas trouve
   nomfile =objfile3.name
   nomfile= lcase(nomfile)
next
end function
'=== delete a table in a database
function tabdel()
               b=lcase(tab.name)
               '=== object.delete not supported, so we delete with name
               objcat.tables.delete b
               fbot.WriteLn("delete: " & b & "<br>")
            END IF
         next
end function
'=== for reference
function dynbotcho00
               i3=0
               For each dia01 in choiceara
                  sql = makque(dia01,tab,sel,whe,"","=","")
                  a = exesql(objcon,tag,sql)
                  '=== make same array for a multiples queries
                  if tag.eof=0 then
                     'a = dynbotcho("DIAGNOSTIC",tag,0,sql,1,1,1,1) '=== 1 2 3
                     if ubound(choiceara)=0 and i3=0 then
                     elseif i3=0 then
                        '=== header
                        a = dynbotcho("DIAGNOSTIC",tag,0,sql,1,1,0,0) '=== 1 2 3
                     elseif i3<>ubound(choiceara) and i3<>0 then
                        '=== footer
                        a = dynbotcho("DIAGNOSTIC",tag,0,sql,0,1,0,0) '=== 1 2 3
                     elseif i3=ubound(choiceara) then
                        a = dynbotcho("DIAGNOSTIC",tag,0,sql,0,1,1,1) '=== 1 2 3
                     end if
                     i3 = i3 + 1
                  else
                     '=== 0 results
                     a = nores(sql)
                  end if
               next
end function
function dynbotcho(ffra, ttext, aaratit, aara, cc01 ,hh, mm, ff, rr)
   '=== ffra frame to use for display (object)
   '=== ttext to display
   '=== aara = array with what to display
   '=== cc = choice button
   '=== sql = sql query for debugging
   '=== hh = 1 = header
   '=== mm = 1 = middle
   '=== bb = 1 = footer
   '=== rr = 1 = reload at end
   call oieready
   '=== print button
   priara = array("<input type=""button"" onClick=""javascript:print()"" value=""Print""/><br><br>")
   xmax = UBound(aara, 1) 'Returns the Number of columns  --- elements in first dimension
   on error resume next
   ymax = UBound(aara, 2) 'Returns the Number of rows     --- elements in second dimension
   '=== number of dimensions in case there is only 1 column
   if err<>0 then
      dimnum=1
   else
      dimnum=2
   end if
   on error goto 0
   '=== web script for buttons to return the number of the button that was pressed
   '=== print button
   if hh=1 then
      for each a in priara
         ffra.WriteLn(a)
         'ffra.WriteLn("<BODY onLoad=""document.form01." & namtmp(0) & ".focus()"">")
      next
   end if
   '=== select buttons
   if cc01<>0 then
      '=== buttons var only if select is active
      if cc01<>0 then
         for yy=0 to ymax
         next
      end if
   end if
   '=== header
   if hh=1 then
      htmtab = ttext & "<b><table width=""100%"" BORDERCOLOR=""black"" class=MsoTableGrid border=1 CELLSPACING=0 cellpadding=2 style='border-collapse:collapse;border:none'>"
      htmtab = htmtab & "<CAPTION></CAPTION><span style='color:purple'>" & vbcrlf
      '=== tableau html
      htmtab = htmtab & "<TR>"
      i=0
      For Each a In aaratit
         '=== columns names
         if cc01<>0 then if i=0 then htmtab = htmtab & "<td><p>Select</td>"
         htmtab = htmtab & "<td><p>" & Trim(a) & "</td>"
         i=i+1
         if dimnum=1 then exit for
      Next
         htmtab = htmtab & "</tr>"
   end if
   'ara01(x,y) = "ligne1 col1"
   'ara01(0,0) = "ligne1 col1"
   'ara01(0,1) = "ligne2 col1"
   'ara01(1,0) = "ligne1 col2"
   'ara01(1,1) = "ligne2 col2"
   '=== middle
   if mm=1 then
      For xx = 0 To xmax
         if dimnum=2 then
            For yy = 0 To ymax
               'If IsNull(myarray(xx, yy)) Then myarray(xx, yy) = ""
               if yy=0 and cc01<>0 then
                  htmtab = htmtab & "<input type=""button"" name=""" & "but" & trim(cstr(yy+1)) & """ value=""" & "Select " & yy+1 & """"
                  htmtab = htmtab &  " style=""background-color: #" & "cccccc" & "; color: #000000;""><br>"
                  htmtab = htmtab & "</td>"
               end if
            htmtab = htmtab & "<td><p>" & aara(yy, xx) & "</td>"
            Next
         else
         '=== there is only 1 column
            htmtab = htmtab & "<input type=""button"" name=""" & "but" & trim(cstr(xx+1)) & """ value=""" & "Select " & xx+1 & """"
            htmtab = htmtab & "<td><p>" & aara(xx) & "</td>"
         end if
         htmtab = htmtab & "</tr>" & vbcrlf
      Next
   end if
   '=== footer
   if ff=1 then
      htmtab = htmtab & "</table></span></b><br>"
   end if
   htmtab = htmtab & "</form>"
   ffra.WriteLn(htmtab)
   '=== reload (will not reload if we are in middle of a muliple elements/query table)
   if rr=1 then
      ffra.location.reload(true)
      call oieready
   end if
   if mm=1 then
      For xx = 0 To xmax
         if dimnum=2 then
            For yy = 0 To ymax
                  fmid.forms(0).elements("but" & trim(cstr(yy+1))).onclick = getref("buttonmid")
               end if
            Next
         else
            fmid.forms(0).elements("but" & trim(cstr(xx+1))).onclick = getref("buttonmid")
         end if
      Next
   end if
   'next
end function
sub oieready()
      wscript.sleep 100
   loop
   Do While (oIE.Busy)
      wscript.sleep 100
   Loop
end sub
Comments (5)
interrnet explorer was crashing sometimes, when i was sending a clear frame command and internet explorer was reporting "not busy", but the frame was busy
here is the code:
   cc=""
   for each aa in aara
      'cc = cc & "Do While (oIE.Busy)" & vbcrlf
      'cc = cc & "   wscript.sleep 200" & vbcrlf
      'cc = cc & "Loop" & vbcrlf
      'cc = cc & "Do While oie.readystate<>4" & vbcrlf
      'cc = cc & aa & ".location.reload(true)" & vbcrlf
      'cc = cc & aa & ".WriteLn(""&nbsp;"")" & vbcrlf
      'cc = cc & "Do until " & aa & ".ReadyState = ""Terminé"" or " & aa & ".ReadyState = ""Complete""" & vbcrlf
      '•uninitialized - Has not started loading yet
      '•loading - Is loading
      '•interactive - Has loaded enough and the user can interact with it
      '•complete - Fully loaded
      if aa = "flef" then
         aa = lcase(flef.readystate)
         do until aa="complete" or aa="terminé" or aa="interactive"
            fil02.writeline "*********************************** readystate of flef: " & aa
            wscript.sleep 100
         loop
         flef.WriteLn("&nbsp;")
            wscript.sleep 100
         loop
         flef.location.reload(true)
            wscript.sleep 100
         loop
      end if
      if aa = "fmid" then
         aa = lcase(fmid.readystate)
            fil02.writeline "*********************************** readystate of fmid: " & aa
            wscript.sleep 100
         loop
         fmid.WriteLn("&nbsp;")
            wscript.sleep 100
         loop
            wscript.sleep 100
         loop
         if logall=q then fil02.writeline "mid frame cleared----------- ccc -----------"
      end if
      if aa = "fbot" then
         aa = lcase(fbot.readystate)
            fil02.writeline "*****************111****************** readystate of fbot: " & aa
            wscript.sleep 100
         loop
         fbot.WriteLn("&nbsp;")
            fil02.writeline "*****************222****************** readystate of fbot: " & aa
            wscript.sleep 100
         loop
         fbot.location.reload(true)
            fil02.writeline "*****************333****************** readystate of fbot: " & aa
            wscript.sleep 100
         loop
      end if
   next
   'execute cc
'next
   resbutlefstr = ""
   resbutmidstr = ""
   resbutbotstr = ""
   reskeylef = 0
   reskeymid = 0
   reskeybot = 0
end function
i recently added images, and a frame move and image zoon, when the mouse pass over the image
(in a few lines of java script)
i recently added graphics buttons, as a ccs style
i do nto know if we can link blog here but here it is:
http://wildboy85.blogspot.com/
i am converting all my web interface code from wsh (windows host script) to visual basic 2010
so all the techniques here have been converted
1 using internet explorer as web interface in vb.net
2 using database mdb
3 handling key event
4 handling click event
With the arrival of internet explorer 10 my web interface was displaying empty frames
Here is the correction you must apply to 3 objects:
Just search for this line:
It's when the frames objects are created
Replace with the code below with a condition if it's explorer 10 or before
'=== get version
if fileversion2 = "10" then
else
end if
