Simple way to show multi column data in SSRS (Horizontally or Vertically)
rshqProgrammer
Updated:
Hi
When we create a simple report in SSRS data show in one column. (To start using SSRS see this link Creating a Report Server Project ).
In this article we want create a report to show data in multi-column (Horizontally or Vertically).
For example: if we have one table with name [Table1] and one field  [No] and inserted number from 1 to 100  in this  table.
If we create a simple report in SSRS and show data on it
we see this report
P1
but we want see multi-column  report like this
P2
How can we do that?
1. We create a report using BIDS (used in this article ) or other tools
after that  delete all object on it to see this picture.
P3
 2.  Put a Matrix on report like this (Matrix is in {ToolBox} under {Report Items}).
P4
In bottom we see [RowGroup] under Row Groups and [ColumnGroup] under Column Groups.
3. RightClick on  [RowGroup] and click Group Properties.
P5
4.Click {Fx} to appear Expression window then insert this expression in top textbox
=ceiling(rownumber(nothing) / 3)
P6
Then click two OK.
5.  Do  stage 3 to 4 for  [ColumnGroup]  but only in expression window type this
=ceiling(rownumber(nothing) mod 3)
Then click two OK.
Number 3 in above formulas show count of column in report result.If we need more column can change it in  above formulas.
6.Now RightClick on Data part of Matrix and select {TextBox Properties}
P7
 It will be open a new window. we fill combobox with field [No] which has been defined in Table1.
P8
Click OK.
7.Now click preview to see
P9
8.If we have more than one field in table we can use {InsertGroupRight}
P10
9.If we want show result vertically swap two formulas together.(In stage 4 use this formula
=ceiling(rownumber(nothing) mod 3) and in stage 5 use this =ceiling(rownumber(nothing) / 3) )
I hope this article be useful.
7
rshqProgrammer
Comments (6)
rshqProgrammer
Hi
 Thank you for the tips.
Jim HornSQL Server Data Dude
Most Valuable Expert 2013
Author of the Year 2015
Nicely done with the images.  Voted Yes.
The reversing of the 2 formulas does not work. It gives 3 rows of data and several columns. How would I force it to give me 8 columns where the data flows down instead of across?
Thank you. Works great.
Rog DSQL Developer / Web Development / Business Analysis
Was curious as this works well in the Preview mode, but no so good in the rendering in SSRS.
I mean the columns work, but not the sorting order.  Any help with this?
I sorted the data coming from the dataset, but that order is great in the preview screen, but
is now handled the same on the SSRS rendering.
Rog
View More
