So, you're experiencing issues on your network and you've decided that you need to perform some tests to determine whether your cabling is good. You're likely thinking that you may need to spend money which you probably don't have on hiring/purchasing a cable test tool, or even a cabling tech if you're not sure where the issue lies. That can be expensive, especially if you have to get someone to site quickly to help diagnose an issue.
Did you know that if you have a Cisco switch-based network you may well have a cable-test function already to hand?
Pretty-much any Enterprise-level Cisco switch made since the 2960 family includes a feature called the TDR test, and even some switches before (such as the 3560G) support this function. It's only available for copper-based connections though as it's only a TDR and not an OTDR, so you can't test fiber-based links using this functionality.
This test will enable you to verify the length of a cable right from the switch to the other end, using the TDR (time-domain reflectometer) function. This is essential in diagnosing faults as a break in the cable can be easily identified on a single wire within the cable, as well as shorts and crossed-pairs.
To use this test, simply issue the following command in privileged exec mode...
(substitute the
gi0/1 interface with whichever one you need to test)
Note: Cisco recommend performing the test with the far-end device disconnected, however you can test with devices connected and on newer switches the traffic will remain uninterrupted. Older switches may disrupt traffic-flow momentarily during the test.
If your switch supports the command you'll see something similar to the following:
TDR test started on interface gi0/1
After a few seconds you will be able to view the result of the TDR test using the following...
This should produce something similar to the following output:
TestSwitch#show cable-diagnostics tdr interface gi0/1 TDR test last run on: Dec 14 20:00:10
Interface Speed Local pair Pair length Remote pair Pair status --------- ------ ---------- ----------- ----------- ----------- Gi0/1 auto Pair A 15 +/- 2 m N/A Open Pair B 14 +/- 2 m N/A Open Pair C 9 +/- 2 m N/A Open Pair D 14 +/- 2 m N/A Open
To decipher what this means you should look particularly at the Pair Length and Pair Status fields. These will quickly show you if there's an issue with your cable, and what.
As you can see in the example above, Pair C has a shorter length than the other pairs, so this indicates a break in the cable somewhere as it's shorter than the others and the Pair Status is
Open. The result is very accurate, so you can be sure that the break is ~9m from the switch. The +/- figure of 2m is the tolerance, so the break could be anywhere between 7m and 11m in theory.
This will help you determine not only how far away the break is, but also which cable is faulty. For example, if you have a 2m patch cable between the switch and patch-panel, and a 2m cable at the other end of the cable-run at the device-end (attached to the far-end patch-panel) you can likely assume that the break is not in either of your patch cables. Therefore you can deduce that the structured cabling between patch-panels is likely faulty - approximately 3m from the end of the cable).
The following values are typically reported for Pair Status, depending on the result of the test or fault, and the hardware you're running the test on:
Normal—The pair of wires is properly connected.
Not completed—The test is running and is not completed.
Not supported—The interface does not support TDR.
Open—The pair of wires is open.
Shorted—The pair of wires is shorted.
ImpedanceMis—The impedance is mismatched.
Short/Impedance Mismatched—The impedance mismatched or the cable is short.
InProgress—The diagnostic test is in progress
If you're testing using 10/100 interfaces you will see N/A in the length field for pairs C and D as they're not used for communication. This is somewhat of a caveat in my opinion as those pairs can be used for PoE, but in terms of Ethernet or FastEthernet they're not required.
Obviously this isn't an absolute alternative to a proper cable diagnostic tool such as a Fluke, but it is a simple and free way to help find faults which can be easily fixed or worked-around quickly.
Comments (1)
