Execution-focused Full Stack Developer and DevOps Engineer with over 10 years experience in all facets of the software development lifecycle
Browse All Articles > Compiling a custom FreeBSD kernel with Packet Filtering (PF) and Alternate Queuing (ALTQ)
FreeBSD on EC2
FreeBSD is a robust Unix-like operating system that has been around for many years. FreeBSD is available on Amazon EC2 through Amazon Machine Images (AMIs) provided by FreeBSD developer and security officer Colin Percival. Percival’s list of AMIs for multiple versions of FreeBSD and Amazon regions can be found here. The AMIs come installed with the GENERIC kernel, plus options to enable XEN support (XEN support allows FreeBSD to run on EC2).
However, the GENERIC kernel does not include support for PF (Packet Filter) with Alternative Queuing (ALTQ). PF is the packet filtering system ported from OpenBSD. It provides a system for filtering, normalizing, and conditioning TCP/IP traffic. PF is also capable of doing Network Address Translation (NAT). It’s an alternative to using IPFW or IPFILTER in FreeBSD. ALTQ provides Quality of Service (QoS) mechanisms, such as the capability for bandwidth control and packet prioritization. This article will explain how to configure, build, and install a custom kernel with PF+ALTQ built-in.
Note that this article focuses on FreeBSD on EC2. While you should be able to follow these steps for other architectures, keep in mind that you may have to tweak a few things. For example, if you see references to ‘amd64’, you may have to alter commands to fit your own architecture.
Update FreeBSD Source
The FreeBSD EC2 AMIs come with the FreeBSD source already installed under /usr/src. You will want to make sure that you’re up to date with security patches. We will be updating the system against FreeBSD's RELEASE branch. The RELEASE branch is a stable branch of FreeBSD that recieves crictical security updates.
This configuration basically includes everything from the GENERIC kernel, plus all of the devices and options needed for adding in PF and ALTQ. The "ident" tag allows us to give our kernel a custom name. If you want to name your kernel something else, you can replace CUSTOM with whatever you want -- just make sure to change the filename as well.
Build and Install Kernel
We’re now ready to build and install our custom kernel. Under your /usr/src directory, run the following:
If you named your kernel something other than "CUSTOM", you will need to modify the command accordingly. It will take a while to build and install the kernel. The amount of time it takes depends on the horsepower of your instance. For reference, on an m3.large EC2 instance (2 virtual CPUs - Intel Xeon E5-2670 v2 Processors) with SSD-backed storage, the whole process took about 25 minutes. Once the process is done, reboot your system:
Your FreeBSD instance now has the full feature-set of PF and ALTQ available to you. The FreeBSD PF Documention page provides everything you need to get going with PF. Some basics for getting it going:
1. Add the following to /etc/rc.conf:
