<cfdocument format="PDF" localURL="yes">
<cfoutput query="myquery">
<!--- Section 1 --->
<cfdocumentsection name="Section1-#myquery.id#">
<cfdocumentitem type="header">
<h1>This is a Header</h1>
</cfdocumentitem>
<table align="center"><tr><td>counter my query</td></tr></table>
<cfdocumentitem type="footer">
<h1>Page #cfdocument.currentPageNumber# of #cfdocument.totalPageCount#</h1>
</cfdocumentitem>
</cfdocumentsection>
<cfdocumentsection name="Section2-#myquery.id#">
<h1>2nd header</h1>
</cfdocumentitem>
<table align="center"><tr><td>counter my query 2</td></tr></table>
</cfdocumentitem>
</cfoutput>
</cfdocument>
When this code is run, it will render perfectly, But if we have a scenario where your cfoutput query="myquery" is empty and returning no results, we will get the cfdocument has no body error. <cfdocument format="PDF" localURL="yes">
<cfif myquery.recordcount>
</cfdocumentitem>
</cfdocumentitem>
<h1>2nd header</h1>
</cfdocumentitem>
</cfdocumentitem>
</cfoutput>
<cfelse>
<br>
</cfif>
</cfdocument>
This will render PDF and create a blank PDF Page because the query is returning null records and that goes into the clause where a tag is used. This will tell cfdocument that it has some contents, so it will not break and it will show it as an empty PDF. This is still vague, so we use another approach.<cfif myquery.recordcount>
</cfdocumentitem>
</cfdocumentitem>
<h1>2nd header</h1>
</cfdocumentitem>
</cfdocumentitem>
</cfoutput>
</cfdocument>
<cfelse>
<div align="center">Query is Empty, So PDF cannot be Generated.
</cfif>
