create table MasterTable (masterId int identity, masterType varchar(32))
create table DetailsTable (detailId int identity, detailMaster int, detailType varchar(32), detailValue varchar(32))
insert into MasterTable (masterType) values ('original')
insert into DetailsTable (detailMaster, detailType, detailValue)
select masterId, masterType, CHAR(ASCII('A')+masterId-1) from MasterTable
insert into DetailsTable (detailMaster, detailType, detailValue) values (3, 'original', 'D')
insert into DetailsTable (detailMaster, detailType, detailValue) values (null, 'random', 'R')
insert into MasterTable values ('masteronly')
select * from MasterTable
select * from DetailsTable
declare @temporaryValues table (
newMasterId int
,oldMasterId int
merge MasterTable as target
using (
select
detailMaster as oldMasterId
,row_number() over(partition by detailMaster order by detailMaster) as rownum
from DetailsTable
where detailType = 'original'
) as source (
oldMasterId
,rownum
on (0=1)
when not matched and rownum=1 then
insert (masterType)
values ('duplicate')
output
inserted.masterId
,source.oldMasterId
into @temporaryValues
select temps.newMasterId, 'duplicate', originals.detailValue
from DetailsTable originals
inner join @temporaryValues temps
on originals.detailMaster = temps.oldMasterId
and originals.detailType = 'original'
