Fixing "output buffer too small" issue for ffmpeg with libmp3lame
This is the error message I got
[libmp3lame @ 0x95c0090]lame: output buffer too small (buffer index: 9404, free bytes: 388)
Audio encoding failed
Error caused by incompatible libmp3lame 3.98-2 with ffmpeg
I've googled this error message and found out sometimes it attaches this note "can be treated with downgrade libmp3lame to version 3.97 or 3.98"
Thing is, in most updated distros' repositories, you will not find these 'outdated' versions.
I've done it on CentOS 5.4, it should not be too far away from this explination in any other distro.
1. we remove version 3.98.2
rpm -e --nodeps lame
rpm -e --nodeps lame-devel
2. download the required version of libmp3lame
wget http://downloads.sourceforge.net/lame/lame-398.tar.gz
3. Extract:
tar xvvzf lame-398.tar.gz
4. Go into the extracted directory
cd lame-398
5. and build!
./configure
make
make install
We're almost done now, but if you'll try you'll get the following error message
ffmpeg: error while loading shared libraries: libmp3lame.so.0: cannot open shared object file: No such file or directory
let's fix up the proper links for the new library;
for 32bit OS:
cd /usr/local/lib
ln -s /usr/local/lib/libmp3lame.so.0.0.0 /usr/lib/libmp3lame.so.0
and for 64bit OS:
cd /usr/local/lib
ln -s /usr/local/lib/libmp3lame.so.0.0.0 /usr/lib64/libmp3lame.so.0
And voila!
