var req = new Request({
url: demo_path + ‘data.txt’,
onSuccess: function(txt){
$(‘result’).set(‘text’, txt);
// Our request will most likely succeed, but just in case, we’ll add an
// onFailure method which will let the user know what happened.
onFailure: function(){
$(‘result’).set(‘text’, ‘The request failed.’);
req.send();
var req = new Request.HTML({url:demo_path+’data.html’,
onSuccess: function(html) {
//Clear the text currently inside the results div.
$(‘result’).set(‘text’, ”);
//Inject the new DOM elements into the results div.
$(‘result’).adopt(html);
//Our request will most likely succeed, but just in case, we’ll add an
//onFailure method which will let the user know what happened.
onFailure: function() {
req.send();
update:$(‘id_of_element’);
//when the dom is ready
window.addEvent(‘domready’,function() {
//smooooooth scrolling enabled
//new SmoothScroll({ options }, window);
new SmoothScroll({ duration:700 }, window); //700 define the duration in mili second to go to the portion of the //page
