How to FTP with Oracle PL/SQL
Sean StuberDatabase Developer & Administrator
Updated:
Sometimes you need to get data from a server into your database, or from your database into a remote server.  There are many ways this can be done such as  SOAP or REST web service calls, database links,  pipes,  or external tools.  Another option, illustrated here,  is to use the internet standard File Transfer Protocol (FTP).
In the attached code snippets I have included a PL/SQL package that implements most of the FTP protocol, including local/remote file transfer in ascii and binary formats, remote directory navigation and manipulation and some modified features for local actions.  Directories in Oracle are independent objects and do not have a hierarchy, even though the underlying filesystem paths might.  Also, data can be sent directly to and from the database without the need for a local file.
Sample Usage
Many readers won't care how any of the functionality is implemented; if it works, that's good enough.  So, I'll begin by skipping straight to the meat and show how you might use this package to retrieve a remote file and display its contents.  This use case is embedded in the source comments for reference.
DECLARE
                          v_conn sdsftp.connection;
                      BEGIN
                          sdsftp.clear_log;
                          sdsftp.set_log_options(1);
                          v_conn := sdsftp.open(:HOST, :username, :pwd);
                          DBMS_OUTPUT.
                           put_line(
                          DBMS_OUTPUT.put_line(sdsftp.get_clob(v_conn, 'test.txt'));
                          DBMS_OUTPUT.
                           put_line(
                          sdsftp.close(v_conn);
                      EXCEPTION
                          WHEN OTHERS
                          THEN
                              RAISE;
                      END;
Explanation of Example
In general the API works much like you would expect a set of file operations in most languages to behave.  Declare a handle, open, read/write, close.
As with any pl/sql block we have to declare our variables first.  The connection type is a wrapper for the Oracle UTL_TCP connection with some extra fields included.
DECLARE
Next we start the code and initialize the logging.  Option 1 directs all logs to the DBMS_OUTPUT buffer.
BEGIN
                          sdsftp.clear_log;
After setting up the logs, open a connection to the remote host,  I have bound variables here to prompt for the required values. The connection will be to the default FTP port 21, but this can be changed with the optional p_port parameter. Other options include setting local and remote starting directories and transfer options (ASCII vs Binary)
Then, a one-line workhorse. Get and display a remote file called "test.txt".  Note, the function is "get_clob".  No file is created locally, not even temporarily in this process. The contents of test.txt  are read directly into a temporary CLOB variable.  That CLOB is then returned from the function.  Thus turning the remote file into a local string variable; which is then displayed.
And, finally, having read the file we close the connection.
If there were any errors above, cleanup our connection and then throw/raise the error.
EXCEPTION
                          WHEN OTHERS
                          THEN
                              RAISE;
                      END;
Overview of the API and the FTP protocol
Next, I'd like to go into more detail about the procedures and functions exposed and how they relate to and implement the FTP protocol.   FTP is a fairly simple protocol.  Everything is a command-reply pair with numeric codes on each reply indicating meaning.  The actual data transfers (in either direction) add a little more complexity since a secondary connection is opened with semi-independent communication on it from the main command port.  That complexity is encapsulated within a family of get_xxx and put_xxx routines.  I'll list the procedures and functions exposed in the package and explain how the underlying FTP commands are invoked.
Connectivity and communication
open
All FTP sessions will start with the OPEN procedure or function, they are equivalent, both forms are provided for programmatic convenience and preference.  Under the hood, the function version simply calls the procedural version.  The session begins with a telnet connect to the remote server and assuming a good connection will then issue the FTP commands USER and PASS, and as you might expect these log you in with your username and password.  Some servers may request a secondary password or "account info".  If this is requested, the open procedure will acknowledge with the appropriate ACCT command.  Note, you must provide these credentials, including the account info (if needed) when invoking the open routine.
close
Simply disconnects from the FTP server with the QUIT command and cleans up the TCP telnet connection to the server.
send_ftp_command
This is the engine behind all of the other routines that communicate with the remote server. Despite being critical, its functionality is actually quite simple.  First it writes the command to the remote TCP port along with any arguments.  It reads whatever reply returned from the server and, if prompted for account information as described in the login process , will automatically send the ACCT command and appropriate information supplied with the OPEN.
read_reply
Each FTP command should expect a reply, so every invocation of send_ftp_command automatically calls read_reply to get the response.  All FTP responses begin with a 3 digit code and then possibly some text including multi-line responses.  Read_reply handles all of these and raises exceptions for codes in the 4xx or 5xx series as these indicate Transient and Permanent errors respectively from the remote server.
get_last_reply
Returns the last reply from the remote FTP server, including numeric code and any associated text.  Multi-line replies are returned as a single value with embedded carriage-returns and line-feeds.
Logging
set_log_options and get_log_options
There are 4 logging options which may be used in combination as bit masks
c_log_off (0)
If logging is set to 0 then all logging is turned off
c_log_dbms_ouptut (1)
When logging bit-1 is set then all messages are written to the dbms_output buffer. When using this option remember to enable output and also remember the buffer is not displayed until processing is over.  If you want a more real-time response, consider adding either or both of the next options.
c_log_rolling_buffer (2)
When logging bit-2 is set then all messages are written to a 32K buffer (varchar2 type).  When the buffer fills, the oldest messages are wiped out from the beginning and new are appended to the end.
c_log_client_info (4)
When logging bit-3 is set then the first 64 bytes of each message is written to the user's session client_info column of v$session.  This is a non-transactional update.  So it's seen immediately regardless of any data manipulation or commits/rollbacks that may have occurred.
clear_log
The rolling buffer will be set to NULL and, if  client_info logging is enabled, it will be set to NULL as well.  The dbms_output buffer is not affected by this procedure.
get_log_text
Returns the contents of the rolling buffer.  The type of the rolling buffer is VARCHAR2(32767) so it's a legal string for use in PL/SQL but may be too large to be used in a SQL statement.  If so, it can be split into smaller, consumable chunks with SUBSTR
write_to_log
Just as the name implies, the procedure writes a message to any and all active logging options (see above.)
set_verbose and get_verbose
The verbose option doesn't correspond to an FTP command, it's internal to this package and when TRUE, increases the level of information written to the logs.  If logging is disabled then verbose mode has no effect.  Verbose is OFF by default.
Remote operations
The following commands call send_ftp_command to operate on files or directories of the remote FTP server.  With the exception of a rename, each of these routines maps to exactly one FTP command. These commands have no affect on local files, directories or data.  Paths given in these may be absolute or relative to the current working directory.
remote_rename
Rename a file on the remote server.  The exposed API is a single command but inside the procedure, the FTP protocol requires 2 calls to send_ftp_command:  RNFR (ReName FRom) and RNTO (ReName TO).   The rename can include new paths causing the remote file to be moved to a new directory in addition to changing the file name.
remote_delete_file
Delete a file on the remote server using ftp command  DELE
remote_create_directory
Create a new directory on the remote server with ftp command  MKD.
remote_delete_directory
Delete a directory on the remote server with ftp command  RMD.
remote_cd
Change your current working directory on the remote server with ftp command CWD
remote_cdup
Change your current working directory to the parent of the current directory with ftp command CDUP
remote_pwd
Rather than manipulating anything on the remote server, this function returns the absolute path of your current working directory.
Local operations
The following routines work a little differently than a typical FTP client because the Oracle database is our client and the database doesn't have normal file sytems.  It has directory objects that sit on top of the underlying operating system file structure.  As such, there are no paths  absolute or relative.  Each directory is its own entity, even if the underlying OS filesystem has a hierarchy.  Since the directories are database objects which already have corresponding SQL commands for their DDL operations, this package doesn't duplicate that functionality.  So, there are only two local operations compared to the greater remote operations.  Directory privileges are not checked as part of these routines.  Privileges to read from or write to a directory is only determined at the time of those operations.
local_cd
Change your current local directory
local_pwd
Return the name of your current local directory
File and Data Transfers
The data transfers for the pl/sql client are similar to those you might find in other clients: gets and puts with different transfer methods.   Two signficant differences.  One, there is no facility for multi-file transfers in either direction. Two, as illustrated in the use case above, a local file isn't necessary, the local data can come directly from or write directly to CLOB and BLOB objects within the database.
set_transfer_method
3 different transfer methods are available.  ASCII, EBCDIC, and IMAGE.  These may be chosen by name, abbreviation (A,E,I) or the keywords BINARY (same as IMAGE) or DEFAULT (constant currently set to ASCII).  All input variations are converted to the standard strings and passed with the TYPE command.  FTP options for NONPRINT, TELNET and CARRIAGE CONTROL may be passed as optional 3rd parameters but do not have any effect in the current verions of the code.
put_clob and put_blob
These two procedures copy a local LOB value to the remote system and write it as a file with the FTP command STOR.  The CLOB version can be sent with the current transfer method or the optional 4th parameter can change the current method as part of the transfer.  The BLOB procedure will, by default change to the IMAGE (binary) transfer method if it's not currently selected and then restore the current method afterward.  The optional 4th parameter can override this switch and force the current transfer method to be used.
get_clob and get_blob
Each of the get options is exposed in both procedure and function versions, but perform the same with the FTP command RETR.  The function verions simply invoke the corresponding procedure and return the OUT parameter as the function value.  Since LOBs don't have names, unlike a file get, you only need to specify the remote file name, the LOB pointer determines the destination.   Like the put functions above, the CLOB routines can change transfer methods and the BLOB will automatically switch to IMAGE (binary) transfer unless forced to use the current method.
put_file and get_file
These are each overloaded to 3 versions, depending whether you want to specify the remote file path, or simply read/write the local file with the same name to the current directory.  And whether you want to specify a local directory other than the current directory.  By default, the current transfer method will be used, but it can be changed as part of the transfer with the last parameter of each version (optional in all of them).  As with the LOB verions,  put actions are an FTP STOR, get actions are with FTP RETR.
get_file_list
This routine comes in procedure and function form but the functionality is equivalent.  Given a path and including optional filename wildcards, these will return the list of files in a collection.  By default all information about the files will be returned but if the p_names_only parameter is TRUE only the names will be returned.  These options correspond to the FTP commands LIST (false) and NLST (true).  Note the FTP RFC does not specify content or format of the data returned by these commands, so all information
is returned simply as a collection of strings.  Once you know the format of the data for the particular server you are working with you can write a parsing routine to extract the pieces of information you need; but be sure to verify the format anytime you change servers.
Additional Example
This example shows how to use the get_file_list function and iterate through the resulting collection
DECLARE
                          v_list sdsftp.file_list;
                      BEGIN
                          sdsftp.clear_log;
                          sdsftp.set_log_options(0);
                          v_list := sdsftp.get_file_list(v_conn, '/', false);
                          FOR i IN v_list.FIRST .. v_list.LAST
                          LOOP
                              DBMS_OUTPUT.put_line(v_list(i));
                          END LOOP;
                      EXCEPTION
                          WHEN OTHERS
                          THEN
                              RAISE;
                      END;
Reference and Source Code
For more information about FTP commands and reply codes, see "RFC 959 - File Transfer Protocol" ( http://www.faqs.org/rfcs/rfc959.html )
I hope you find the attached package code both useful and interesting.  It was fun to write.  If you need more complete support of the FTP protocol, you can try searching for other pl/sql implementations, or java stored procedures with standard FTP libraries may be a better bet.
CREATE OR REPLACE PACKAGE sdsftp
                      AS
                          --                   (0 o)
                          ---------------0000--(_)--0000---------------
                          --  Sean D. Stuber
                          --  sean.stuber@gmail.com
                          --             oooO      Oooo
                          --              \_)     (_/
                          -- Only Passive data transfers are supported
                          -- Active connections aren't possible because UTL_TCP, as of 11gR2, doesn't support
                          -- the local_host and local_port parameters and fields of the open procedure and record
                          --   Sample usage
                          --DECLARE
                          --    v_conn   sdsftp.connection;
                          --BEGIN
                          --    sdsftp.clear_log;
                          --    sdsftp.set_log_options(1);
                          --    v_conn   := sdsftp.open(:HOST, :username, :pwd);
                          --    DBMS_OUTPUT.put_line(
                          --    DBMS_OUTPUT.put_line(sdsftp.get_clob(v_conn, 'test.txt'));
                          --    sdsftp.close(v_conn);
                          --EXCEPTION
                          --    WHEN OTHERS THEN
                          --        RAISE;
                          --END;
                          TYPE connection IS RECORD
                              tcp               UTL_TCP.connection,
                              account_info      VARCHAR2(1000),
                              transfer_method   VARCHAR2(1),
                              transfer_option   VARCHAR2(1),
                              local_directory   VARCHAR2(30),
                              last_reply        VARCHAR2(32767)
                          TYPE file_list IS TABLE OF VARCHAR2(32767)
                                                INDEX BY BINARY_INTEGER;
                          c_default_ftp_control_port   CONSTANT INTEGER := 21;
                          c_default_transfer_method    CONSTANT VARCHAR2(10) := 'ASCII';
                          c_default_verbose            CONSTANT BOOLEAN := FALSE;
                          c_log_off                    CONSTANT INTEGER := 0;
                          c_log_dbms_output            CONSTANT INTEGER := 1;
                          c_log_rolling_buffer         CONSTANT INTEGER := 2;
                          c_log_client_info            CONSTANT INTEGER := 4;
                          PROCEDURE open(p_server             IN     VARCHAR2,
                                         p_username           IN     VARCHAR2,
                                         p_password           IN     VARCHAR2,
                                         p_connection            OUT connection,
                                         p_local_directory    IN     VARCHAR2 DEFAULT NULL,
                                         p_remote_directory   IN     VARCHAR2 DEFAULT NULL,
                                         p_trans_method       IN     VARCHAR2 DEFAULT c_default_transfer_method,
                                         p_timeout            IN     INTEGER DEFAULT NULL,
                                         p_port               IN     INTEGER DEFAULT c_default_ftp_control_port,
                                         p_account_info       IN     VARCHAR2 DEFAULT NULL
                          FUNCTION open(p_server             IN VARCHAR2,
                              RETURN connection;
                          PROCEDURE close(p_connection IN OUT NOCOPY connection);
                          PROCEDURE set_verbose(p_verbose IN BOOLEAN);
                          FUNCTION get_verbose
                              RETURN BOOLEAN;
                          PROCEDURE write_to_log(v_text IN VARCHAR2, p_verbose IN BOOLEAN DEFAULT FALSE);
                          PROCEDURE set_log_options(p_log_options IN INTEGER);
                          FUNCTION get_log_options
                              RETURN INTEGER;
                          PROCEDURE clear_log;
                          FUNCTION get_log_text
                              RETURN VARCHAR2;
                          FUNCTION get_last_reply(p_connection IN OUT NOCOPY connection)
                              RETURN VARCHAR2;
                          PROCEDURE send_ftp_command(p_connection     IN OUT NOCOPY connection,
                                                     p_command        IN            VARCHAR2,
                                                     p_arguments      IN            VARCHAR2 DEFAULT NULL,
                          PROCEDURE read_reply(p_connection IN OUT NOCOPY connection);
                          PROCEDURE remote_rename(p_connection   IN OUT NOCOPY connection,
                                                  p_old_name     IN            VARCHAR2,
                                                  p_new_name     IN            VARCHAR2
                          PROCEDURE remote_delete_file(p_connection IN OUT NOCOPY connection, p_file IN VARCHAR2);
                          PROCEDURE remote_create_directory(p_connection   IN OUT NOCOPY connection,
                                                            p_directory    IN            VARCHAR2
                          PROCEDURE remote_delete_directory(p_connection   IN OUT NOCOPY connection,
                          PROCEDURE set_transfer_method(p_connection        IN OUT NOCOPY connection,
                                                        p_transfer_method   IN            VARCHAR2,
                                                        p_option            IN            VARCHAR2 DEFAULT NULL
                          FUNCTION get_transfer_method(p_connection IN OUT NOCOPY connection)
                              RETURN VARCHAR2;
                          PROCEDURE local_cd(p_connection IN OUT NOCOPY connection, p_directory IN VARCHAR2);
                          FUNCTION local_pwd(p_connection IN OUT NOCOPY connection)
                              RETURN VARCHAR2;
                          PROCEDURE remote_cd(p_connection IN OUT NOCOPY connection, p_directory IN VARCHAR2);
                          PROCEDURE remote_cdup(p_connection IN OUT NOCOPY connection);
                          FUNCTION remote_pwd(p_connection IN OUT NOCOPY connection)
                              RETURN VARCHAR2;
                          PROCEDURE put_clob(p_connection     IN OUT NOCOPY connection,
                                             p_local_clob     IN OUT NOCOPY CLOB,
                                             p_remote_file    IN            VARCHAR2,
                                             p_trans_method   IN            VARCHAR2 DEFAULT NULL
                          PROCEDURE put_blob(p_connection     IN OUT NOCOPY connection,
                                             p_local_blob     IN OUT NOCOPY BLOB,
                                             p_force_binary   IN            BOOLEAN DEFAULT TRUE
                          PROCEDURE get_clob(p_connection     IN OUT NOCOPY connection,
                          FUNCTION get_clob(p_connection     IN OUT NOCOPY connection,
                              RETURN CLOB;
                          PROCEDURE get_blob(p_connection     IN OUT NOCOPY connection,
                          FUNCTION get_blob(p_connection     IN OUT NOCOPY connection,
                              RETURN BLOB;
                          PROCEDURE put_file(p_connection        IN OUT NOCOPY connection,
                                             p_local_directory   IN            VARCHAR2,
                                             p_local_file        IN            VARCHAR2,
                                             p_local_file     IN            UTL_FILE.file_type,
                          PROCEDURE get_file(p_connection        IN OUT NOCOPY connection,
                                             p_local_file     IN OUT NOCOPY UTL_FILE.file_type,
                          PROCEDURE get_file_list(p_connection     IN OUT NOCOPY connection,
                                                  p_remote_path    IN            VARCHAR2,
                                                  p_list              OUT        file_list,
                                                  p_names_only     IN            BOOLEAN DEFAULT FALSE,
                                                  p_trans_method   IN            VARCHAR2 DEFAULT 'ASCII'
                          FUNCTION get_file_list(p_connection     IN OUT NOCOPY connection,
                              RETURN file_list;
                      END sdsftp;
CREATE OR REPLACE PACKAGE BODY sdsftp
                      AS
                          --                   (0 o)
                          --  Sean D. Stuber
                          --             oooO      Oooo
                          --              \_)     (_/
                          -- 2010-09-16 Bug Fix:     Buffer length in binary transfers set to null, meaning all.
                          --            Bug Fix:     Files are closed in routines that generate their own file handle.
                          --                         Routines that receive a file handle are left open.
                          --            Cosmetic:    Minor formatting and variable name changes.
                          -- 2011-01-18 Enhancement: Added support for listing of remote directories
                          c_crlf                    CONSTANT CHAR(2) := CHR(13) || CHR(10);
                          -- Currently unused, would be used with the PORT command to do transfers
                          -- without passive mode.
                          c_default_ftp_data_port   CONSTANT INTEGER := c_default_ftp_control_port - 1;
                          -- Per RFC 959, if account info (ACCT) is requested then a 332 code
                          -- should be returned from the PASS command instead of a Positive Completion
                          c_ftp_request_acct        CONSTANT INTEGER := 332;
                          g_log_options                      INTEGER := c_log_dbms_output;
                          g_log_text                         VARCHAR2(32767) := NULL;
                          g_verbose                          BOOLEAN := c_default_verbose;
                          -- Parse an FTP reply string, extract the numeric code
                          FUNCTION reply_code(p_reply_text IN VARCHAR2)
                              RETURN INTEGER
                          IS
                          BEGIN
                              RETURN TO_NUMBER(SUBSTR(p_reply_text, 1, 3));
                          END reply_code;
                          -- When verbose mode is TRUE then additional information will be written to the logs.
                          -- If logging is turned off then verbose mode won't add anything.
                          IS
                          BEGIN
                              g_verbose  := NVL(p_verbose, c_default_verbose);
                              IF p_verbose
                              THEN
                                  write_to_log('Switching logging to verbose mode', TRUE);
                              END IF;
                          END set_verbose;
                          -- Returns the current setting of verbose mode (true/false)
                              RETURN BOOLEAN
                          IS
                          BEGIN
                              RETURN g_verbose;
                          END get_verbose;
                          -- Turn off logging (options=0) or turn on different options (see c_log_xxxxx constants)
                          IS
                          BEGIN
                              -- options big mask must be between 0 and sum of all possible log options.
                              IF p_log_options < 0
                                 OR p_log_options > c_log_dbms_output + c_log_rolling_buffer + c_log_client_info
                              THEN
                                  raise_application_error(
                                      -20001,
                                      'Invalid log options, must be between 0 and '
                                      || TO_CHAR(c_log_dbms_output + c_log_rolling_buffer + c_log_client_info),
                                      TRUE);
                              END IF;
                              g_log_options  := p_log_options;
                          END set_log_options;
                          -- Return current logging options
                              RETURN INTEGER
                          IS
                          BEGIN
                              RETURN g_log_options;
                          END get_log_options;
                          -- Clears (null) the logging buffers
                          PROCEDURE clear_log
                          IS
                          BEGIN
                              -- Clear the log buffer
                              g_log_text  := NULL;
                              -- if logging to session client then clear that too
                              IF BITAND(g_log_options, c_log_client_info) > 0
                              THEN
                                  DBMS_APPLICATION_INFO.set_client_info(NULL);
                              END IF;
                          END clear_log;
                          -- Return the current contents of the rolling log buffer
                              RETURN VARCHAR2
                          IS
                          BEGIN
                              RETURN g_log_text;
                          END get_log_text;
                          -- write the text to each logging option that is currently enabled
                          -- verbose comments will not be logged if verbose mode is off.
                          IS
                          BEGIN
                              -- If global verbose setting is ON (meaning log everything)
                              -- or if this text is not verbose then log it.
                              IF g_verbose OR NOT p_verbose
                              THEN
                                  IF BITAND(g_log_options, c_log_dbms_output) > 0
                                  THEN
                                      DBMS_OUTPUT.put_line(v_text);
                                  END IF;
                                  IF BITAND(g_log_options, c_log_rolling_buffer) > 0
                                  THEN
                                      IF LENGTH(g_log_text) + LENGTH(c_crlf) + LENGTH(v_text) > 32767
                                      THEN
                                          g_log_text      :=
                                              SUBSTR(g_log_text, INSTR(g_log_text, c_crlf, LENGTH(v_text) + 2));
                                      END IF;
                                      g_log_text  := g_log_text || v_text || c_crlf;
                                  END IF;
                                  THEN
                                      DBMS_APPLICATION_INFO.set_client_info(v_text);
                                  END IF;
                              END IF;
                          END write_to_log;
                          -- Log in to the given server and return a connection object
                          IS
                              v_connection   connection;
                          BEGIN
                              write_to_log('opening connection to: ' || p_server || ':' || p_port, TRUE);
                              v_connection.tcp      :=
                                  UTL_TCP.open_connection(remote_host  => p_server,
                                                          remote_port  => p_port,
                                                          tx_timeout   => p_timeout
                              read_reply(v_connection);
                              send_ftp_command(v_connection, 'USER', p_username, p_account_info);
                              send_ftp_command(v_connection, 'PASS', p_password, p_account_info);
                              -- If we haven't already been prompted for ACCT info
                              -- then send it now if we have it
                              IF p_account_info IS NOT NULL AND v_connection.account_info IS NULL
                              THEN
                                  send_ftp_command(v_connection, 'ACCT', p_account_info);
                                  v_connection.account_info  := p_account_info;
                              END IF;
                              IF p_local_directory IS NOT NULL
                              THEN
                                  local_cd(v_connection, p_local_directory);
                              END IF;
                              IF p_remote_directory IS NOT NULL
                              THEN
                                  remote_cd(v_connection, p_remote_directory);
                              END IF;
                              set_transfer_method(v_connection, p_trans_method);
                              p_connection  := v_connection;
                          END open;
                              RETURN connection
                          IS
                          BEGIN
                              sdsftp.open(p_server            => p_server,
                                          p_username          => p_username,
                                          p_password          => p_password,
                                          p_connection        => v_connection,
                                          p_local_directory   => p_local_directory,
                                          p_remote_directory  => p_remote_directory,
                                          p_trans_method      => p_trans_method,
                                          p_timeout           => p_timeout,
                                          p_port              => p_port,
                                          p_account_info      => p_account_info
                              RETURN v_connection;
                          END open;
                          -- Close the FTP, severs the TCP connection and clears the internal values
                          IS
                          BEGIN
                              write_to_log(
                                     'closing connection: '
                                  || p_connection.tcp.remote_host
                                  || p_connection.tcp.remote_port,
                                  TRUE);
                              send_ftp_command(p_connection, 'QUIT');
                              UTL_TCP.close_connection(p_connection.tcp);
                              p_connection.tcp              := NULL;
                              p_connection.account_info     := NULL;
                              p_connection.transfer_method  := NULL;
                              p_connection.transfer_option  := NULL;
                              p_connection.local_directory  := NULL;
                              p_connection.last_reply       := NULL;
                              write_to_log('connection closed', TRUE);
                          END close;
                          -- Request a separate connection on a different port for data transfer
                          -- PASV is the preferred transfer method opposed to PORT
                          -- per RFC 1123 (4.1.2.6) all servers must implement PASV.
                          FUNCTION get_passive_connection(p_connection IN OUT NOCOPY connection)
                              RETURN UTL_TCP.connection
                          IS
                              v_temp              VARCHAR2(25);
                              v_host              VARCHAR2(25);
                              v_port              INTEGER;
                              v_pasv_connection   UTL_TCP.connection;
                          BEGIN
                              write_to_log('requesting passive connection', TRUE);
                              send_ftp_command(p_connection, 'PASV');
                              -- PASV should respond with something of the form 227 zzzzzzzzzzzzzz (hhh,hhh,hhh,hhh,ppp,ppp)
                              -- where  hhh,hhh,hhh,hhh  is the host ip address, simply change ','  to '.' and it's ready to go
                              -- construct the port by taking the first part as the high byte of a 2-byte number  (multiply by 256)
                              -- and the second part as the low byte of the 2-byte number  (add it to the high byte)
                              -- per RFC1123 the host/port digits might not be enclosed in parentheses(),
                              -- therefore the parsing should be based on a scan of the digits themselves
                              v_temp             := REGEXP_SUBSTR(p_connection.last_reply, '(\d{1,3},){5,5}\d{1,3}');
                              -- 9i and lower don't have regular expressions
                              -- so, we have to use other methods to strip out the host/port digits
                              --        v_temp :=
                              --            RTRIM(
                              --                LTRIM(
                              --                    TRANSLATE(
                              --                        SUBSTR(p_connection.last_reply, 5),
                              --                        '0123456789,'
                              --                        || TRANSLATE(SUBSTR(p_connection.last_reply, 5), CHR(0) || '0123456789,', CHR(0)),
                              --                        '0123456789,'
                              --  v_temp should now look like this: 'hhh,hhh,hhh,hhh,ppp,ppp'  (minus the quotes)
                              v_host             := REPLACE(SUBSTR(v_temp, 1, INSTR(v_temp, ',', 1, 4) - 1), ',', '.');
                              v_temp             := SUBSTR(v_temp, INSTR(v_temp, ',', 1, 4) + 1);
                              v_port             :=
                                  TO_NUMBER(SUBSTR(v_temp, 1, INSTR(v_temp, ',') - 1)) * 256
                                  + TO_NUMBER(SUBSTR(v_temp, INSTR(v_temp, ',') + 1));
                              write_to_log('opening passive connection', TRUE);
                              v_pasv_connection  := UTL_TCP.open_connection(remote_host => v_host, remote_port => v_port);
                              RETURN v_pasv_connection;
                          EXCEPTION
                              WHEN OTHERS
                              THEN
                                  write_to_log('ERROR in get_passive_connection');
                                  write_to_log('    reply:' || p_connection.last_reply);
                                  write_to_log('    host:' || v_host);
                                  write_to_log('    port:' || v_port);
                                  write_to_log(DBMS_UTILITY.format_error_stack || DBMS_UTILITY.format_error_backtrace);
                                  RAISE;
                          END get_passive_connection;
                          -- Return the last reply from the server (multi-line replies will be returned as a single string)
                              RETURN VARCHAR2
                          IS
                          BEGIN
                              RETURN p_connection.last_reply;
                          END;
                          -- Read a reply from the server, including multi-line replies, concatenating them into a single reply string
                          IS
                              --    FTP Replies (per rfc959)
                              --        replies begin with 3 digit codes xyz
                              --        the from can be either single line or multi-line
                              --        if single line, then xyz text
                              --        if multi-line, then xyz-text, followed by any number of lines, followed by xyz text
                              --        thus a reply will always end with the xyz code, a space and optionally some text.
                              --        xyz single line reply
                              --        xyz-start of multi-line reply
                              --            some text
                              --            some more text
                              --        xyz end of multi-line reply
                              --        1yz   Positive Preliminary reply
                              --        2yz   Positive Completion reply
                              --        3yz   Positive Intermediate reply
                              --        4yz   Transient Negative Completion reply
                              --        5yz   Permanent Negative Completion reply
                              --        x0z   Syntax
                              --        x1z   Information
                              --        x2z   Connections
                              --        x3z   Authentication and accounting
                              --        x4z   Unspecified as yet.
                              --        x5z   File system
                              --        The third digit gives a finer gradation of meaning in each
                              --        of the function categories, specified by the second digit.
                              v_reply        VARCHAR2(32767) := NULL;
                              v_start_code   VARCHAR2(3);
                              v_temp         VARCHAR2(32767);
                          BEGIN
                              v_temp                   := UTL_TCP.get_line(p_connection.tcp, TRUE);
                              IF SUBSTR(v_temp, 4, 1) = ' '
                              THEN
                                  -- 3 digits and a space is a normal, one line response
                                  v_reply  := v_temp;
                              ELSIF SUBSTR(v_temp, 4, 1) = '-'
                              THEN
                                  v_start_code  := SUBSTR(v_temp, 1, 3);
                                  LOOP
                                      IF v_reply IS NULL
                                      THEN
                                          v_reply  := v_temp;
                                      ELSE
                                          v_reply  := v_reply || UTL_TCP.crlf || v_temp;
                                      END IF;
                                      EXIT WHEN v_temp LIKE v_start_code || ' %';
                                  END LOOP;
                              ELSE
                                  raise_application_error(-20001, 'Invalid FTP Protocol reply: ' || v_temp, TRUE);
                              END IF;
                              p_connection.last_reply  := v_reply;
                              IF g_log_options > 0
                              THEN
                                  write_to_log(v_reply);
                              END IF;
                              IF SUBSTR(v_reply, 1, 1) = '4'
                              THEN
                                  raise_application_error(-20001, 'Transient error from FTP server: ' || v_reply, TRUE);
                              ELSIF SUBSTR(v_reply, 1, 1) = '5'
                              THEN
                                  raise_application_error(-20001, 'Permanent error from FTP server: ' || v_reply, TRUE);
                              END IF;
                          EXCEPTION
                              WHEN UTL_TCP.end_of_input
                              THEN
                                  NULL;
                          END read_reply;
                          -- Send raw FTP protocol command (such as USER, PASS, STOR, RETR, etc)
                          IS
                              v_code   INTEGER;
                          BEGIN
                              IF p_arguments IS NULL
                              THEN
                                  v_code  := UTL_TCP.write_line(p_connection.tcp, p_command);
                              ELSE
                                  v_code  := UTL_TCP.write_line(p_connection.tcp, p_command || ' ' || p_arguments);
                              END IF;
                              read_reply(p_connection);
                              IF reply_code(p_connection.last_reply) = c_ftp_request_acct
                              THEN
                                  send_ftp_command(p_connection, 'ACCT', NVL(p_connection.account_info, p_account_info));
                                  p_connection.account_info  := p_account_info;
                              END IF;
                          EXCEPTION
                              WHEN OTHERS
                              THEN
                                  write_to_log('ERROR in send_ftp_command(' || p_command || ')');
                                  RAISE;
                          END send_ftp_command;
                          -- Rename a file or directory on the FTP server.
                          -- Note, this operation can be used to move files
                          IS
                          BEGIN
                              write_to_log('renaming remote file: ' || p_old_name || ' to ' || p_new_name, TRUE);
                              send_ftp_command(p_connection, 'RNFR', p_old_name);
                              send_ftp_command(p_connection, 'RNTO', p_new_name);
                          EXCEPTION
                              WHEN OTHERS
                              THEN
                                  write_to_log('ERROR in remote_rename(' || p_old_name || ',' || p_new_name || ')');
                                  RAISE;
                          END remote_rename;
                          -- Delete a file on the FTP server.
                          IS
                          BEGIN
                              write_to_log('deleting remote file: ' || p_file, TRUE);
                              send_ftp_command(p_connection, 'DELE', p_file);
                          EXCEPTION
                              WHEN OTHERS
                              THEN
                                  write_to_log('ERROR in remote_delete_file(' || p_file || ')');
                                  RAISE;
                          END remote_delete_file;
                          -- Create a directory on the FTP server.
                          IS
                          BEGIN
                              write_to_log('creating remote directory: ' || p_directory, TRUE);
                              send_ftp_command(p_connection, 'MKD', p_directory);
                          EXCEPTION
                              WHEN OTHERS
                              THEN
                                  write_to_log('ERROR in remote_create_directory(' || p_directory || ')');
                                  RAISE;
                          END remote_create_directory;
                          -- Delete a directory on the FTP server.
                          IS
                          BEGIN
                              write_to_log('deleting remote directory: ' || p_directory, TRUE);
                              send_ftp_command(p_connection, 'RMD', p_directory);
                          EXCEPTION
                              WHEN OTHERS
                              THEN
                                  write_to_log('ERROR in remote_delete_directory(' || p_directory || ')');
                                  RAISE;
                          END remote_delete_directory;
                          -- Sets the transfer method, it will accept FTP protocol values of A, I, E
                          -- as well as the key words ASCII, IMAGE, EBCIDIC, BINARY, DEFAULT
                          -- The first three map to the protocol characters, BINARY is equivalent to I
                          -- DEFAULT will set the method equal to the default method defined in this package's
                          -- specification.  If NULL, then no change will be made.
                          -- The A, E and I methods can also be parameterized if necessary (usually won't be)
                          -- The FTP protocol representation L is NOT supported at this time.
                          IS
                              v_method       VARCHAR2(10) := UPPER(SUBSTR(p_transfer_method, 1, 10));
                              v_option       VARCHAR2(1) := UPPER(SUBSTR(p_option, 1, 1));
                              v_new_method   VARCHAR2(3);
                          BEGIN
                              CASE
                                  WHEN v_method IS NULL
                                  THEN
                                      -- Do nothing, if NULL is the new method, then just keep the current one
                                      NULL;
                                  WHEN v_method = 'DEFAULT'
                                  THEN
                                      v_new_method  := SUBSTR(c_default_transfer_method, 1, 1);
                                  WHEN v_method = 'BINARY'
                                  THEN
                                      v_new_method  := 'I';
                                  WHEN v_method IN ('A', 'ASCII', 'I', 'IMAGE', 'E', 'EBCDIC')
                                  THEN
                                      v_new_method  := SUBSTR(v_method, 1, 1);
                                  ELSE
                                          -20001,
                                          'SDSFTP.set_transfer_method INVALID method: ' || p_transfer_method,
                                          TRUE);
                              END CASE;
                              IF v_new_method != NVL(p_connection.transfer_method, '---')
                              THEN
                                  write_to_log('changing transfer method', TRUE);
                                  IF v_option IN ('N', 'T', 'C')
                                  THEN
                                      send_ftp_command(p_connection, 'TYPE', v_new_method || ' ' || v_option);
                                  ELSIF v_option IS NULL
                                  THEN
                                      send_ftp_command(p_connection, 'TYPE', v_new_method);
                                  ELSE
                                                              'SDSFTP.set_transfer_method INVALID option: ' || p_option,
                                                              TRUE
                                  END IF;
                                  p_connection.transfer_method  := v_new_method;
                                  p_connection.transfer_option  := v_option;
                                  write_to_log('Transfer method changed', TRUE);
                              END IF;
                          END set_transfer_method;
                          -- Return the full name of the current transfer method for the given connection
                          -- Note, the FTP protocol representation L is NOT supported at this time.
                              RETURN VARCHAR2
                          IS
                          BEGIN
                              RETURN CASE
                                         WHEN p_connection.transfer_method = 'A' THEN 'ASCII'
                                         WHEN p_connection.transfer_method = 'E' THEN 'EBCDIC'
                                         WHEN p_connection.transfer_method = 'I' THEN 'IMAGE'
                                     END;
                          END get_transfer_method;
                          -- Change the directory used locally for sending files from or retrieving files into
                          -- a directory can be an explicit path supported by utl_file_dir parameter
                          -- or it can be a directory object.
                          IS
                          BEGIN
                              p_connection.local_directory  := p_directory;
                          END local_cd;
                          -- Returns the current directory used locally
                          -- Unlike a server which will always have a current directory
                          -- the local client might be NULL if a local_cd has not occurred.
                              RETURN VARCHAR2
                          IS
                          BEGIN
                              RETURN p_connection.local_directory;
                          END local_pwd;
                          -- Returns the current directory for the remote host
                              RETURN VARCHAR2
                          IS
                          BEGIN
                              write_to_log('Requesting remote directory', TRUE);
                              send_ftp_command(p_connection, 'PWD');
                              -- reply should be of the from 257 "directoryname"
                              -- strip the return code prefix and leading double quote
                              v_temp  := SUBSTR(p_connection.last_reply, 6);
                              -- strip off trailing double-qoutes
                              v_temp  := RTRIM(v_temp, '"');
                              -- double-qoutes within the name will be escaped with double-qoutes  i.e.  ""
                              -- un-escape any embedded double-quotes
                              v_temp  := REPLACE(v_temp, '""', '"');
                              write_to_log('Remote directory is:' || v_temp, TRUE);
                              RETURN v_temp;
                          END remote_pwd;
                          -- Change to the given directory on the remote host
                          IS
                          BEGIN
                              write_to_log('Changing remote directory to: ' || p_directory, TRUE);
                              send_ftp_command(p_connection, 'CWD', p_directory);
                              write_to_log('Remote directory changed', TRUE);
                          END remote_cd;
                          -- Move up to the parent directory on the remote host
                          IS
                          BEGIN
                              write_to_log('Changing to remote parent directory', TRUE);
                              send_ftp_command(p_connection, 'CDUP');
                              write_to_log('Changed to remote parent directory', TRUE);
                          END;
                          -- Given a local clob, send it to the remote host to be saved as a file
                          -- by default the current transfer method can be used or it can be
                          -- changed as part of this procedure
                          IS
                              v_read_cnt     INTEGER;
                              v_write_cnt    INTEGER;
                              v_lob_length   INTEGER;
                              v_index        INTEGER;
                              v_chunk        VARCHAR2(32767);
                              v_data         UTL_TCP.connection;
                          BEGIN
                              set_transfer_method(p_connection, p_trans_method);
                              v_data        := get_passive_connection(p_connection);
                              send_ftp_command(p_connection, 'STOR', p_remote_file);
                              write_to_log('storing file on: ' || v_data.remote_host || ':' || v_data.remote_port, TRUE);
                              v_lob_length  := DBMS_LOB.getlength(p_local_clob);
                              v_index       := 1;
                              WHILE v_index <= v_lob_length
                              LOOP
                                  v_read_cnt   := 32767;
                                  DBMS_LOB.read(p_local_clob, v_read_cnt, v_index, v_chunk);
                                  v_write_cnt  := UTL_TCP.write_text(v_data, v_chunk, NULL);
                                  UTL_TCP.flush(v_data);
                                  v_index      := v_index + v_write_cnt;
                              END LOOP;
                              write_to_log(
                                  'closing passive connection: ' || v_data.remote_host || ':' || v_data.remote_port,
                                  TRUE);
                              UTL_TCP.close_connection(v_data);
                          EXCEPTION
                              WHEN OTHERS
                              THEN
                                  write_to_log('ERROR in put_clob(' || p_remote_file || ')');
                                  write_to_log(
                                      TRUE);
                                  RAISE;
                          END put_clob;
                          -- by default the current transfer method will be ignored
                          -- and the procedure will temporarily switch to Image/Binary transfer
                          -- if force_binary is FALSE then the current method will be used.
                          IS
                              v_save_method   VARCHAR2(1);
                              v_read_cnt      INTEGER;
                              v_index         INTEGER;
                              v_chunk         RAW(32767);
                          BEGIN
                              IF p_force_binary AND p_connection.transfer_method != 'I'
                              THEN
                                  v_save_method  := p_connection.transfer_method;
                                  write_to_log('Saving current transfer method: ' || v_save_method, TRUE);
                                  write_to_log('Setting transfer method for BLOB binary transfer', TRUE);
                                  set_transfer_method(p_connection, 'IMAGE');
                              END IF;
                              v_lob_length  := DBMS_LOB.getlength(p_local_blob);
                              v_index       := 1;
                              LOOP
                                  DBMS_LOB.read(p_local_blob, v_read_cnt, v_index, v_chunk);
                                  v_write_cnt  := UTL_TCP.write_raw(v_data, v_chunk, NULL);
                              END LOOP;
                              write_to_log(
                                  TRUE);
                              IF p_force_binary AND v_save_method != 'I'
                              THEN
                                  write_to_log('Restoring previous transfer method:' || v_save_method, TRUE);
                                  set_transfer_method(p_connection, v_save_method, SUBSTR(v_save_method, 3, 1));
                              END IF;
                          EXCEPTION
                              WHEN OTHERS
                              THEN
                                  write_to_log('ERROR in put_blob(' || p_remote_file || ')');
                                  write_to_log(
                                      TRUE);
                                  RAISE;
                          END put_blob;
                          -- Read a remote file directly into a local clob
                          -- there will be no OS file created locally by this
                          -- by default the current transfer method will be used
                          -- but it can be changed as part of this procedure call
                          IS
                              v_char_cnt   INTEGER;
                              v_error      VARCHAR(32767);
                          BEGIN
                              send_ftp_command(p_connection, 'RETR', p_remote_file);
                              write_to_log('retrieving file from: ' || v_data.remote_host || ':' || v_data.remote_port,
                                           TRUE
                              LOOP
                                  BEGIN
                                      v_char_cnt  := UTL_TCP.read_text(v_data, v_chunk, 32767);
                                      DBMS_LOB.writeappend(p_local_clob, v_char_cnt, v_chunk);
                                  EXCEPTION
                                      THEN
                                          EXIT;
                                      WHEN OTHERS
                                      THEN
                                          RAISE;
                                  END;
                              END LOOP;
                              write_to_log(
                                  TRUE);
                          EXCEPTION
                              WHEN OTHERS
                              THEN
                                  write_to_log('ERROR in get_clob(' || p_remote_file || ')');
                                  write_to_log(
                                      TRUE);
                                  RAISE;
                          END get_clob;
                              RETURN CLOB
                          IS
                              v_clob   CLOB;
                          BEGIN
                              DBMS_LOB.createtemporary(v_clob, TRUE);
                              get_clob(p_connection, p_remote_file, v_clob, p_trans_method);
                              RETURN v_clob;
                          EXCEPTION
                              WHEN OTHERS
                              THEN
                                  IF DBMS_LOB.istemporary(v_clob) = 1
                                  THEN
                                      IF DBMS_LOB.ISOPEN(v_clob) = 1
                                      THEN
                                          DBMS_LOB.close(v_clob);
                                      END IF;
                                      DBMS_LOB.freetemporary(v_clob);
                                  END IF;
                                  RAISE;
                          END get_clob;
                          -- Read a remote file directly into a local blob
                          IS
                              v_byte_cnt      INTEGER;
                              v_chunk         RAW(32767);
                          BEGIN
                              THEN
                              END IF;
                                           TRUE
                              LOOP
                                  BEGIN
                                      v_byte_cnt  := UTL_TCP.read_raw(v_data, v_chunk, 32767);
                                      DBMS_LOB.writeappend(p_local_blob, v_byte_cnt, v_chunk);
                                  EXCEPTION
                                      THEN
                                          EXIT;
                                      WHEN OTHERS
                                      THEN
                                          RAISE;
                                  END;
                              END LOOP;
                              write_to_log(
                                  TRUE);
                              THEN
                              END IF;
                          EXCEPTION
                              WHEN OTHERS
                              THEN
                                  write_to_log('ERROR in get_blob(' || p_remote_file || ')');
                                  write_to_log(
                                      TRUE);
                                  RAISE;
                          END get_blob;
                              RETURN BLOB
                          IS
                              v_blob   BLOB;
                          BEGIN
                              DBMS_LOB.createtemporary(v_blob, TRUE);
                              sdsftp.get_blob(p_connection, p_remote_file, v_blob, p_force_binary);
                              RETURN v_blob;
                          EXCEPTION
                              WHEN OTHERS
                              THEN
                                  IF DBMS_LOB.istemporary(v_blob) = 1
                                  THEN
                                      IF DBMS_LOB.ISOPEN(v_blob) = 1
                                      THEN
                                          DBMS_LOB.close(v_blob);
                                      END IF;
                                      DBMS_LOB.freetemporary(v_blob);
                                  END IF;
                                  RAISE;
                          END get_blob;
                          -- Given a local file, send it to the remote host to be saved as a file
                          -- by default the current transfer method will be used but it can be
                          -- overridden.  The procedure is overloaded 3 ways based on available values.
                          -- This version reads from a local utl_file pointer and sends that file
                          -- to the remote server.
                          -- with directory and local file, with utl_file pointer,
                          -- or just file names with current directory
                          IS
                              v_byte_cnt    INTEGER;
                              v_textchunk   VARCHAR2(32767);
                              v_binchunk    RAW(32767);
                          BEGIN
                              write_to_log('writing file to: ' || v_data.remote_host || ':' || v_data.remote_port, TRUE);
                              LOOP
                                  BEGIN
                                      IF p_connection.transfer_method = 'I'
                                      THEN
                                          UTL_FILE.get_raw(file => p_local_file, buffer => v_binchunk, len => 32767);
                                          v_byte_cnt  := UTL_TCP.write_raw(v_data, v_binchunk, NULL);
                                      ELSE
                                          UTL_FILE.get_line(file => p_local_file, buffer => v_textchunk, len => 32767);
                                          v_byte_cnt  := UTL_TCP.write_text(v_data, v_textchunk, NULL);
                                      END IF;
                                  EXCEPTION
                                      WHEN NO_DATA_FOUND
                                      THEN
                                          EXIT;
                                      WHEN OTHERS
                                      THEN
                                          RAISE;
                                  END;
                              END LOOP;
                              write_to_log(
                                  TRUE);
                          EXCEPTION
                              WHEN OTHERS
                              THEN
                                  write_to_log('ERROR in put_file(' || p_remote_file || ')');
                                  write_to_log(
                                      TRUE);
                                  RAISE;
                          END put_file;
                          -- This version reads from a file from a local directory and sends that file
                          IS
                              v_file   UTL_FILE.file_type;
                          BEGIN
                              IF p_local_directory IS NULL
                              THEN
                                  write_to_log(
                                         'Local directory not set prior to get_file('
                                      || p_local_directory
                                      || p_local_file
                                      -20001,
                                      'SDSFTP.PUT_FILE - Local directory must be specified to GET files',
                                      TRUE);
                              END IF;
                              IF p_remote_file IS NULL
                              THEN
                                  write_to_log(
                                         'NULL file name used for put_file('
                                      || p_local_directory
                                      || p_local_file
                                                          'SDSFTP.GET_FILE - Can not PUT a file into a NULL file name',
                                                          TRUE
                              END IF;
                              IF NVL(UPPER(p_trans_method), p_connection.transfer_method) IN ('BINARY', 'IMAGE', 'I')
                              THEN
                                  v_file  := UTL_FILE.fopen(p_local_directory, p_local_file, 'rb', 32767);
                              ELSE
                                  v_file  := UTL_FILE.fopen(p_local_directory, p_local_file, 'r', 32767);
                              END IF;
                              sdsftp.put_file(p_connection    => p_connection,
                                              p_local_file    => v_file,
                                              p_remote_file   => p_remote_file,
                              UTL_FILE.fclose(v_file);
                          EXCEPTION
                              WHEN OTHERS
                              THEN
                                  IF UTL_FILE.is_open(v_file)
                                  THEN
                                  END IF;
                                  RAISE;
                          END put_file;
                          -- This version reads from a file from the current local directory.
                          IS
                          BEGIN
                              IF p_connection.local_directory IS NULL
                              THEN
                                  write_to_log('Local directory not set prior to put_file(' || p_local_file || ')');
                                      -20001,
                                      'SDSFTP.PUT_FILE - Local directory must be specified to PUT files',
                                      TRUE);
                              END IF;
                                              p_local_directory  => p_connection.local_directory,
                                              p_local_file       => p_local_file,
                                              p_remote_file      => p_local_file,
                          END put_file;
                          -- Read remote file to local UTL_FILE file handle
                          -- by default the current transfer mode will be used but it can be changed
                          -- This is the driver function that all other "get_file" procedures invoke
                          IS
                              v_transfer_cnt   INTEGER;                              -- bytes for raw, characters for Text
                          BEGIN
                                           TRUE
                              LOOP
                                  BEGIN
                                      THEN
                                          v_transfer_cnt  := UTL_TCP.read_raw(v_data, v_binchunk, 32767);
                                          UTL_FILE.put_raw(file => p_local_file, buffer => v_binchunk, autoflush => TRUE);
                                      ELSE
                                          v_transfer_cnt  := UTL_TCP.read_text(v_data, v_textchunk, 32767);
                                          UTL_FILE.put(file => p_local_file, buffer => v_textchunk);
                                      END IF;
                                      UTL_FILE.fflush(p_local_file);
                                  EXCEPTION
                                      THEN
                                          EXIT;
                                      WHEN OTHERS
                                      THEN
                                          RAISE;
                                  END;
                              END LOOP;
                              write_to_log(
                                  TRUE);
                          EXCEPTION
                              WHEN OTHERS
                              THEN
                                  write_to_log('ERROR in get_file(' || p_remote_file || ')');
                                  write_to_log(
                                      TRUE);
                                  RAISE;
                          END get_file;
                          -- Read remote file to selected local directory and new local name
                          IS
                          BEGIN
                              THEN
                                  write_to_log('Local directory not set prior to get_file(' || p_remote_file || ')');
                                      -20001,
                                      'SDSFTP.GET_FILE - Local directory must be specified to GET files',
                                      TRUE);
                              END IF;
                              IF p_local_file IS NULL
                              THEN
                                  write_to_log('NULL file name used for get_file(' || p_remote_file || ')');
                                                          'SDSFTP.GET_FILE - Can not GET a file into a NULL file name',
                                                          TRUE
                              END IF;
                              THEN
                                  v_file  := UTL_FILE.fopen(p_local_directory, p_local_file, 'wb', 32767);
                              ELSE
                                  v_file  := UTL_FILE.fopen(p_local_directory, p_local_file, 'w', 32767);
                              END IF;
                              sdsftp.get_file(p_connection    => p_connection,
                          EXCEPTION
                              WHEN OTHERS
                              THEN
                                  THEN
                                  END IF;
                                  RAISE;
                          END get_file;
                          -- Read remote file to current local directory with the same name
                          IS
                          BEGIN
                              THEN
                                      -20001,
                                      TRUE);
                              END IF;
                                              p_local_file       => p_remote_file,
                          END get_file;
                          -- Given a path, return the list of files, but default it return the full
                          -- file information but that may be changed to just the file names themselves.
                          -- Supported transfer methods are ASCII and EBCDIC only.
                          -- The current transfer method will be restored after listing if it was
                          -- changed by this routine.
                          -- Note the FTP RFC does not specify what the format will be so all information
                          -- is returned simply as a collection of strings.
                          IS
                              v_save_method    VARCHAR2(1) := NULL;
                              v_index          INTEGER := 1;
                          BEGIN
                              IF p_trans_method NOT IN ('A', 'ASCII', 'E', 'EBCDIC')
                              THEN
                                                          'SDSFTP.get_file_list INVALID method: ' || p_trans_method,
                                                          TRUE
                              END IF;
                              IF p_trans_method != get_transfer_method(p_connection)
                              THEN
                                  write_to_log('Setting ' || p_trans_method || ' method for remote file listing', TRUE);
                              END IF;
                              IF p_names_only
                              THEN
                                  send_ftp_command(p_connection, 'NLST', p_remote_path);
                              ELSE
                                  send_ftp_command(p_connection, 'LIST', p_remote_path);
                              END IF;
                              write_to_log(
                                  'retrieving file list from: ' || v_data.remote_host || ':' || v_data.remote_port,
                                  TRUE);
                              p_list.delete;
                              LOOP
                                  BEGIN
                                      v_transfer_cnt   := UTL_TCP.read_line(v_data, v_textchunk, TRUE, FALSE);
                                      p_list(v_index)  := v_textchunk;
                                      v_index          := v_index + 1;
                                  EXCEPTION
                                      THEN
                                          EXIT;
                                      WHEN OTHERS
                                      THEN
                                          RAISE;
                                  END;
                              END LOOP;
                              write_to_log(
                                  TRUE);
                              IF v_save_method IS NOT NULL
                              THEN
                                  set_transfer_method(p_connection, v_save_method);
                              END IF;
                          EXCEPTION
                              WHEN OTHERS
                              THEN
                                  write_to_log('ERROR in get_file_list(' || p_remote_path || ')');
                                  write_to_log(
                                      TRUE);
                                  THEN
                                  END IF;
                                  RAISE;
                          END get_file_list;
                              RETURN file_list
                          IS
                              p_list   file_list;
                          BEGIN
                              get_file_list(p_connection, p_remote_path, p_list, p_names_only, p_trans_method);
                              RETURN p_list;
                          END;
                      END sdsftp;
Comments (24)
Pascal WoodtliData Analyst
Hello Sean,
first off, this package is really awesome! Thank you a lot for sharing it.
I'm relatively new to the whole PL/SQL. Trying to write an .csv file (about 30 MB) to an FTP server by means of your sdsftp.put_clob(). So the file appears correctly on the server but the Oracle process will not stop running for several minutes after and finally show an error like:
  ORA-20001: Transient error from FTP server: 421 Data timeout. Reconnect. Sorry.
  ORA-06512: at "WET_TRADER.SDSFTP", line 393
  ORA-06512: at "WET_TRADER.SDSFTP", line 6791
  ORA-29260: network error: not connected
As you suggested above, I use at the end:
    THEN
    END IF;
What did I do wrong?
Thanks for the great article.
I have a requirement to read a CSV file from SFTP server.
Does the same code work for SFTP as well (or is it that it only works for FTP)?
Thanks in advance!
Most Valuable Expert 2011
Top Expert 2012
It only works with normal FTP,  not SFTP.
Hi Sean, how i can connect to ftp server on port 990 with TLS/SSL Implicit encryption enabled
Top Expert 2012
I have not personally tried it, but if you modify the OPEN procedure to call the UTL_TCP.OPEN_CONNECTION function with the wallet parameters, it may work (assuming you've created such a wallet.)
TLS/SSL communication is exactly what those parameters and wallets are for.
View More
