Existing System
The existing system is a pretty simple Excel tracking sheet.
As you can see, it was done with a simple sheet, in which Member's details and Attendance are tracked together.
Some formulas have been placed to get the total count of attendance in different dimensions, such as attendance per individual and per gathering, which will be explained at a later stage.
As you might have observed, when a member has attended a cross mark ( "X" ) will be entered in that particular gathering.
So, the following is my intention to somehow automate the process.
My Planning
I have in mind what is needed:
1 ) Buy a barcode scanner
2 ) Select a suitable barcode font to install
3 ) Develop a macro that will be able to receive barcode text
4 ) Put in the formula
5 ) Testing1 ) Buy a barcode scanner
A standard barcode scanner will do the task.
2 ) Select a barcode font to be installed
A suitable barcode font is needed to make things easier, so there will be no need to use any extra library of components to generate the barcodes.
There are plenty of free barcodes fonts available online.
In this case, I have selected a barcode font from IDAutomation.
To download it, please refer to the following link:
Once you have gotten the barcode font, simply right click the downloaded font file and click Install to install it.
3 ) Develop a macro that able to receive the barcode text
We have now entered into the final phase before we will be ready for testing.
To start, we will need to create a userform, so that it can be used to accept the needed inputs, either by manually keying them in or via the scanning of a barcode.
a ) First, launch the Visual Basic Editor in Excel.
To do this, go to the Developer tab and click Visual Basic, or simply press the shortcut keys of Alt + F11.
b ) Right-click any of the files in the Project Explorer and add a UserForm. See below;
c ) There are a few controls we are able to put into the form.
Event Date | So that we know which date is to be marked To represent this data, I recommend using a Combo Box control |
Barcode | To detect the data received from the barcode scanner and make the attendance To represent this data, I recommend using a Textbox control |
Scan Option | So that we know it's to mark or un-mark the attendance To represent this data, I recommend using OptionButton controls |
Ok action | To validate the barcode that has been scanned To represent this data, I recommend using the Button control |
Go action | To provide a convenient way of jumping the cursor to the attendance sheet for verification To represent this data, I recommend using the Button control |
Message | To show the result of scanning To represent this data, I recommend using the Label control |
d ) To load the Event Date
We can simplify things so that the event dates are entered and tracked in this same worksheet, as long as the event dates are in a sequential alignment in columns.
To get the macro codes to load the event dates into the dropdown list in the userform would be done as follows:
Dim LastCol As Integer, idx As Integer
Dim EventDate As Variant
Dim EventName As String
Dim SelectedIndex As Integer
SelectedIndex = 0
LastCol = Sheets(ws_Member).Cells(3, Sheets(ws_Member).Columns.Count).End(xlToLeft).Column
If LastCol < Sheets(ws_Member).Range(cell_FirstEvent).Column Then
MsgBox "No Events in Sheet Member", vbCritical, "Error"
Exit Sub
End If
For i = Sheets(ws_Member).Range(cell_FirstEvent).Column To LastCol
EventDate = Sheets(ws_Member).Cells(Sheets(ws_Member).Range(cell_FirstEvent).Row, i)
EventName = Trim(EventDate)
If EventName <> "" Then
If IsDate(EventDate) Then
cmbEventDate.AddItem Format(EventDate, "d-MMM")
If EventDate <= Date Then
SelectedIndex = idx
End If
End If
idx = idx + 1
End If
Next
cmbEventDate.ListIndex = SelectedIndex
e ) To add/remove attendance
Private Sub txtBarcode_Enter()
SendKeys "{Home}+{End}"
End Sub
Private Sub txtBarcode_KeyDown(ByVal KeyCode As MSForms.ReturnInteger, ByVal Shift As Integer)
If KeyCode = vbKeyReturn Then
Call cmdOk_Click
KeyCode = 0
End If
End Sub
Private Sub txtBarcode_MouseUp(ByVal Button As Integer, ByVal Shift As Integer, ByVal X As Single, ByVal Y As Single)
End Sub
Private Sub cmdOk_Click()
If IsValid() Then
Set rng = Sheets(ws_Member).Range("J:J").Find(txtBarcode.Text, , xlValues, xlWhole)
If Not rng Is Nothing Then
If optAdd.Value = True Then
Sheets(ws_Member).Cells(rng.Row, eventIdx) = "X"
msg = "Marked Attendance for : " & Sheets(ws_Member).Cells(rng.Row, "B") & " (" & Sheets(ws_Member).Cells(rng.Row, "C") & ")"
Call SetColor(lblMsg, msg, vbGreen)
Else
Sheets(ws_Member).Cells(rng.Row, eventIdx) = ""
msg = "Removed Attendance for : " & Sheets(ws_Member).Cells(rng.Row, "B") & " (" & Sheets(ws_Member).Cells(rng.Row, "C") & ")"
Call SetColor(lblMsg, msg, vbCyan)
End If
Else
msg = "Member ID " & txtBarcode.Text & " could not be found."
Call SetColor(lblMsg, msg, vbYellow)
txtBarcode.SetFocus
Exit Sub
End If
End If
txtBarcode.SetFocus
End Sub
Private Function IsValid() As Boolean
lblMsg.Caption = ""
If cmbEventDate.ListIndex = -1 Then
msg = "Please select Event Date"
cmbEventDate.SetFocus
IsValid = False
Exit Function
End If
Set rng = Sheets(ws_Member).Range("AA3:OZ3").Find(cmbEventDate.Value, , xlValues, xlWhole)
If rng Is Nothing Then
msg = "Event Date " & cmbEventDate.Value & " could not be found."
IsValid = False
Exit Function
End If
eventIdx = rng.Column
txtBarcode.Text = Replace(Trim(txtBarcode.Text), vbTab, "")
If txtBarcode.Text = "" Then
msg = "Please enter the Barcode"
txtBarcode.SetFocus
IsValid = False
Exit Function
End If
IsValid = True
End Function
Private Sub SetColor(ByRef lbl As MSForms.Label, ByVal msg As String, ByVal color As Long)
lbl.Caption = msg
lbl.BackColor = color
If color = vbYellow Then Beep
End Sub
After that, we will need to create a button in the attendance worksheet, so that we can write a simple macro to launch the userform we created, like so:
Dim frm As frmMain
Set frm = New frmMain
frm.Show vbModal
=COUNTA(AA4:AA500)
The end range row is changeable. This would define the maximum no of members per gathering.
=COUNTA(AA4:CO4)
The end range row is changeable. This would define the maximum no of gatherings available.
For this example, it set a limit to col: CO for the calculation.
Finally, we now need to save the file as an Excel Macro-Enabled Workbook (.xlsm)
5 ) Testing
a ) Valid Entry - Add attendance
