select employee_pk
, max(work_start_dt) last_start
, max(work_end_dt) last_end
, max(pk) last_pk
from tbl_Employee_WorkRecords
group by employee_pk;
The query is very close to what is requested in A, except for the fact that the individual results aren't synchronized:
select t.*
from tbl_Employee_WorkRecords t
where t.work_start_dt =
( SELECT MAX(i.work_start_dt)
from tbl_Employee_WorkRecords i
where i.employee_pk = t.employee_pk
A different syntax you will come across often is this technique:
select t.*
join ( select employee_pk, max(work_start_dt) max_start_dt
) i
on i.employee_pk = t.employee_pk
and i.max_start_dt = t.work_start_dt
--- MS SQL Server
select t.*
where convert(varchar(10), t.work_start_dt, 120) =
( SELECT convert(varchar(10), MAX(i.work_start_dt), 120)
-- ms sql server
select t.*
where t.pk = ( select top 1 i.pk
order by i.work_start_dt DESC
The main problem is that the pk field should only identify the row, and not have any other meaning, like ordering the results.
-- oracle => incorrect code
select t.*
where t.pk = ( select i.pk
and rownum = 1
Reason: Oracle applies the WHERE ROWNUM = 1 before the ORDER BY.
-- oracle
select sq.*
from ( SELECT t.*
, ROW_NUMBER() OVER ( PARTITION BY employee_pk ORDER BY work_start_dt DESC ) rn
FROM tbl_Employee_WorkRecords t
) sq
WHERE sq.rn = 1
When you remove the last condition WHERE sq.rn=1, you will see the additional column rn in the results, which should be self-explaining: The same syntax will actually work in MS SQL Server 2005 or higher, but not in SQL 2000 or lower, though.
--- MS SQL Server
select t.*
--- MS SQL Server
select t.*
-- the work_start_dt needs to be higher than the max(work_start_dt) for this employee, -1 day
where t.work_start_dt >=
( SELECT DATEADD(DAY, -1, MAX(i.work_start_dt))
-- ensure the record(s) are on the same date, actually, and not on the previous day than MAX(work_start_dt)
AND convert(varchar(10), t.work_start_dt, 120) =
The same technique will work for MySQL, you only need to replace the CONVERT() expression, for example using the TO_DAYS function:
--- MySQL
select t.*
AND TO_DAYS(t.work_start_dt) =
( SELECT TO_DAYS(MAX(i.work_start_dt))
And in Oracle, the function would be called TRUNC(), which leads to a much better solution:
--- Oracle
select t.*
( SELECT TRUNC(MAX(i.work_start_dt))
MS SQL Server doesn't know how to truncate a date the same way, but we can use for example:
--- MS SQL Server
select t.*
( SELECT CONVERT(DATETIME, CONVERT(VARCHAR(10), MAX(i.work_start_dt), 120), 120)
To save space, I won't repeat the same method again, just mention the 2 functions you will like to use: str_to_date() and date_format()
-- oracle
select sq.*
from ( SELECT t.*
, RANK () OVER ( PARTITION BY employee_pk ORDER BY TRUNC(work_start_dt) DESC ) rn
) sq
WHERE sq.rn = 1
Explanation: RANK() and DENSE_RANK() will hence give a rn=1 for all the values of the same DATE (as the time will be truncated => ignored).
-- oracle
select sq.*, e.Name
from ( SELECT t.*
) sq
join tbl_Employee e
ON e.pk = sq.employee_fk
WHERE sq.rn = 1
-- oracle
select sq.*, e.Name
from tbl_Employee e
left join ( SELECT t.*
, ROW_NUMBER() OVER ( PARTITION BY t.employee_pk ORDER BY t.work_start_dt DESC ) rn
FROM tbl_Employee e
JOIN tbl_Employee_WorkRecords t
WHERE e.last_name like 'B%'
) sq
AND sq.rn = 1
Comments (9)
Commented:Here the example for N = 1:
Here, the "JOIN condition" is done inside the CROSS APPLY, and instead of using ROW_NUMBER() function, we use the TOP x ... ORDER BY syntax, which will eventually be more readable/understandable for most people.Commented:
btw: there's a broken link to the dates/times article
Commented:it's been fixed!
View More
