For years I was a dedicated Apple iPhone user, yet despite many searches, I could never find a decent call recorder for my iPhone.
Having recently switched to a Samsung S9+ Android mobile, I finally found a utility that I think is brilliant and does everything I need and more!
This is a review of Call Recorder S9 - Automatic Call Recorder Pro available from the Google Play Store
What Capabilities does it have?
From the Google Play website...
Capabilities
- Samsung Galaxy S9 and S9 plus optimized
- Record your calls automatically while calling
- Advanced File Manager
- You can play back, or save your call to mp3 files on your SD card
- Record all outgoing calls
- Record all incoming calls
- Record all phone call conversations
- Play audio-recorded conversations
- Delete recorded conversations
- Send calls to email
After Call confirmation dialog for saving the recorded call
- Record incoming call
- Record Outgoing call
- Favorite
- Search
- Marking recordings as important
- Multi select, delete, send
- Excluded numbers
- Set password to protect privacy
- Set different audio format (MP3, WAV)
- Different recording modes by number, contact, non-contact or just selected contacts
- Enable/Disable call recording
- Records all your phone calls
- Play recorded audio
- Share recorded items
- Playback through speaker or earpiece on your phone
Share files
- Dropbox
- Google Drive
- SMS
- Viber
- Skype
My experiences with this App
Call Recorder S9 Pro is optimized for the Samsung S9 mobile, but not having access to other Android models, I can't confirm it works just as well on any other Android-based models. You'll just have to download and try it yourself sorry.
That said, installation is a breeze and pretty much the same process as installing any other Android-based app on your phone.
After installing the app on your phone, the first thing you need to do is just answer a couple of questions and go through the setup which only takes a minute or two. Once that's done, you're ready to go.
Here's the Main Menu Preferences Screen where you can modify a variety of settings and configurations.
!Tip: Click on any image to get a full-sized view in another tab of your browser!
Let's take a look at all the Options and preferences you can modify to your own liking and needs, one-by-one...
Automatic Recording
Tapping on the automatic recording option gives you the following
NOTIFICATIONS
Here is where you can enable Automatic recording, The fact that you can set the app to announce that the conversation is being recorded should take care of any legal issues about recording a telephone conversation because the person you are speaking to is made aware that the call is being recorded.
To configure this function to your liking, simply (1) tap the "Preferences" icon at the top right, and then (2) tap the "Notifications" option as shown below.
You can also adjust the "Sound Volume" controlling how loud the announcement will be, as well as enable an "After Call Notification" for the app to give you a notification once the call has ended.
On the next screen, turn on (3) "Play Sound" as shown in the second screenshot above and then tap (4) "Choose Sound" to select what type of notification you want the app to sound when a telephone call recording starts. Here you can select the following;
AUTOMATIC RECORDING
If you don't want to automatically record every call made or received, then once again, (A) tap the "Preferences" icon at the top right, and then (B) tap the "Shake to Record" option as shown below. You can then tap the "Shake Me" button and adjust/test the "Set Shake Sensitivity" to your own liking.
Once happy, then each time you receive or make a call, you can just shake your phone whenever you want to start the recording. Pretty neat right?
GENERAL SETTINGS
Tapping "General Settings" as per the first image on the left above, tapping "Caller ID" provides you with the following configuration options...
Caller ID Settings
Under the Extras category, you can select whether or not to show the caller ID for contacts that already exist in your phonebook. You can also select (or disable) an option to "Use your location to improve search results".
There is also an option to "Read the Usage and Privacy Terms" for using the App, along with the Version Number of the App (4.4.9 at time of writing). It also lists your unique Client ID.
ALL CONFIGURATION OPTIONS
Back to the Preferences/Main Menu screen again, here's an explanation of what all of the options allow you to do...
Here's a screenshot of my DropBox with some automatically uploaded and saved recordings:
A Summary of my views about Call Recorder S9 - Automatic Call Recorder Pro
If like me, you have a need to record inbound and outgoing call all the time (or selectively) then I can't see you going past this excellent App. I tried several other Apps before I settled on this one and they all failed dismally in one way or another, often not recording calls when they were supposed to, crashing on the odd occasion and just being generally unreliable.
Some other apps I also tried were as follows:
Call recorder automatic by Green Apple Studio
Call Recorder - ACR by NLL
Audio Recorder by Sony Mobile Communications
On the flip side, Call Recorder S9 has not hiccuped or failed me once since I've started using it. I used the Ad-Supported version for a while and can happily say that the ads are unobtrusive, not bugging you all the time and the free version does as good a job as the paid product. I decided to purchase the app, not just to get rid of the ads, but to encourage the author of the app to continue development. It truly is an excellent product.
Should you have any questions about this app, please do leave a comment below this article and I'll do my best to answer any questions you have from a user's standpoint.
I am an IT Professional, Professional Freelance Journalist, and Blogger, and an all-around nice guy! :)
You can contact me privately if you wish by accessing my Experts Exchange Profile Page.
Andrew Leniart - © Copyright 2018 - All rights reserved
Disclaimer: Neither I nor my company has any affiliation with the author of Call Recorder S9 Pro. I have had no contact from the author, nor any request to write this review. I am simply a very happy owner of this App that is totally pleased with its performance!
Comments (4)
Commented:Kind regards, Andrew
Commented:Good info for those who decide to opt for Google Voice. Thanks for sharing your info.
Regards, Andrew
