ASP Classic - Using Parameterized Queries
Published on
42,710 Points
10 Endorsements
Last Modified:
Awarded
Wayne Barron
ASP Classic, VB.NET with SQL Server development. Video Lesson's on Web Development and Video Post Production work. Always fun to share!
I have helped a lot of people on EE with their coding sources and have enjoyed near about every minute of it. Sometimes it can get a little tedious but it is always a challenge and the one thing that I always say is:
The Exchange of information is power;
Power is the Exchange of Knowledge;
Knowledge is the Power that you have to help others in need of your help.
The Exchange of Information!
The information below is for people that want to learn how to use Parameterized Queries in their Classic ASP scripts. I was forced to learn this back in the beginning of 2009 and have taken off with it. There is nothing really tough about it, just read the liner notes and then try it out for yourself.
In this tutorial below, I am giving you several different scenarios and the code for them. It works all out at the end.
What are Parameterized queries?
Parameterized queries are queries that have one or more embedded parameters in the SQL statement. This method of embedding parameters into a SQL statement is less prone to errors than the method of dynamically building up a SQL string.
-- source: Taken from enterprisedb.com
Tutorial Begins
Now, on with the code/lesson...
Note: If you have any questions please feel free to ask away. For this lesson, you will need to have the ADOVBS.inc file, which can be downloaded from here:
Download ADOVBS.INC
0. Getting Started
Make sure that the above line is at the very top of your page, and only one @ is allowed per page
<%@LANGUAGE="VBSCRIPT" CODEPAGE="65001"%>
Make sure that you are using the charset=utf-8, if not then you will lose some of your protection!
This our CSS to be used at the bottom of the page
<style type="text/css">
.MyTD{
border:1px #000000 double;
text-align:left;
vertical-align:top;
padding:3px;
color:#999999;
background-color:#333333;
</style>
Example of a FORM, none functional at this point
<form>
<input type="hidden" name="MyID" value="<%=getID%>" />
<input type="text" name="loginEmail" value="" />
</form>
Example of a QueryString, none functional at this point, to be used on the Multiple and below
page.asp?ID=1&amp;Email=me@site.com
First, we need to make sure that no one can attack our codes, so we are going to use my custom ProtectSQL script.
This will be used to PROTECT your code/database from being attacked by idiots with nothing better to do.
Function ProtectSQL(SQLString)
SQLString = Replace(SQLString, "'", "&#39;") ' replace single Quotes with Double Quotes
SQLString = Replace(SQLString, ">", "&gt;") ' replace > with &gt;
SQLString = Replace(SQLString, "<", "&lt;") ' replace < with &lt;
SQLString = Replace(SQLString, "(","&#40;") ' replace ( with &#40;
SQLString = Replace(SQLString, ")","&#41;") ' replace ) with &#41;
SQLString = Replace(SQLString, "&", "&amp;")
SQLString = Replace(SQLString, "%", "&#37;")
' replace vblf with <br /> (This is mainly used for Memo fields).
SQLString = Replace(SQLString, vblf,"<br />")
SQLString = Trim(SQLString)
ProtectSQL = SQLString
End Function
When you call the codes back out, just do the ProtectSQL function in reverse, basically create a new Function and do a reverse on it. This will be used to display the data to the page (To your visitor)
Function ReverseSQL(SQLString)
SQLRevString = Replace(SQLRevString, "&#39;", "'")
SQLRevString = Replace(SQLRevString, "&gt;", ">")
SQLRevString = Replace(SQLRevString, "&lt;", "<")
SQLRevString = Replace(SQLRevString, "&#40;","(")
SQLRevString = Replace(SQLRevString, "&#41;",")")
SQLRevString = Replace(SQLRevString, "&amp;", "&")
SQLRevString = Replace(SQLRevString, "%", "&#37;")
SQLRevString = Replace(SQLRevString,"<br />", vblf)
SQLRevString = Trim(SQLRevString)
ReverseSQL = SQLRevString
End Function
These are our Variables for our Parameters. For ALL Examples, as you can see, we have wrapped the ProtectSQL() around each one, so that we can capture ALL the bad things that someone might want to throw at us.
loginEmail = ProtectSQL(request.Form("loginEmail"))
loginPass = ProtectSQL(request.Form("Password"))
myID = ProtectSQL(request.Form("myID"))
1. Using Parameters with text VarChar, with a field length of 25
Set chEmail = Server.CreateObject("ADODB.Command")
chEmail.ActiveConnection=objConn
chEmail.Prepared = true
chEmail.commandtext="SELECT cusEmail, password, mydate FROM ordercavecustomer WHERE cusEmail =?"
chEmail.Parameters.Append chEmail.CreateParameter("@cusEmail", adVarChar, adParamInput, 25, loginEmail)
set rschEmail = chEmail.execute
2. Using Parameters with the Integer (INT)
As you can tell, we are not adding in a number, this is because the INT does not require a length, it can be any length up to 1 billion.
chEmail.commandtext="SELECT cusEmail, password, myID FROM ordercavecustomer WHERE myID =?"
chEmail.Parameters.Append chEmail.CreateParameter("@myID", adInteger, adParamInput, , getmyID)
3. We Are Going to Get Multiple Queries
Let's get these from our QueryString. As you can see, we have the Parameters in order of the way they are listed in our Statement, if not, then it will give you an error.
getID = ProtectSQL(request.QueryString("ID"))
getEmail = ProtectSQL(request.QueryString("Email"))
chEmail.commandtext="SELECT cusEmail, password, myID FROM ordercavecustomer WHERE myID =? and cusEmail=?"
4. INSERT Statement
Once again, we have to have everything in order, to make sure that it gets inserted correctly and without error.
chEmail.commandtext="INSERT into ordercavecustomer(cusEmail, password, myID)values(?,?,?)"
chEmail.Parameters.Append chEmail.CreateParameter("@password", adVarChar, adParamInput, 25, loginPass)
5. UPDATE Statement
Same as before, in order as they are written. The WHERE goes last, and as you can see, it is also last in the parameters list.
chEmail.commandtext="update ordercavecustomer set cusEmail=?, password=? where myID=?"
6. DELETE Statement
This example will DELETE the item with the ID of whatever it is in the QueryString (or) FORM
chEmail.commandtext="delete from ordercavecustomer where myID=?"
7. Display the information to the visitor with the ReverseSQL in place.
chEmail.commandtext="SELECT cusEmail, password, username, mydate, fname, lname FROM ordercavecustomer WHERE cusEmail =?"
' first we need to make sure that a record exist for the Query
if not rschEmail.eof then
' Now. We want to show our information back to our visitor, so we need to reverse what we have protected. So we wrap our recordsets with the ReverseSQL Function
strEmail = ReverseSQL(rschEmail("cusEmail"))
strpassword = ReverseSQL(rschEmail("password"))
strusername = ReverseSQL(rschEmail("username"))
strmydate = rschEmail("mydate")
strfname = ReverseSQL(rschEmail("fname"))
strlname = ReverseSQL(rschEmail("lname"))
elseif rschEmail.eof then
response.Write "Sorry, the user does not exist in our system, Sorry! Please try again later."
end if
<table>
<tr><td class="MyTD">Full Name</td><td class="MyTD"><%=strfname&" "&strlname%></td></tr>
<tr><td class="MyTD">Email</td><td class="MyTD"><%=strEmail%></td></tr>
<tr><td class="MyTD">Username</td><td class="MyTD"><%=strusername%></td></tr>
<tr><td class="MyTD">Password</td><td class="MyTD"><%=strpassword%></td></tr>
<tr><td class="MyTD">Date Joined</td><td class="MyTD"><%=strmydate%></td></tr>
</table>
The copy/paste version is below.
<%'Make sure that the above line is at the very top of your page, and only one @ is allowed per page%>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtm<wbr ></wbr>l1/DTD/xht<wbr ></wbr>ml1-transi<wbr ></wbr>tional.dtd<wbr ></wbr>">
<html xmlns="http://www.w3.org/1<wbr ></wbr>999/xhtml"<wbr ></wbr>>
<head>
<%'Make sure that you are using the charset=utf-8, if not then you will loose some of your protection!%>
<%'our CSS to be used at the bottom of the page%>
.MyTD{
text-align:left;
vertical-align:top;
padding:3px;
color:#999999;
</style>
</head>
<body>
<%'Example of a FORM, none functional at this point%>
<form>
</form>
<%'Example of a Querystring, none functional at this point, to be used on the Multiple and below%>
page.asp?ID=1&Email=me<wbr ></wbr>@site.com
' First thing is First, we need to make sure that no one can attach our codes
' So we are going to use my custom ProtectSQL script.
' This will be used to PROTECT your code/database from being attacked by idiots with nothing better to do.
SQLString = Replace(SQLString, "'", "'") ' replace single Quotes with Double Quotes
SQLString = Replace(SQLString, ">", ">") ' replace > with >
SQLString = Replace(SQLString, "<", "<") ' replace < with <
SQLString = Replace(SQLString, "(","(") ' replace ( with (
SQLString = Replace(SQLString, ")",")") ' replace ) with )
SQLString = Replace(SQLString, "&", "&")
SQLString = Replace(SQLString, "%", "%")
SQLString = Replace(SQLString, vblf,"<br />") ' replace vblf with <br /> (This is mainly used for Memo fields.
End Function
' When you call the codes back out, just do the ProtectSQL function in reverse, basically create a new Function and do a reverse on it.
' This will be used to display the data to the page (To your visitor)
SQLRevString = Replace(SQLRevString, "'", "'")
SQLRevString = Replace(SQLRevString, ">", ">")
SQLRevString = Replace(SQLRevString, "<", "<")
SQLRevString = Replace(SQLRevString, "(","(")
SQLRevString = Replace(SQLRevString, ")",")")
SQLRevString = Replace(SQLRevString, "&", "&")
SQLRevString = Replace(SQLRevString, "%", "%")
Reverse = SQLRevString
End Function
' These are our Variables for our Parameters. For ALL Examples, as you can see, we have wrapped the ProtectSQL() around each one, so that we can capture ALL the bad things that someone might want to throw at us.
loginEmail = ProtectSQL(request.Form("l<wbr ></wbr>oginEmail"<wbr ></wbr>))
loginPass = ProtectSQL(request.Form("P<wbr ></wbr>assword"))<wbr ></wbr>
myID = ProtectSQL(request.Form("m<wbr ></wbr>yID"))
' Example #1. using Parameters with text VarChar, with a field length of 25
Set chEmail = Server.CreateObject("ADODB<wbr ></wbr>.Command")<wbr ></wbr>
chEmail.ActiveConnection=o<wbr ></wbr>bjConn
chEmail.commandtext="SELEC<wbr ></wbr>T cusEmail, password, mydate FROM ordercavecustomer WHERE cusEmail =?"
chEmail.Parameters.Append chEmail.CreateParamet<wbr ></wbr>er("@cusEm<wbr ></wbr>ail", adVarChar, adParamInput, 25, loginEmail)
'Example #2. using Parameters with the Integer (INT)
' As you can tell, we are not adding in a number, this is because the INT does not require a length, it can be any length up to 1 billion.
chEmail.commandtext="SELEC<wbr ></wbr>T cusEmail, password, myID FROM ordercavecustomer WHERE myID =?"
chEmail.Parameters.Append chEmail.CreateParamet<wbr ></wbr>er("@myID"<wbr ></wbr>, adInteger, adParamInput, , getmyID)
' Example #3. We are going to get multiple Queries
' Lets get these from our QueryString
' As you can see, we have the Parameters in order of the way they are listed in our Statement, if not, then it will give you an error.
getID = ProtectSQL(request.QuerySt<wbr ></wbr>ring("ID")<wbr ></wbr>)
getEmail = ProtectSQL(request.QuerySt<wbr ></wbr>ring("Emai<wbr ></wbr>l"))
chEmail.commandtext="SELEC<wbr ></wbr>T cusEmail, password, myID FROM ordercavecustomer WHERE myID =? and cusEmail=?"
'#4 INSERT Statement
' Once again, we have to have everything in order, to make sure that it gets inserted correctly and without error.
chEmail.commandtext="INSER<wbr ></wbr>T into ordercavecustomer(cusEmail<wbr ></wbr>, password, myID)values(?,?,?)"
chEmail.Parameters.Append chEmail.CreateParamet<wbr ></wbr>er("@passw<wbr ></wbr>ord", adVarChar, adParamInput, 25, loginPass)
'#5 UPDATE Statement
' Same as before, in order as they are written.
' The WHERE goes last, and as you can see, it is also last in the parameters list.
chEmail.commandtext="updat<wbr ></wbr>e ordercavecustomer set cusEmail=?, password=? where myID=?"
'#6 DELETE Statement
' This example will DELETE the item with the ID of whatever it is in the Querystring (or) FORM
chEmail.commandtext="delet<wbr ></wbr>e from ordercavecustomer where myID=?"
'#7 Display the information to the visitor with the ReverseSQL inplace.
chEmail.commandtext="SELEC<wbr ></wbr>T cusEmail, password, username, mydate, fname, lname FROM ordercavecustomer WHERE cusEmail =?"
strEmail = ReverseSQL(rschEmail("cusE<wbr ></wbr>mail"))
strpassword = ReverseSQL(rschEmail("pass<wbr ></wbr>word"))
strusername = ReverseSQL(rschEmail("user<wbr ></wbr>name"))
strfname = ReverseSQL(rschEmail("fnam<wbr ></wbr>e"))
strlname = ReverseSQL(rschEmail("lnam<wbr ></wbr>e"))
response.Write"Sorry, the user does not exist in our system, Sorry! Please try again later."
end if
<table>
<tr><td class="MyTD">Full Name</td><td class="MyTD"><%=strfname&"<wbr ></wbr> "&strlname%></td></tr>
<tr><td class="MyTD">Email</td><td<wbr ></wbr> class="MyTD"><%=strEmail%><wbr ></wbr></td></tr><wbr ></wbr>
<tr><td class="MyTD">Username</td><wbr ></wbr><td class="MyTD"><%=strusernam<wbr ></wbr>e%></td></<wbr ></wbr>tr>
<tr><td class="MyTD">Password</td><wbr ></wbr><td class="MyTD"><%=strpasswor<wbr ></wbr>d%></td></<wbr ></wbr>tr>
<tr><td class="MyTD">Date Joined</td><td class="MyTD"><%=strmydate%<wbr ></wbr>></td></tr<wbr ></wbr>>
</table>
Conclusion
All the codes that I show people how to do here and on other threads throughout EE, is what I use in my real-world applications, I WILL NOT give someone code that I would not trust and use myself on my own sites.
CFF Coding Source
Have Fun & Happy Programming
Carrzkiss
Additional Resources
(please view the following code tutorial examples that I have written for EE)
#1: Shows basically what we are doing here in this article.
SELECT, INSERT, UPDATE, DELETE w/SQL & XSS Injection Prevention
Marked up with all the information that is here plus a LOT more.
http://ee.cffcs.com/Q_24801116/Q_24801116.asp
code
http://ee.cffcs.com/Q_24801116/Q_24801116.zip
#2: Protect your members online with a cookie that is also protected from SQL and XSS Injections.
http://ee.cffcs.com/Q_24252782/login.asp
http://ee.cffcs.com/Q_24252782/Q_24252782.zip
#3: Download without the physical path being known
http://ee.cffcs.com/Q_26208870/Q_26208870.asp
(Click on the =>Download your file here<=)
Updated Article 08-03-2012.
From this
chEmail.Parameters.Append getMyProfile.CreateParameter
To this
This is a HUGE Mistake on my part, and I wish to apologize to everyone that has come in here and learned from a mistake that I made.
Thank you to "rrhandle8" for pointing this out to me.
10
Get 7 days free
