CFGRID: How to open a cfwindow on double click of a cfgrid row
stu215Systems Analyst/Project Manager/Programmer
Updated:
PROBLEM: How to open a cfwindow or run a function on double click of a cfgrid row.
One of my clients wanted to be able to double click on a row item to get more detailed information about a transaction and to be able to modify the line items in a sub window. ( I tried posting a question in the forums to no avail and finally came up with my own solution after an extensive session of searching on google )
For something that seems quite simple it would have been nice to avoid that nuisance so I decided to create an article for anyone else who might be looking to do something similar.  At the end of this article I have included a full page source which will require minimal modifications to work ( explained in detail below ).
Step by step solution using CFGrid Event Listeners:
( skip to the bottom if you want the full source – requires minimal modification )
Step 1:
- Would be to create your <cfgrid> and a .cfc to populate it with some data.  It is important that the “selectmode” attribute for your grid be set to “row” ( selectmode=“row”)
Example:
<cfgrid name="YourGridName"
            format="html"
            pagesize="10"
            selectmode=“row”
            striperows="yes"
            bind="…">
Here is a great <cfgrid> tutorial if you require assistance on creating a <cfgrid> as I will not be covering that here:
http://www.forta.com/blog/index.cfm/2007/5/31/ColdFusion-Ajax-Tutorial-3-Live-Data-Grids
Step 2:
- Place the following <cfwindow> inside the <body> tag after your <cfgrid>:
<cfwindow
	closable="true"
	draggable="true"
	height="300"
	name="YourCFWindowName"
	resizable="false"
	title="My Window"
	width="300"
	x="100"
	y="100"
<table><tr><td>YAY! It works :-)</td></tr></table>
</cfwindow>
Step 3:
- It is important that the following <script> be placed inside of the <head> </head> tags of your page:
("YourGridName" should be replaced with the name of your cfgrid, and "YourCFWindowName" should be replaced with the name of your cfwindow. )
NOTE: You could replace the "showWin" function with any other function you want to run on double click of a row.
<script>
	init=function(){
		grid = ColdFusion.Grid.getGridObject("YourGridName");
		grid.addListener("rowdblclick",showWin);
	function showWin(){
		ColdFusion.Window.show('YourCFWindowName')
</script>
Step 4:
- Calling your init script - place the following code after your <cfwindow> inside the <body> tag:
<cfset ajaxOnLoad("init")>
CONCLUSION:
Using the script provided you should be able to fire any function you would like on a double click of a row item, and should you decide  you want it to be single click you can change “rowdblclick” to “rowclick”.
I have attached a demo page below but you will need to replace the <cfgrid> with your own, and "YourGridName" in the init function to make it work
<head>
<title>How to open a cfwindow on double click of a grid row</title>
<script>
	init=function(){
	function showWin(){
</script>
</head>
<body>
<cfform name="YourGridFormName">
<!--- Replace the following cfgrid with your cfgrid, this one is only here as a placeholder --->
         format="html"
         pagesize="25"
         striperows="yes"
         gridlines="yes"
         selectmode="row"
         bind="cfc:yourCFC_Name.yourLoadFunctionName({cfgridpage},
                              {cfgridpagesize},
                              {cfgridsortcolumn},
                              {cfgridsortdirection})"
         onchange="cfc:yourCFC_Name.yourFunctionName({cfgridaction},
                                 {cfgridrow},
                                 {cfgridchanged})">
      <cfgridcolumn name="myCol1" header="Column 1" width="100"/>
      <cfgridcolumn name="myCol2" header="Column 2" width="100"/>
      <cfgridcolumn name="myCol3" header="Column 3" width="100"/>
   </cfgrid>
</cfform>
<cfwindow
	closable="true"
	draggable="true"
	height="300"
	resizable="false"
	title="My Window"
	width="300"
	x="100"
	y="100"
</cfwindow>
</body>
</html>
Comments (6)
I'd need to look a bit more into having seperate actions for each column - presently just used rows.
However if you are just trying to display the row data in a form, you could use a cfajaxproxy and bind the form to the grid row so on click it shows the window and changes the form data to that specific row...
<cfajaxproxy bind="javascript:someFunction({YourGridName.Rec_ID}>
hmm! i tried that it does not work that way!
ok i madeit work, i will post article how to play with EXT js, its awesome and easy
Did you ever post on how to do this.
Hi Rick,
I have created a Tutorial on this and Will post it here, it may take some time for Approval
Cheers
View More
