Browse All Articles > Variable, Custom Code and Assembly reference in SSRS
How to use Variables and Custom code in SSRS report and Assembly reference to use compile shared code in SSRS.
Its big question for all who are working with SSRS. It is easy to create assembly and refer in SSRS report, still there are
some steps need to be applied. Let's look in details.
1. Variable in SSRS
If you want to use or hold value through out the request then refer the SSRS variables. It is available in any part of report and lifetime of variable is request to server. It reset when new request comes to server.
You can create variable using
Menu=>Report=>Report Properties=>Variables
![Add variables to SSRS]()
You can use this variable in calculation of field or anywhere in the report as below:
2. Custom Code in SSRS
Custom Code is very useful where you can not achieve desire result using Sum/Avg/Count/Running Total.
For example in report you are displaying records (Products) those have price > $10 That time you can hide those rows in report but total not eliminate hidden rows in count. In these type of case it's good to have custom code. Let's see how can we create custom code.
You can create custom code at
Menu=>Report=>Report Properties=>Code
Note: Make sure SSRS support custom code in VB only.
Let's time to see how to use the custom code in report fields.
3. Assembly Reference in SSRS
This is the very crucial part of the Assembly reference in SSRS. It is very useful when you want to use logic in other reports rather than in single one (Shared custom code).
To do that Just create one Library (As you know it is basic task.) Build that and paste it to
Consider for SQL 2008
To load assembly in SSRS
%\Program Files%\Microsoft SQL Server\MSRS10_50.MSSQLSERVER\Reporting Services\ReportServer\bin
To load assembly in BIDS (Development environment)
%\Program Files%\Microsoft Visual Studio %Installed Version%\Common7\IDE\PrivateAssemblies
Now time to consume or add assembly reference to SSRS.
You can add assembly reference at
Menu=>Report=>Report Properties=>References
![Add assembly reference]()
1. Click on Add Assembly reference and select your library.
2. Add class and create instance in second frame.
That's it for now. Hope meet with new Topic again.
Alpesh Patel
