How to quickly and accurately populate Word documents with Excel data, charts, and images (including Automated Bookmark generation)
Published on
247,974 Points
59 Endorsements
Last Modified:
Awarded
Editor's Choice
Community Pick
How to quickly and accurately populate Word documents with Excel data, charts and images (including Automated Bookmark generation)
David Miller (dlmille)
Synopsis
In this article you’ll learn how to use ExcelToWord! to copy data,charts, shapes and/or images to Word in a structured fashion, whether as a one-off solution or as a product of iterating through a list/database.  ExcelToWord! output options include printing, saving to Word, PDF, and eMail.  The downloadable add-in and test examples for learning ExcelToWord! can be found at the bottom of this article.
Intro
You inherited this job where you have to copy data from Excel into Word, save/print the Word document and/or Email it to a distribution list on a daily/weekly/monthly basis.
Your boss came to you with a Word document he/she worked on over the weekend and asked you to update key fields in the document, and print/email the document for her monthly leadership team meeting.
You have an impressive, massive Word document that is used as a template to report company performance, each month, and you have to pull together 50 Excel data-points and 5 charts, then update the Word document in key places, saving and distributing the document by email, within 24 hours of “business close” for the prior month.
Sound familiar?  I don’t know about you, but each of these demands sounds like they could be full-blown IT applications, and yet we’re stuck holding the bag, manually delivering these results, day in and day out.  When we finally get the data side of the equation in order (generally, in Excel), we still have to tediously enter data in Word – sometimes reading off Excel and typing in Word, and sometimes copying and pasting. In fact, we have less time these days, for analysis and real business thinking, because we have to do more and more administrative tasks to either get our jobs done, please the boss, or both.  Stressful!
This article focuses on a set of tools that can be used to configure Word and Excel to help you get more out of Office by more quickly and accurately updating Word documents with Excel data.  There’s a bit of setup involved – in re-designing your Word document/template, and in structuring your Excel data.  However, if your Excel data is already relatively structured, and you have more than a few data-points that need populating from Excel to Word, then you should find these tools helpful.
How does it all work?
The basic setup works with two templates:  1) Word template and 2) Excel template (a workbook with a worksheet that has the data needing to be farmed to the Word template).  The Word template is a designed document that has fields (Bookmarks) which should be populated from the Excel template.  Once the template design is complete, the act of opening the template causes Word to create a new document (not just open the template, itself), thus the act of saving the document after Excel data update will not invalidate the original template, itself ready to generate that next form-letter, invoice, report, etc.
Beyond basic mail merge, there are several ways to connect your Word template to Excel data:
1.  Write a specialized application to find certain text strings in Word for replacement from Excel data.
2.  Link specific fields in Word directly to Excel:  http://www.meadinkent.co.uk/excel-to-word.htm
3.  Leverage the use of Word Bookmarks (very common approach, with many tips in the public domain), e.g., straight-forward example: See VBADUD’s BlogSpot, and http://www.datawright.com.au/other/update_word_file_using_Bookmarks_and_VBA.htm is much more sophisticated, but it looks like a very structured approach.
I’m sure there are others, as well.  Option #3 is just a more structured (and perhaps maintainable) approach to #1, leveraging Word bookmarks to quickly identify where the Word ranges are that require update from Excel.
As I had already successfully completed a couple solutions in this arena, I decided to leverage #3 via the use of Bookmarks for this article.
Success Stories – It can be done!
In past solutions, however (and indeed, most published tips/blogs on the subject that I’ve found), the user was required to create specific bookmarks in Word, manually.  Now, that’s a fairly tedious process, in and of itself.  Not only do you need to identify where each bookmark goes, but you have to select a text string and use Word menus to create each bookmark, one at a time (there’s some similarity to creating a named range in Excel).  This was my first attempt at this , with LANCE_S_P having a database of data and needing to automate the population of a Word document.  In that solution, we created the bookmarks, manually, and leveraged Excel VBA to automate the data update process, up to and including automatically pasting an Excel chart into the Word document.  This was a big win for me, because up to this point, Word had been a 4-letter word.
Progressing from that, to another related solution, where LANCE_S_P had the job of updating a massive Word document with many data-points and charts requiring periodic update, I wrote a simple utility that would automatically generate bookmark positions (see: http:/Q_27114358.htm). There was some setup involved – and this is important – LANCE_S_P wanted to leverage some type of indicator in his Word document, that VBA could find, in order to automate the creation of bookmarks.  The approach we took looked for the string [[BM]], which would identify generic Bookmarks in his large document, subsequently numbering them in a sequence, creating Bookmark BM_1, BM_2, etc.   While he would have to manage the sequence, ensuring his Excel data matched up properly, this became a timesaving enhancement.
Finally, in my last related solution, I worked with creativefusion to automate his process: http:/Q_27432741.html.  Building on the prior two solutions, I developed a simple utility to automate the creation of more intelligent, personalized bookmarks, based on searching the Word template for the string pattern: [[bookmark_name]].  Also, we came up with logic to handle templates that could have one to many rows of data (e.g., as in an item list for invoice processing).
At this point, and fresh on my mind, I thought it appropriate to share the fruits of this labor.
1. Create (or modify) a Word document, saving it as a Word template.
So, what do I need to do with the Word template?
If you’ve followed me to this point, you’ve already figured out that the Word document/template side of things is relatively straight-forward:  bookmarks need to be created in the document, anywhere data is needed from Excel.  You can create them, manually, by selecting a text string or shape where the bookmark should go and then by leveraging the insert->bookmark menus in Word.  The utility associated with this article will support two additional methods that automate the task of bookmark creation:  generic BM_1, BM_2, etc., or intelligent, personalized bookmark_name approach.  Either still requires you to specify where the bookmark actually goes, leveraging the pattern [[BM]] in the generic case, and [[bookmark_name]] in the more intelligent case.  With the utility from this article, creation and maintenance of your bookmarks should be much faster, more accurate, and easier to implement.
This next section discusses three approaches to creating bookmarks in your Word template.  Choose one based on your circumstances, then when you’ve completed the document with all the required bookmarks or bookmark indicators,save it as a template, and pair the template with an Excel dataset (read on):
Steps for bookmark or bookmark indicator creation (see the three methods documented, below these steps):
1.  Create a (or modify an existing) Word template (or document).  Note: we’ll be saving the document ultimately as a Word template.
2.  Identify where Excel data-points or charts* are required.
3.  Indicate where the bookmark should go by typing a representative text string that is recognizable to you and others who may have to support this effort, going forward.
4.  (Method 1 - the manual approach - only.  Method 2 and 3 do not require this step) - Select that string, and then insert a bookmark, carefully naming it with a unique, identifiable name.
5.  Save the document as a Word template.
Bookmark method one (the manual approach):
Follow the steps, indicated above.  Note, you cannot create duplicate bookmarks, so just increment your bookmark, when you need duplicate data pasted (e.g., Contact_Name2).
Note:  In addition to any creative solutions you might develop, there is a unique opportunity to mix methods #1 with #2 or #3.  You could create a Shape in the Word template, and set a manual bookmark to that Shape (first selecting the Shape, then from the menu, Insert->Bookmark).  Size and place that Shape, as appropriate.  The application will paste any Excel Shape/Image/Chart into the Word’s Shape (via Fill), allowing you to have more control of how images are presented in the final Word document.
For method one, see demonstrated example, below.
figure-1: Manually creating a Word bookmark
Bookmark method two (the generic approach):
In this example, perhaps there are so many bookmarks, that the act of creating and maintaining unique, identifiable names can be difficult.  It might be much easier to enumerate them from BM_1 to BM_50, for example, while keeping a ledger of each bookmark number and its Excel counterpart in your Excel workbook.  While some tracking is required, to ensure accuracy, this might be the most efficient approach of the three.
Identify where each bookmark should go, and, for the representative text string , type [[BM]] at each location where you want to paste Excel data.  Don’t worry, later on there will be a utility you’ll use to transform each [[BM]] into [[BM_1]], [[BM_2]], etc., creating respective bookmarks in the process. For method two, see demonstrated example, below:
figure-2: Creating generic bookmark indicators in Word
Bookmark method three: (the intelligent, personalized approach):
In this last example, you’ve chosen perhaps the most accurate approach.  As with method two, modify the document by creating bookmark indicators, but this time, for the representative text string use the [[bookmark_name]] approach.
Method Three rules for bookmarks in the Word template:
1.  Must be formatted as follows:  [[bookmark_name]] – the [[ ]] brackets are required, and inside the brackets, only AlphaNumeric and Underscores are allowed (Word doesn't allow spaces in Bookmark names)
2.  There can be no duplicates.  Word doesn't allow duplicate Bookmarks (when they are ultimately generated by the utility.  If you have a duplicate, just create an additional Bookmark, incrementing the number, e.g., [[Contact_Name2]]
Note, the utility has an option to allow you to use both Bookmark method one and Bookmark method three, simultaneously (the utility would search range names first, then, if not found, it would search the workbook for the bookmark indicator).  This creates the unique opportunity to embed pictures/charts in the Excel workbook, atop an underlying range name – thus these can be exported to the Word document, as well.
For Bookmark method three, see demonstrated example, below:
figure-3: Creating intelligent, personalized bookmark indicators in Word
*Note:  See - http://peltiertech.com/Excel/ChartsHowTo/NameAChart.html on how to name an embedded Excel chart.  Alternatively, there’s a menu option to name a shape/image/or chart – just select the shape, then use the Name Embedded Shape/Chart option from the ExcelToWord! menu.  Follow a similar approach to naming any other type of Excel embedded shape/image.  If range names was the selected option, then ExcelToWord! will not only look at range names, but chart/shape names as well.  In fact, if you selected you wanted range/shape names and bookmark indicators as a configuration option, ExcelToWord! will look first for matching range names, then charts/shapes within scope (e.g., current worksheet or the entire workbook, when you setup the configuration), and finally bookmark indicators, stopping the search with the first one found.
2. Create (or modify) an Excel workbook.
Ok, so what do I need to do to structure my Excel workbook so all this will work?
The utility’s logic in this case, is very straight-forward.  The driving engine for this methodology is the Word bookmarks.  By enumerating a Word document’s bookmarks, we already know the names of the data-points that we need to find in Excel, we just need a consistent approach for documenting them during document creation (of the Excel workbook) so we can use simple VBA code to find them.
There many of ways you could manage this side of the process.  Here are two ways that are supported by the utility:
1. Somewhat similar to the approach taken with the Word template, but using named ranges as opposed to bookmarks, you could create a named range for each Excel data-point, then use code similar to the following to find the Word bookmark (absent the [[ ]] brackets – as Excel names disallow these characters).  I’ve not automated the generation of range names as I did for Word bookmarks, as option #2, below, I believe might be somewhat superior.
2. You could leverage an approach (similar to my approach with creativefusion, mentioned in my storytelling, above) where the Excel bookmark indicator is simply typed in a cell, and the data-point adjacent (right, below, left, or above – at your option, or based on your worksheet design) that text would be leveraged for updating Word.  The bookmark_name in this case needs to have the [[bookmark_name]] form to ensure you’ve precisely located the data-point, as the VBA code will be using the Find command searching the entire workbook for that term (and you could have duplicate Customer_Name fields in the workbook, but unlikely you’d have duplicate [[Customer_Name]] fields – so you can purposefully locate each term, but save the steps needed to create a range name (as needed in the #1 approach, above).
Note, for this option #2, if you have a “duplicate” Word bookmark (e.g., [[Customer_Name2]]) it will need to be created as well, in Excel, even though the actual adjacent data field should be referencing the original data-point.  Note:  “duplicate” in the sense of the SAME identifier, just more than one occurrence, as opposed to a true duplicate which is not allowed in Word.
For this option #2, see example demonstration, below:
figure-4: Creating bookmark indicators in ExcelAfter completing your construction of the Excel template workbook, be sure to save it, as well.
3. Follow the steps from the [b]ExcelToWord! [/b] add-in
Ok – I have the Word and Excel template’s created. Now, how do I get this to work?
Follow these steps to use the ExcelToWord! Add-in utility:
1. Download the add-in – save it to a Trusted Location.
2. Load your Excel template workbook, and start the add-in
3. From the Add-ins menu, select the ExcelToWord! menu
4. Configure your setup, using the Configuration option from the ExcelToWord! menu
5. Generate bookmarks in your Word template (note the newly generated template will be saved as name_BM.dot)
6. Update Word with Excel data (a Word document will be created from your template)
7. Repeat item #6, above, for as many updates as needed.  Note: your Excel workbook might be designed such that you can initiate Excel data changes (manually, through data queries, or by indexing to the next record).
As long as the data is associated with the Excel bookmark indicators, the Update process will generate a new document with the revised data (there’s no need to re-generate bookmarks (step #5) unless you’ve changed the structure of your original Word template.
When you execute the Update Word with Excel data routine, the final Word document can be printed, extracted to PDF, saved or deleted at the end of the routine (these options are set in the Configure routine).
Advanced Usage – Incrementing to generate multiple outputs
This is working great, but I have to process a letter for 50 customers.  How can I do this in one step, to avoid having to run the Update 50 times?”
You may have noticed in the Configuration Options panel, that there is a section called Cycle thru list or database.  The function means exactly that.  By identifying three cell references in the workbook, you can leverage the Incrementer function - a function that starts with the starting point and increments through to the ending point, while initiating the Update process on each increment:
1.  Location of the counter (e.g., a cell reference where the number entered provides your workbook formulas an index against a list or database, where data-points in Excel are updated based on that reference.  Use of OFFSET, VLOOKUP, etc., could be performed leveraging the index),
2.  Location of the Incrementer starting point (e.g., a cell reference where the value/formula for the starting number (integer) is provided), and
3.  Location of the Incrementer ending point (e.g., the last increment.  It could be the number of rows in a list or number of records in a database, or any other value that indicates the Incrementer’s ending point)
As with range names, identified Incrementer references can be located anywhere in the workbook, based on your design.
Based on the After Update option selected, in the Configuration Options panel, the resulting document would be printed, extracted to PDF*, or saved, with each Increment, as the Update Word with Excel data process is cycled.  Note:  PDF or Word filenames will be modified to include _XX in their filename, where XX would indicate the generated increment.
*Note: You must have PDF writer capability to use this feature.  However, there are "free" solutions if you have Office 2007/2010.  While Office 2010 has the functionality to extract Office documents to PDF formatted files, Microsoft has also provided an Office 2007 PDF Add-on supporting the same functionality.  (see:http://labnol.blogspot.com/2006/09/office-2007-save-as-pdf-download.html, or 'http://www.ehow.com/how_7184784_save-word-docs-pdf-vba.html)
Advanced Usage II – Using variable lists
Ok – I’ve got this list of items – could be 1, could be up to 20.  How can I deal with this to avoid a bunch of blank lines?
Let’s say in your Word template, you have a list of items, as in the invoice example (see figure 7, below):
figure-5: Using variable lists
As a result of this template design, there are 1 to many rows of bookmarks, enumerating invoice items.  When ExcelToWord! is initiated, if the Excel template has data for only the first few line items (the remainder are blank/not needed, in implementation, the remaining line items in the Word document would look like blank lines in the Word Template – a potentially unattractive gap between a list of line items, and the rest of the invoice.
This is handled through the creation of a table in your Word template, where each row in the table represents a line item (which might have several columns of text and/or bookmarks – for example):
[[LineItem1]], [[Quantity1]], [[Amount1]]
[[LineItem2]], [[Quantity2]], [[Amount2]]
[[LineItem3]], [[Quantity3]], [[Amount3]]
[[LineItem20]], [[Quantity20]], [[Amount20]] ‘<- the last line item
The above would be a Word table, having 3 columns, 20 rows, with each line items’ data on a separate row.
Through the Configuration panel of ExcelToWord! you can specify that tables containing rows with NO text/data be removed when the document is generated via the Update process.  In this way, the table will dynamically conform to available data.
 See example demonstration of steps 4-6, below:
figure-6: The Configurator userform in action
Appendix - The Code
The primary utility depends on three major routines:
1.  readWordDocMakeBookmarks() – the code reads the Word template, sending each paragraph to the setWordBookmark() routine.  Upon completion, a new Word template file is created, named original_name_BM.dot or .dotx, and saved in the same path as the original template.
2.  setWordBookmark()* -, the code then searches for the [[bookmark_name]] indicators in the text.  Once found, a bookmark is generated based on the specific text range.
3.  copyDataToWord() – once a template with bookmarks is created (through whatever means – manual, generic, or intelligent/personalized), the code opens that template file as a Word document, enumerating all Word bookmarks, searching Excel for each data point (via range name, or workbook find – based on Configuration settings) and replacing each bookmark with its Excel data counterpart.  Finally, print, extract to PDF, save, and/or delete is executed to complete the process.
*Note:  The code for finding bookmarks in Word was achieved leveraging RegEx – specifically the RegExpFind function (see matthewspatrick's most excellent article on the subject: http:\A_1336.html).  My RegEx pattern \[{2}[A-Za-z0-9_]+\]{2} looks for the [[ ]] brackets to define where the bookmark name would be, with alphanumeric and underscore allowed inside the brackets.  Bookmark indicators with any other characters or spaces are included inside the brackets will be ignored (Word doesn't allow spaces in Bookmark names, and through convenience, disallowed any other characters).  Check your template_BM.dot to ensure all your Bookmarks were created, just to be sure you didn’t use any disallowed characters!
While not the entire codeset (which is downloadable by all) I tried to post what I believed was the most interesting/relevant to the app.
Here’s the code for reading the Word document, making bookmarks as a result of scanning for bookmark indicators:
Option Explicit
Public Sub generateWordBookmarks(Optional control As Object) 'IRibbonControl
Dim xMsg As Long
Dim myMsg As String
'The Configuration Options panel should not have saved a set of invalid options, but to be sure,
'complete a final pass of run-through validations prior to the update.  Recall, it could be days, weeks, or months since this workbook
'was originally created and successfully completed an ExcelToWord! update.  As a result, file paths, templates, etc., could have been
'deleted, renamed, or relocated...
    If Application.Workbooks.Count = 0 Then
        MsgBox "No files open to process"
        Exit Sub
    End If
    If ActiveSheet.Type <> xlWorksheet Then
        MsgBox "You can only run ExcelToWord! functions from Excel Worksheets (e.g., Not from Chart Sheets, etc.)", vbCritical
    ElseIf myEvaluate(CONFIG_SCOPE) = "" Or (myEvaluate(CONFIG_SCOPE) = "Worksheet" And _
        myEvaluate(CONFIG_SHEET) = "") Then 'scope has not been defined, go to Configurator
        xMsg = MsgBox("Configurator settings have not been defined.  Proceed to Configuration Options?", vbYesNo, "Proceed to Configuration Options?")
        If xMsg = vbYes Then Call showConfigurator
    Else
        'first, validate all entries in the current configuration (as source files may have been deleted/renamed since the configuration was set up.
        Call setPublicVariables 'load configuration for current activity
        'check for Word template existence
        If Not validateFileFolderSelection(strWD_TemplFile, "Word", "template", False) Then
            MsgBox "The path\filename no longer exists" & Chr(10) & Chr(10) & strWD_TemplFile & Chr(10) & Chr(10) & "Please return to Configuration Options and Fix entry, or delete entry and BROWSE for file", vbOKOnly, "Configurator Error"
        ElseIf strWD_TemplOpt = "OWN" Then
            MsgBox "Configuration Options set to ""OWN"" therefore cancelling request to generate bookmarks.  Instead, you may proceed directly to the Update Word from Excel process."
        Else
            Call readWordDocMakeBookmarks(IIf(strWD_TemplOpt = "GENERIC", True, False), strWD_TemplFile)
        End If
    End If
End Sub
Private Sub readWordDocMakeBookmarks(bGeneric As Boolean, fPathFname As String)
'Dim oWA As Word.Application 'early binding
Dim oWA As Object 'late binding
'Dim oWD As Word.Document 'early binding
Dim oWD As Object 'late binding
'Dim para As Paragraph 'early binding
Dim para As Object
Dim bmks As Variant
Dim i As Integer
'Dim myDict As Scripting.Dictionary 'early binding
Dim myDict As Object 'late binding
Dim cntDict As Long
Dim regExPattern As String
Dim bResult As Boolean
Dim fName As String, fPath As String, fBMName As String
Dim fNameExt As String
Dim tempBMK As String
Dim objWkbSht As Object
'Rules for Bookmarks - NO duplicates, NO spaces.  Must start with [[  and end with ]], may include alphanumeric and underscore only
'This app will find proposed bookmarks in word document, and make them according to the book mark "name" inside the [[name]] brackets
'It will then save the file as a NEW TEMPLATE to be used with this application, named template_BM.dotx
'On the active sheet of the active workbook will be a range name called "WordDoc" that will be the name of the Word template
'to be found in the active workbook's path.
'If bookmarks already exist in the document, the new bookmark will overwrite the old.  Formfields having same name as proposed bookmarks will prompt
'option to skip that bookmark (encouraging user to clean up, after) or abort the update process.
    'start new instance of Word, regardless if an instance exists
    'Set oWA = New Word.Application 'early binding
    Set oWA = CreateObject("Word.Application") 'late binding
    'Set myDict = New Scripting.Dictionary 'early binding
    Set myDict = CreateObject("Scripting.Dictionary") 'late binding
    fPath = getPathFromPathFName(fPathFname)
    fName = Right(fPathFname, Len(fPathFname) - Len(fPath))
    fNameExt = Right(fName, Len(fName) - InStr(fName, ".") + 1) 'get file extension
    fBMName = Left(fName, InStr(fName, ".") - 1) & "_BM" & fNameExt
    Set oWD = oWA.Documents.Open(filename:=fPath & fName, ReadOnly:=True, AddToRecentFiles:=False) 'ReadOnly - never subject original template to corruption, .Add opens document based on template, .Open opens the Word TEMPLATE
    oWA.Visible = oWA_VISIBLE
    regExPattern = "\[{2}[A-Za-z0-9_]+\]{2}" 'looks for strings like [[alphanumeric or underscore]] spaces in BM's not permitted, also no duplicates
    For Each para In oWD.Paragraphs
        bmks = RegExpFind(para.Range.Text, regExPattern)
        On Error GoTo flagError
        If Not IsNull(bmks) Then
            For i = 0 To UBound(bmks)
                Application.StatusBar = "Processing bookmark " & bmks(i) & "..."
                cntDict = cntDict + 1 'new bookmark counter
                'do some validation - ensure GENERIC bookmarks all are of the type [[BM]], and that INTELLIGENT/PERSONALIZED bookmarks are unique via dictionary
                If bGeneric And bmks(i) <> "[[BM]]" Then Err.Raise 3, Description:="GENERIC bookmark is invalid - must be EXACTLY ""[[BM]]""" & _
                    Chr(10) & "BookMark: " & bmks(i) & Chr(10) & "Paragraph: " & para.Range.Text
                If bGeneric Then
                    tempBMK = Left(bmks(i), Len(bmks(i)) - 2) & "_" & cntDict & "]]" 'embed counter in bookmark name
                Else
                    tempBMK = bmks(i)
                End If
                'continue validation - ensure bookmark is unique, and if so, then generate bookmark
                If Not myDict.Exists(tempBMK) Then
                    myDict.Add tempBMK, cntDict
                    'now, modify the Word Template, setting the bookmark
                    bResult = setWordBookMark(oWD, para, tempBMK, bGeneric)
                    If Not bResult Then Err.Raise 2, Description:="Cannot create bookmark in Word for some reason" & Chr(10) & "BookMark: " & bmks(i) & Chr(10) & "Paragraph: " & para.Range.Text
                Else
                    Err.Raise 1, Description:="Error:  Duplicate found on proposed bookmark " & tempBMK & ": Bookmark proposed does not follow rules: " _
                        & Chr(10) & Chr(10) & "Rules for Bookmarks - NO duplicates, NO spaces.  Must start with [[  and end with ]]," & _
                        " may include alphanumeric and underscore only"
                End If
            Next i
        End If
        On Error GoTo 0
    Next para
    Application.StatusBar = "Saving Bookmark Template: " & fPath & fBMName & "..."
    'Note - FileFormat:= not needed - save in same format
    oWD.SaveAs filename:=fPath & fBMName, _
        LockComments:=False, Password:="", AddToRecentFiles:=True, _
        WritePassword:="", ReadOnlyRecommended:=False, EmbedTrueTypeFonts:=False, _
        SaveNativePictureFormat:=False, SaveFormsData:=False, SaveAsAOCELetter:=False
    'now, add this to the set of options for this sheet/workbook, for retrieval on the ExcelToWord! Update process
    strWD_TemplateBMFile = fPath & fBMName
    Set objWkbSht = IIf(bXL_SpanWorkbook, ActiveWorkbook, ActiveSheet)
    objWkbSht.Names.Add Name:="ETW_strWD_TemplateBMFile", RefersTo:=strWD_TemplateBMFile, Visible:=NAME_VISIBLE
    Application.StatusBar = False
    MsgBox "Successful Creation of " & myDict.Count & " Bookmarks" & Chr(10) & Chr(10) & "Revised Template File Has Been Saved: " & fBMName
gracefulExit:
    myDict.RemoveAll
    Set myDict = Nothing
    oWA.Quit
    Exit Sub
flagError:
    If Err.Number < 5 Then
        MsgBox "Error: " & Err.Number & "->" & Err.Description & Chr(10) & "Please correct problem with template/workbook and try again", vbCritical, "Aborting!..."
    Else
        MsgBox "VBA Error: " & Err.Number & "->" & Err.Description & Chr(10) & "Hit ok to enter Debugger", vbOKOnly, "Please correct VBA code - Aborting"
        Stop 'hit F8 to resume at error line for debug mode
        Resume
    End If
    Resume gracefulExit
End Sub
'Private Function setWordBookMark(oWD As Word.Document, para As Word.Paragraph, bmStr As Variant, bGeneric As Boolean) As Boolean 'early binding
Private Function setWordBookMark(oWD As Object, para As Object, bmStr As Variant, bGeneric As Boolean) As Boolean 'late binding
'Dim oBMK As Word.Bookmark 'early binding
Dim oBMK As Object 'late binding
Dim BM_Name As String
Dim xMsg As Long
Dim bDelete As Boolean
'Searches for Word bookmark indicators, then creates a bookmark for each.
'Generic bookmark indicators are incremented and "flagged" (e.g., [[BM_XX]]) with numeric increments, in the text of the template, as well.
    bDelete = True
    BM_Name = Left(Right(bmStr, Len(bmStr) - 2), Len(Right(bmStr, Len(bmStr) - 2)) - 2) 'eliminate the left and right [[ ]] braces from BookMark name
    Set oWA = oWD.Parent
    oWA.Selection.Find.ClearFormatting
    With oWA.Selection.Find
    If bGeneric Then
        .Text = "[[BM]]"
        .Replacement.Text = bmStr
    Else
        .Text = bmStr
    End If
        .Forward = True
        .Wrap = wdFindContinue
        .Format = False
        .MatchCase = False
        .MatchWholeWord = False
        .MatchWildcards = False
        .MatchSoundsLike = False
        .MatchAllWordForms = False
    End With
    If bGeneric Then
        oWA.Selection.Find.Execute Replace:=wdReplaceOne
    Else
    End If
    If BookmarkExists(oWD, BM_Name) Then 'existing bookmarks will be overwritten, but test formfields, first
        Set oBMK = oWD.Bookmarks(BM_Name)
        If ISFormfield(oBMK) Then
            xMsg = MsgBox("Bookmark: " & BM_Name & " already exists as a Form Field - do you want to SKIP this bookmark (YES - SKIP, keeping the bookmark/formfield ""as-is"" (note, you'll want to eliminate or restate a new name for the [[" & BM_Name & "]] in the Word template),CANCEL - Abort the process?", vbYesNoCancel, "YES - Skip & Continue, CANCEL - Abort")
                setWordBookMark = True
                Exit Function
            Else
                setWordBookMark = False
                Exit Function
            End If
        End If
        oBMK.Delete
    End If
    'now, create the bookmark
    With oWD.Bookmarks 'now add the bookmark
        .Add Range:=oWA.Selection.Range, Name:=BM_Name
        .DefaultSorting = wdSortByName
        .ShowHidden = False
    End With
End Function
'Private Sub enumerateWordBookMarks(oWA As Word.Application) 'early binding
Private Sub enumerateWordBookMarks(oWA As Object) 'late binding
'Dim BkMk As Word.Bookmark 'early binding
Dim BkMk As Object 'late binding
    For Each BkMk In oWA.ActiveDocument.Bookmarks
        Debug.Print BkMk.Name
    Next BkMk
End Sub
'Source: Adapted from http://www.vbaexpress.com/kb/getarticle.php?kb_id=562
'Private Function BookmarkExists(oWD As Word.Document, sBookmark As String) As Boolean 'early binding
Private Function BookmarkExists(oWD As Object, sBookmark As String) As Boolean 'late binding
'Checks if a bookmark exists in the active document
    If oWD.Bookmarks.Exists(sBookmark) Then
        BookmarkExists = True
    Else
        BookmarkExists = False
    End If
End Function
'Private Function ISFormfield(oBMK As Word.Bookmark) As Boolean 'early binding
Private Function ISFormfield(oBMK As Object) As Boolean 'late binding
'Dim oFormField  As Word.FormField 'early binding
Dim oFormField As Object 'late binding
'Checks if bookmark IS a formfield
    Set oWD = oBMK.Parent
    If oWD.FormFields.Count = 0 Then
        ISFormfield = False
    Else
        For Each oFormField In oWD.FormFields()
            If oFormField.Name = oBMK.Name Then
                ISFormfield = True
            End If
        Next
    End If
End Function
Here’s the code that pairs Word bookmarks with Excel bookmark indicators and generates the output
Option Explicit
Public Const RANGE_OBJ = 1
Public Const RANGE_NAME = 2
Public Const SHAPE_OBJ = 3
Public Const CHART_OBJ = 4
Public Const CHART_EMB = 5
Public myBM As BM_Indicators
Public Sub updateWordFromExcel(Optional control As Object) 'IRibbonControl
Dim validError As String
Dim strNameScope As String
Dim xMsg As Long
Dim strPathFName As String
Dim wkb As Workbook
Dim wks As Worksheet
'Dim bkMk As Word.Bookmark 'early binding
Dim fPath As String
Dim fName2 As String
Dim PDFname As String
Dim PDFname2 As String
Dim fRange As Range
Dim tbl As Object
Dim rw As Object
Dim cl As Object
Dim dataRow As Boolean
'Dim FSO As FileSystemObject 'early binding
Dim FSO As Object 'late binding
Dim BM_col As New BM_Indicators 'collection of bookmark indicators in Excel workbook
Dim eMail_Col As New BM_Indicators ' use same container for email address
Dim myObj As BM_Indicator
Dim bMultiCellOShape As Boolean
Dim bPasteChartSheet As Boolean
Dim bPasteChartEmbed As Boolean
Dim myObjCopy As Object
Dim i As Long
Dim lLoop As Long
Dim rIncrement As Range
Dim lStart As Long
Dim lEnd As Long
Dim xCalc As Long
Dim bDraftPreview As Boolean
Dim bPasteEnhMeta As Boolean
Dim fileAttach As String
'Dim OutApp As Outlook.Application 'early binding
Dim OutApp As Object 'late binding
        Exit Sub
    End If
        Exit Sub
    End If
    xCalc = Application.Calculation
    Application.StatusBar = "Update Word From Excel: Initialization..."
'Checking all relevant options
            GoTo backToUserform
        Else
            GoTo gracefulExit
        End If
    End If
    'check scope
    strNameScope = myEvaluate(CONFIG_SCOPE)
    If strNameScope = "" Then
        validError = "CONFIG_SCOPE ERROR:  Please revisit the Configuration Options panel, as there's some confusion about the scope.  " & _
            "No value for scope (Worksheet or Workbook)"
        GoTo backToUserform
    End If
    'ensure word template exists - the one that should have been generated
    If strWD_TemplOpt <> "OWN" Then
        If strWD_TemplateBMFile = vbNullString Or Not validateFileFolderSelection(strWD_TemplFile, "Word", "template", False) Then
            validError = "Word Template File ERROR:  The path\filename no longer exists, or needs to be re-generated" & vbCrLf & vbCrLf & "[path\filename]: " & strWD_TemplFile & vbCrLf & vbCrLf & "You may need to just Generate Word Bookmarks, or ..."
            GoTo backToUserform
        End If
    Else
        strWD_TemplateBMFile = strWD_TemplFile 'OWN option does not require BM File generation, but name it now, as the rest of the code depends on it
    End If
    'notify user with options if word document filename exists at that path - overwrite or cancel
    If bAftUpdSave Then
        'ensure word document path still exists
        If strWD_DocPath = vbNullString Or Not validateFileFolderSelection(strWD_DocPath, "Word", "document", True) Then
            validError = "New Word Document Path ERROR:  The path\filename no longer exists" & vbCrLf & vbCrLf & "[path\filename]: " & strWD_DocPath
            GoTo backToUserform
        ElseIf strWD_DocFile = vbNullString Then
            validError = "New Word Document File ERROR:  The filename chosen is no longer valid.  You might try save/close Excel, then reload your workbook and check Configuration Options"
            GoTo backToUserform
        End If
    End If
    'open word template as a document
    'Set FSO = New FileSystemObject 'early binding
    Set FSO = CreateObject("Scripting.FileSystemObject") 'late binding
    Set wkb = ActiveWorkbook
    Set wks = wkb.ActiveSheet
    fPath = getPathFromPathFName(strWD_TemplateBMFile)
    If bAftUpdPDF Then 'get path for PDF file generation & advise user
        If bAftUpdSave Then
            PDFname = strWD_DocPath & "\" & strWD_DocFile & ".pdf"
            MsgBox "PDF File will be saved in directory:" & vbCrLf & vbCrLf & strWD_DocPath & vbCrLf & vbCrLf & "The same as the generated Word Document", vbOKOnly
        Else
            PDFname = Left(strWD_TemplateBMFile, InStr(strWD_TemplateBMFile, ".") - 1) & ".pdf"
            MsgBox "PDF file will be saved in directory:" & vbCrLf & vbCrLf & fPath & vbCrLf & vbCrLf & "The same as the existing Word Template", vbOKOnly
        End If
    End If
    If FSO.fileExists(strWD_TemplateBMFile) Then
        'Prepare for Increment generation
        If bXL_Increment Then
            lStart = Range(strXL_RefStart).Value
            lEnd = Range(strXL_RefEnd).Value
        Else
            lStart = 1
            lEnd = 1
        End If
        For lLoop = 0 To lEnd - lStart
            If bXL_Increment Then 'set Incrementer value so data refresh is forced
                Range(strXL_RefCounter).Value = lStart + lLoop
                If xCalc = xlCalculationManual Then Application.Calculate
            End If
            Set oWD = oWA.Documents.Add(Template:=strWD_TemplateBMFile) 'Create New Document From Template
            'traverse all bookmarks and ensure that those bookmarks exist in Excel, looking at selected options - range, labels, or both
            For Each BkMk In oWD.Bookmarks 'first pass to build collection of Excel bookmark indicator (objects) associated with each Word bookmark
                'find corresponding Excel key that matches bookmark
                'look in range names first, then shape names (e.g., charts,images, etc.)
                'then bookmark indicators, as prescribed by the Configuration options selected
                Application.StatusBar = "[" & lLoop + 1 & "]:" & "Testing for Bookmark: " & BkMk.Name & "..."
                'search range names, then shape names option
                Select Case strXL_TemplOpt:
                    Case "RANGE":  'search range names, then shape names for bookmark indicators
                        bResult = searchRangeShapes(BM_col, BkMk, bXL_SpanWorkbook)
                    Case "RANGE_AND_CELL": 'search range names, then shape names, then CELLS for bookmark indicators
                        If Not bResult Then 'if not found in range, then look at CELL level
                            bResult = searchCells(BM_col, BkMk.Name, bXL_SpanWorkbook)
                        End If
                    Case "CELL": 'search CELLS for bookmark indicators
                End Select
                If Not bResult Then 'bookmark not found!
                    xMsg = MsgBox("Cannot Find Excel data for bookmark: " & BkMk.Name & ".  Continue anyway?", vbOKCancel, "Hit OK to Continue, Cancel to Abort")
                    If xMsg = vbCancel Then GoTo gracefulExit
                End If
            Next BkMk
            'now search for eMail marker in workbook [[eMail]]
            If strAftUpdEmail <> "" Then
                bResult = searchCells(eMail_Col, "eMailTo", bXL_SpanWorkbook) 'just add the eMail indicator to the bookmark indicators collection
                If bResult Then
                    bResult = searchCells(eMail_Col, "emailSubject", bXL_SpanWorkbook)
                    If bResult Then
                        bResult = searchCells(eMail_Col, "emailBody", bXL_SpanWorkbook)
                    End If
                End If
                    xMsg = MsgBox("Cannot Find Excel data for eMail address: [[eMailTo]], [[eMailSubject]], or [[eMailBody]] is missing. Continue anyway?", vbOKCancel, "Hit OK to Continue, Cancel to Abort")
                End If
                On Error Resume Next
                Set OutApp = GetObject(, "Outlook.Application")
                If OutApp Is Nothing Then
                    'Set OutApp = New Outlook.Application 'early binding
                    Set OutApp = CreateObject("Outlook.Application") 'late binding
                End If
                On Error GoTo 0
            End If
            'now loop through collection of found bookmark indicators, and output results to Word template
            For Each BkMk In oWD.Bookmarks 'second pass:  now we have matching Excel bookmark indicators and Word objects
                Application.StatusBar = "[" & lLoop + 1 & "]:" & "Second Pass:  Updating Word bookmarks from Excel for Bookmark: " & BkMk.Name & "..."
                bMultiCellOShape = False
                bPasteChartSheet = False
                bPasteChartEmbed = False
                On Error Resume Next 'recall, user may have allowed "Continue anyway" if bookmark indicator wasn't found
                Set myObj = BM_col(BkMk.Name)
                If Err.Number <> 0 Then 'assumed missed bookmark, but continue
                    'do nothing
                    On Error GoTo 0
                ElseIf Not myObj Is Nothing Then
                    On Error GoTo 0
                    'determine if type resolves to a single cell, a range > 1 cell, or a shape
                    Select Case myObj.BM_Type
                        Case RANGE_NAME:
                            bMultiCellOShape = IIf(myObj.obj.RefersToRange.Count > 1, True, False)
                            Set myObjCopy = myObj.obj.RefersToRange
                        Case RANGE_OBJ:
                        Case SHAPE_OBJ:
                            bMultiCellOShape = True
                        Case CHART_OBJ:
                            Set myObjCopy = myObj.obj.ChartArea
                            bPasteChartSheet = True
                        Case CHART_EMB:
                            bPasteChartEmbed = True
                    End Select
                    If bPasteChartSheet Or bPasteChartEmbed Then
                        'need to test if the bookmark in Word is a Shape, or Text
                        Dim r As Object
                        Set r = oWA.Selection.GoTo(what:=wdGoToBookmark, Name:=BkMk.Name)
                        If r.Text <> "" Then 'the bookmark is referencing text - a normal text-based bookmark indicator
                            myObjCopy.Copy
                            BkMk.Range.PasteSpecial Placement:=wdInLine, DataType:=iXL_TemplOptShapePaste
                                BkMk.Range.PasteSpecial Placement:=wdInLine, DataType:=wdPasteEnhancedMetafile
                                bPasteEnhMeta = True
                            End If
                            On Error GoTo 0
                            Application.CutCopyMode = False
                        ElseIf Not pastePicToBkMk(oWA, myObjCopy, BkMk) Then 'the bookmark is referencing a Shape, so paste via fill effects of the Shape
                            'paste shape/image/chart as picture into Word Shape bookmark
                            xMsg = MsgBox("Could not paste shape/image as a fill picture for bookmark: " & BkMk.Name & "." & _
                                vbCrLf & vbCrLf & "Continue anyway?", vbYesNo, "Hit YES to Continue, NO to Abort")
                            If xMsg = vbNo Then GoTo gracefulExit
                        End If
                    ElseIf bMultiCellOShape Then
                        myObjCopy.Copy
                            End If
                            On Error GoTo 0
                    Else
                        If myObjCopy.Value <> "" Then
                            BkMk.Range.Text = Application.WorksheetFunction.Text(myObjCopy.Value, myObjCopy.NumberFormat)
                        Else
                            BkMk.Range.Text = myObjCopy.Value 'use base format for all else
                        End If
                    End If
                End If
                On Error GoTo 0
            Next BkMk
            'The following code assumes that the application requires a list of items which can vary from 1 to unlimited
            If bWD_Table Then
                'So, there are 1 to many rows of BookMarks - e.g., invoice lineItems, For Example:
                'lineItem1, description1, amount1
                'lineItem2, description2, amount2
                'lineItem-n, description-n, amount-n
                'As a result, if the Excel template uses only the first few line items, the remaining line items would be a blank
                'copy from Excel to Word, leaving blank lines in the Word Template - and perhaps an unattractive gap between a list of line items,
                'and the rest of the invoice.
                'The following loop traverses all tables in the template and deletes lineItems that are blank
                Application.StatusBar = "[" & lLoop + 1 & "]:" & "Cleaning Word Template Tables..."
                'If there are any tables in the Word template, and their row is empty, then delete that empty row
                For Each tbl In oWD.Tables
                    For Each rw In tbl.Rows 'examine each row
                        dataRow = False
                        For Each cl In rw.Cells 'look at all cells in each row
                            If Len(Trim(Application.WorksheetFunction.Clean(cl.Range.Text))) > 0 Then
                                dataRow = True 'if there's data in any cell, then there's data in the row
                                Exit For
                            End If
                        Next cl
                        If Not dataRow Then
                            rw.Delete 'delete any rows in the table that all cells on that row are empty
                        End If
                    Next rw
                Next tbl
            End If
            'The document is now complete, all that remains is to print, extract to PDF, and/or save, then close the file, per Configuration Options
            If bAftUpdPrint Then
                Application.StatusBar = "[" & lLoop + 1 & "]:" & "Printing Word Document..."
                oWD.PrintOut
            End If
            If bAftUpdPDF Then
                'Save Word Document as PDF
                'for Office 2007 with Office PDF Add-On from http://labnol.blogspot.com/2006/09/office-2007-save-as-pdf-download.html, or
                    PDFname2 = Left(PDFname, Len(PDFname) - 4) & "_" & Format(lLoop + 1, "000") & ".pdf"
                End If
                Application.StatusBar = "[" & lLoop + 1 & "]:" & "Generating PDF file: " & PDFname2
                oWD.ExportAsFixedFormat OutputFileName:=PDFname2, ExportFormat:= _
                    wdExportFormatPDF, OpenAfterExport:=False, OptimizeFor:= _
                    wdExportOptimizeForPrint, Range:=wdExportAllDocument, _
                    Item:=wdExportDocumentContent, IncludeDocProps:=True, KeepIRM:=True, _
                    CreateBookmarks:=wdExportCreateNoBookmarks, DocStructureTags:=True, _
                    BitmapMissingFonts:=True, UseISO19005_1:=False
                    MsgBox "Unable to SaveAs/ExportTo PDF - you are either: " & vbCrLf & vbCrLf & _
                        "1) Running Excel 2003 or earlier, " & vbCrLf & _
                        "2) Running Excel 2007 without the required Office 2007 Save as PDF Add-on (See http://www.microsoft.com/download/en/details.aspx?id=7)" & vbCrLf & _
                        " or " & vbCrLf & _
                        "3) There's a problem with your Save as PDF capability in either Excel 2007 or Excel 2010." & vbCrLf & vbCrLf & _
                        "Please repair and try again", vbCritical, "Skipping Save as PDF step..."
                End If
                On Error GoTo 0
            End If
            If bAftUpdSave Then
                'Save Word document, in current format (e.g., doc, docx, etc.) then close file
                    fName2 = strWD_DocFile & "_" & Format(lLoop + 1, "000")
                Else
                End If
                Application.StatusBar = "[" & lLoop + 1 & "]:" & "Saving Word Document: " & strWD_DocPath & "\" & fName2
                oWD.SaveAs Filename:=strWD_DocPath & "\" & fName2
                oWD.Close
                Set oWD = Nothing
            ElseIf bAftUpdDelete Then 'otherwise, done with file, without save
                oWD.Close savechanges:=False
            Else 'then just preview the new Word document
                oWA.Visible = True
                bDraftPreview = True
                MsgBox "Toggle to Word document for Preview", vbOKOnly, "Terminating operation after 1st draft generated"
                GoTo gracefulExit
            End If
            If strAftUpdEmail <> "" And Not eMail_Col Is Nothing Then
                'eMail the PDF or Word document
                If UCase(strAftUpdEmail) = UCase("ePDF") Then 'process email w/ PDF
                    fileAttach = PDFname2
                Else 'process email w/ Word document
                    fileAttach = oWD.Name
                End If
                If fileAttach <> "" Then
                    Call processEmail(OutApp, eMail_Col("emailTo").obj, eMail_Col("emailSubject").obj, eMail_Col("emailBody").obj, fileAttach)
                End If
            End If
            'clean up before next pass
            BM_col.RemoveAll
            Set BM_col = Nothing
            If Not eMail_Col Is Nothing Then 'prepare for next eMail address, if we're emailing
                eMail_Col.RemoveAll
                Set eMail_Col = Nothing
            End If
        Next lLoop
        MsgBox "Successful ExcelToWord! production process", vbOKOnly
    Else
        MsgBox "Template file: " & strWD_TemplateBMFile & " not found at " & fPath & " - please create Template and try again", vbCritical, "Aborting"
    End If
    GoTo gracefulExit
backToUserform:
    xMsg = MsgBox(validError & vbCrLf & vbCrLf & "Open Configuration Options to make changes?", vbYesNo, _
        "Configurator Error: Hit YES to pull up Configuration Options, NO to Abort")
gracefulExit:
    If Not bDraftPreview Then 'only if successful generation of draft will this be skipped
        'clean up open word document and application, if any
        If Not oWD Is Nothing Then oWD.Close savechanges:=False
        If Not oWA Is Nothing Then oWA.Quit
    End If
    BM_col.RemoveAll
    If bPasteEnhMeta Then MsgBox "Could not paste all objects according to style selected, so pasted as Enhanced Metafile, instead"
End Sub
'Private Function searchRangeShapes(BM_col As BM_Indicators, bkMk As Word.Bookmark, bXL_SpanWorkbook As Boolean) As Boolean 'early binding
Private Function searchRangeShapes(BM_col As BM_Indicators, BkMk As Object, bXL_SpanWorkbook As Boolean) As Boolean 'late binding
Dim wkb As Workbook
Dim cht As Chart
Dim myActWks As Worksheet
Dim rName As Name
Dim shp As Shape
Dim strSearch As String
Dim xMsg As Long
Dim myQuote_char As String
    Set myActWks = wkb.ActiveSheet
    'Search for Range name matching Excel Bookmark Indicator name, at ActiveSheet level, then Workbook level, exiting on first instance found
    If Not bXL_SpanWorkbook Then 'search within ActiveSheet scope, only
        If InStr(myActWks.Name, SPACE_CHAR) <> 0 Then
            myQuote_char = QUOTE_CHAR
        Else
            myQuote_char = vbNullString
        End If
        strSearch = UCase(myQuote_char & myActWks.Name & myQuote_char & "!" & BkMk.Name)
        Set rName = myActWks.Names(strSearch)
        If Err.Number = 0 Then
            BM_col.Add BkMk.Name, rName, RANGE_NAME
            searchRangeShapes = True
            Exit Function 'stop when first instance is found
        End If
        On Error GoTo 0
    Else
        Set rName = wkb.Names(BkMk.Name)
        End If
        On Error GoTo 0
        'finally, find first range name that matches at the worksheet level - span workbook has workbook level name priority,
        'then worksheet name, starting with activesheet as priority
        'Check ActiveSheet
        Else
        End If
        End If
        On Error GoTo 0
        'now check the rest of the sheets
        For Each wks In wkb.Worksheets
            If wks.Name <> myActWks.Name Then
                If InStr(wks.Name, SPACE_CHAR) <> 0 Then
                Else
                End If
                strSearch = UCase(myQuote_char & wks.Name & myQuote_char & "!" & BkMk.Name)
                Set rName = wks.Names(strSearch)
                End If
                On Error GoTo 0
            End If
        Next wks
    End If
    'if we didn't find it in a Range, then let's look at shapes - e.g., charts, images, and other assorted shapes, using the Shapes collection
    'search workbook_level names, then worksheet names, on every sheet, until found
        Set shp = myActWks.Shapes(BkMk.Name)
            If shp.Type = msoChart Then 'embedded chart
                BM_col.Add BkMk.Name, shp, CHART_EMB
            Else
                BM_col.Add BkMk.Name, shp, SHAPE_OBJ
            End If
        End If
        On Error GoTo 0
        'Chart sheets can exist, even though bXL_SpanWorkbook is false, so test for those
        Set cht = wkb.Charts(BkMk.Name)
            BM_col.Add BkMk.Name, cht, CHART_OBJ
            Exit Function
        End If
        On Error GoTo 0
    Else    'search workbook_level shape names, then worksheet shape names, on every sheet
            'check for chart sheet, first
            Exit Function
        End If
        'then look at embedded shapes at the worksheet level
            Set shp = wks.Shapes(BkMk.Name)
                Else
                End If
            End If
        Next wks
    End If
    'otherwise, fail out
End Function
Private Function searchCells(BM_col As BM_Indicators, strBkMk As String, bXL_SpanWorkbook As Boolean) As Boolean
Dim fRange As Range
Dim wkb As Workbook
Dim focusRange As Range
    'routine searches for Excel bookmark indicators, identifying each corresponding data-point adjacent to the indicator inside the BM_Indicators class collection
        If bXL_SpanWorkbook Or (bXL_SpanWorkbook = False And wks.Name = myActWks.Name) Then 'search all worksheets, or active sheet
            Set fRange = wks.Cells.Find(what:="[[" & strBkMk & "]]", LookIn:=xlValues, lookat:=xlWhole)
            If Not fRange Is Nothing Then
                Select Case strXL_TemplOptCell
                    Case "Left": Set focusRange = fRange.Offset(0, 1)
                    Case "Above": Set focusRange = fRange.Offset(1, 0)
                    Case "Right": Set focusRange = fRange.Offset(0, -1)
                    Case "Below": Set focusRange = fRange.Offset(-1, 0)
                End Select
                    MsgBox "You indicated bookmark indicators would be adjacent " & UCase(strXL_TemplOptCell) & " of the data, while bookmark indicator " & strBkMk & " at " & "'" & fRange.Worksheet.Name & "'!" & fRange.Address & " throws an error when that offset is performed." & vbCrLf & vbCrLf & "Please recast bookmark: " & strBkMk, vbCritical, "Aborting..."
                    searchCells = False
                    Exit Function
                End If
                On Error GoTo 0
                BM_col.Add strBkMk, focusRange, RANGE_OBJ
                searchCells = True
            End If
        End If
    Next wks
End Function
'Private Function pastePicToBkMk(oWA As Word.Application, myObjCopy As Object, bkMk As Word.Bookmark) As Boolean 'early binding
Private Function pastePicToBkMk(oWA As Object, myObjCopy As Object, BkMk As Object) As Boolean 'late binding
Dim strTmpPicFile As String
Dim r As Object
'logic to change bookmark shape fill effects, importing temporary image
    On Error GoTo errHandler
    'first, save the image to a temporary file
    strTmpPicFile = export(myObjCopy)
    'then, navigate to the bookmark, and change the fill effects, importing the image
    'no line around shape and ensure picture fits re: aspect ratio
    r.ShapeRange.Fill.Transparency = 0#
    r.ShapeRange.Line.Visible = msoFalse
    r.ShapeRange.LockAspectRatio = msoFalse
    'replace recorded filename with temporary file name just generated
    r.ShapeRange.Fill.UserPicture strTmpPicFile
    pastePicToBkMk = True
    GoTo gracefulExit
errHandler:
    pastePicToBkMk = False
gracefulExit:
    Kill strTmpPicFile 'delete temporary file
    On Error GoTo 0
End Function
Here’s the code for the Export of Excel Shape/Image/Charts to a JPEG file and updating of a corresponding Word Shape via Fill method:
'Source Adapted from: http://www.experts-exchange.com/Software/Office_Productivity/Office_Suites/MS_Office/Excel/Q_27403520.html
'May have originated from other cites:
'   http://www.jpsoftwaretech.com/blog/2009/04/export-excel-range-to-a-picture-file-redux/, or
'   http://peltiertech.com/WordPress/export-chart-as-image-file/
Public Function export(shp As Object) As String
Dim pic_object As Shape
Dim pic_height As Double
Dim pic_with As Double
Dim fName As String
Dim tmp_object As Chart
'Exports Shape/Image/Chart to a JPG file by first pasting it into a temporary chart object, then exporting that object as a JPG file
    Set pic_object = Workbooks(shp.Parent.Parent.Name).Sheets(shp.Parent.Name).Shapes(shp.Name)
    fName = ActiveWorkbook.path & "\" & pic_object.Name & ".png"
    pic_height = pic_object.Height
    pic_width = pic_object.Width
    pic_object.CopyPicture appearance:=xlScreen, Format:=xlPicture
    Set tmp_object = ActiveSheet.ChartObjects.Add(1, 1, pic_object.Width, pic_object.Height).Chart
    With tmp_object
        .ChartArea.Border.LineStyle = 0
        .Paste
        .export filename:=fName
        .Parent.Delete
    End With
    export = fName
End Function
In Excel, the BM_Indicators is a collection of BM_Indicator, with three properties:  Name, Obj, and Type.  Obj contains the Cell reference, Range Name, Shape/Image/Chart, or Chart_Sheet object representing each type of Excel bookmark indicator.  I used matthewspatrick’s Parent Class Builder add-in to generate the starting point for the class modules (see:  http://www.experts-exchange.com/Software/Office_Productivity/Office_Suites/MS_Office/Excel/A_3802-Parent-Class-Builder-Add-In-for-Microsoft-Excel.html?sfQueryTermInfo=1+30+builder+class+parent).
And, finally, here’s the Configuration Options panel data handling routines that maintain a cadre of settings that are saved at the workbook and worksheet level, via hidden range names:
Option Explicit
'Configurator Options --------------------
Public Const CONFIG_SETTINGS = "ETW_strWD_TemplOpt,ETW_bWD_Table,ETW_strWD_TemplFile,ETW_strWD_TemplateBMFile,ETW_strXL_TemplOpt,ETW_strXL_TemplOptShapePaste,ETW_strXL_TemplOptCell,ETW_bXL_SpanWorkbook,ETW_bXL_Increment,ETW_strXL_RefCounter,ETW_strXL_RefStart,ETW_strXL_RefEnd,ETW_bAftUpdPrint,ETW_bAftUpdPDF,ETW_bAftUpdSave,ETW_strAftUpdEmail,ETW_bAftUpdDelete,ETW_bAftUpdPreview,ETW_strWD_DocPath,ETW_strWD_DocFile,ETW_bSaveConfig"
Public Const RANGE_REF = "ETW_strXL_RefCounter,ETW_strXL_RefStart,ETW_strXL_RefEnd"
Public Const ChartShapeImagePasteOptions = "wdPasteBitmap,wdPasteDeviceIndependentBitmap,wdPasteEnhancedMetafile,wdPasteMetafilePicture,wdPasteOLEObject"
Public Const EmailWordOrPDFOptions = ",eWord,ePDF"
Public iXL_TemplOptShapePaste As Integer
Public Const adjacent = "Left,Above,Right,Below" '0,1,2,3.  0-Default = Left
Public Const CONFIG_SCOPE = "ETW_ConfiguratorScope"
Public Const CONFIG_SHEET = "ETW_ConfigSheet"
Public Const NAME_VISIBLE = False 'whether config names are visible or not - TRUE for debug purposes, only
Public strWD_TemplOpt As String 'Word template options:  User created "OWN", "GENERIC", or "INTELLIGENT" bookmarks
Public bWD_Table As Boolean 'TRUE: User has a 1-to-many row table, with bookmarks indicators embedded.  Option to delete empty rows from table, during processing
Public strWD_TemplFile As String 'Original word template - the starting point
Public strWD_TemplateBMFile As String 'Generated Word template, with bookmarks either user/system generated
Public strXL_TemplOpt As String 'Excel template options: User created named ranges/shapes, bookmark indicators to the left/above/right/below of data, or both
Public strXL_TemplOptShapePaste As String 'option for Picture or OLE Object link to Excel with shape paste (e.g., chart)
Public strXL_TemplOptCell As String 'bookmark indicators to the left, above, right, or below the data
Public bXL_SpanWorkbook As Boolean 'True - configuration options span entire workbook, as opposed to active sheet
Public bXL_Increment As Boolean 'True - Update Word from Excel will cycle based on counter, start & end point
Public strXL_RefCounter As String
Public strXL_RefStart As String
Public strXL_RefEnd As String
Public bAftUpdPrint As Boolean 'True - print after Word document is updated
Public bAftUpdPDF As Boolean 'True - PDF file will be extracted after Word template is updated
Public bAftUpdSave As Boolean 'True - Word document will be saved from Word template
Public bAftUpdDelete As Boolean 'True - Word document will be deleted after the update process (e.g., after printing or PDF process, etc.
Public strAftUpdEmail As String 'ePDF or eWord - Will email the PDF or Word output, as selected
Public bAftUpdPreview As Boolean 'True - just preview Word Draft after generation (only the 1st generated document)
Public strWD_DocPath As String 'path for saving Word document
Public strWD_DocFile As String 'Word document filename
Public bSaveConfig As Boolean 'True - save Configuration Options for next step
Public Const WORDDOC_PATH = "ETW_WordDocPath" 'stores the last path the user selected when browsing to set a word document path
Public Const WORDTMPL_PATH = "ETW_WordTemplPath" 'stores the last path the user selected when browsing for a word template
Public Const oWA_VISIBLE = False 'True - Word application will be visible during automation
Public Const SPACE_CHAR = " "
Public Const QUOTE_CHAR = "'"
Public closeOut As Boolean
'-------------------------------- Late Binding variables needed ------------------------------
Public Const wdPasteEnhancedMetafile = 9
Public Const wdPasteBitmap = 4
Public Const wdPasteDeviceIndependentBitmap = 5
Public Const wdPasteMetaFilePicture = 3
Public Const wdPasteOLEObject = 0
Public Const wdGoToBookmark = -1
Public Const wdInLine = 0
Public Const wdExportFormatPDF = 17
Public Const wdExportOptimizeForPrint = 0
Public Const wdExportAllDocument = 0
Public Const wdExportDocumentContent = 0
Public Const wdExportCreateNoBookmarks = 0
Public Const wdRelativeHorizontalPositionColumn = 2
Public Const wdRelativeVerticalPositionParagraph = 2
Public Const wdRelativeHorizontalSizePage = 1
Public Const wdRelativeVerticalSizePage = 1
Public Const wdShapePositionRelativeNone = -999999
Public Const wdShapeSizeRelativeNone = -999999
Public Const wdWrapBoth = 0
Public Const wdFindContinue = 1
Public Const wdReplaceOne = 1
Public Const wdSortByName = 0
Public Const xlOpenXMLAddIn = 55 'for pre-Excel 2007
Public Sub showConfigurator(Optional control As Object) 'IRibbonControl
        Exit Sub
    End If
    Else
        Load Configurator
        Configurator.Show
    End If
End Sub
Public Sub initializeConfiguratorOptions()
Dim strNamedScope As String
Dim tmpVar As Variant
Dim bEvalSheet As Boolean
    'Initial Configuration Settings into Public Variables
    strNamedScope = myEvaluate(CONFIG_SCOPE)
    bEvalSheet = myEvaluate(CONFIG_SHEET)
    On Error GoTo 0
    'determine if any Configuration Settings exist
    If (strNamedScope = "Worksheet" And bEvalSheet) Or (strNamedScope = "Workbook" And Not bEvalSheet) Then 'there are settings at Workbook or this sheet's scope
    Else 'there were no saved settings in the Workbook, or on the Active Sheet
        Call baseInitialization
    End If
End Sub
Public Sub setPublicVariables()
Dim varConfig As Variant
Dim i As Integer
    varConfig = Split(CONFIG_SETTINGS, ",")
    For i = 0 To UBound(varConfig)
        If InStr(UCase(RANGE_REF), UCase(varConfig(i))) <> 0 Then 'get range object, as opposed to string value
            Set tmpVar = myEvaluate(varConfig(i))
                GoTo errHandler
            End If
            tmpVar = "'" & tmpVar.Worksheet.Name & "'!" & tmpVar.Address
        Else
        End If
        Call setVar(varConfig(i), tmpVar)
errHandler:
        On Error GoTo 0
    Next i
End Sub
Private Sub baseInitialization()
    bWD_Table = False
    strWD_TemplFile = vbNullString
    strXL_TemplOpt = "RANGE"
    strXL_TemplOptShapePaste = "wdPasteEnhancedMetafile"
    iXL_TemplOptShapePaste = wdPasteEnhancedMetafile
    strXL_TemplOptCell = "Left"
    bXL_SpanWorkbook = IIf(myEvaluate(CONFIG_SCOPE) = "Worksheet", False, True) 'in case another sheet already has options saved
    bXL_Increment = False
    strXL_RefCounter = vbNullString
    strXL_RefStart = vbNullString
    strXL_RefEnd = vbNullString
    bAftUpdPrint = False
    bAftUpdPDF = False
    bAftUpdSave = True
    strAftUpdEmail = vbNullString
    bAftUpdPreview = False
    bAftUpdDelete = False
    bSaveConfig = False
End Sub
Public Function validateFileFolderSelection(ByVal fName As String, fType As String, src As String, bFolderOnly As Boolean) As Boolean
    validateFileFolderSelection = True
    'Test for word or excel filename & that the file exists
    If Trim(fName) = vbNullString Then
        validateFileFolderSelection = False
    ElseIf bFolderOnly Then
        If Not FSO.FolderExists(fName) Then
        End If
    ElseIf Not FSO.fileExists(fName) Then
    End If
End Function
Public Function browseForTemplate(strPath As String, strFilter1 As String, strFilter2, strTitle As String, bgetFolderOnly) As String
Dim dialogFile As FileDialog
Dim fName As String
    ' Open the file dialog
    Set dialogFile = Application.FileDialog(IIf(bgetFolderOnly, msoFileDialogFolderPicker, msoFileDialogFilePicker))
    With dialogFile
        If Not bgetFolderOnly Then
            .Filters.Clear
            .Filters.Add strFilter1, strFilter2, 1
        End If
        .AllowMultiSelect = False
        .InitialView = msoFileDialogViewDetails
        .InitialFileName = strPath
        .Title = strTitle
        .Show
    End With
    If dialogFile.SelectedItems.Count > 0 Then
        browseForTemplate = dialogFile.SelectedItems(1)
    Else
        browseForTemplate = ""
    End If
    'cleanup
    Set dialogFile = Nothing
End Function
Public Function getVar(strRef As Variant) As Variant
    Select Case strRef
        Case "ETW_strWD_TemplOpt":              getVar = strWD_TemplOpt
        Case "ETW_bWD_Table":                   getVar = bWD_Table
        Case "ETW_strWD_TemplFile":             getVar = strWD_TemplFile
        Case "ETW_strWD_TemplateBMFile":        getVar = strWD_TemplateBMFile
        Case "ETW_strXL_TemplOpt":              getVar = strXL_TemplOpt
        Case "ETW_strXL_TemplOptShapePaste":    getVar = strXL_TemplOptShapePaste
        Case "ETW_strXL_TemplOptCell":          getVar = strXL_TemplOptCell
        Case "ETW_bXL_SpanWorkbook":            getVar = bXL_SpanWorkbook
        Case "ETW_bXL_Increment":               getVar = bXL_Increment
        Case "ETW_strXL_RefCounter":            getVar = strXL_RefCounter
        Case "ETW_strXL_RefStart":              getVar = strXL_RefStart
        Case "ETW_strXL_RefEnd":                getVar = strXL_RefEnd
        Case "ETW_bAftUpdPrint":                getVar = bAftUpdPrint
        Case "ETW_bAftUpdPDF":                  getVar = bAftUpdPDF
        Case "ETW_bAftUpdSave":                 getVar = bAftUpdSave
        Case "ETW_bAftUpdDelete":               getVar = bAftUpdDelete
        Case "ETW_strAftUpdEmail":              getVar = strAftUpdEmail
        Case "ETW_bAftUpdPreview":              getVar = bAftUpdPreview
        Case "ETW_strWD_DocPath":               getVar = strWD_DocPath
        Case "ETW_strWD_DocFile":               getVar = strWD_DocFile
        Case "ETW_bSaveConfig":                 getVar = bSaveConfig
    End Select
End Function
Private Function setVar(strRef As Variant, myVal As Variant) As String
    Select Case strRef
        Case "ETW_strWD_TemplOpt":              strWD_TemplOpt = myVal
        Case "ETW_bWD_Table":                   bWD_Table = myVal
        Case "ETW_strWD_TemplFile":             strWD_TemplFile = myVal
        Case "ETW_strWD_TemplateBMFile":        strWD_TemplateBMFile = myVal
        Case "ETW_strXL_TemplOpt":              strXL_TemplOpt = myVal
        Case "ETW_strXL_TemplOptShapePaste":    strXL_TemplOptShapePaste = myVal
                                                iXL_TemplOptShapePaste = setVarShapePaste(myVal)
        Case "ETW_strXL_TemplOptCell":          strXL_TemplOptCell = myVal
        Case "ETW_bXL_SpanWorkbook":            bXL_SpanWorkbook = myVal
        Case "ETW_bXL_Increment":               bXL_Increment = myVal
        Case "ETW_strXL_RefCounter":            strXL_RefCounter = myVal
        Case "ETW_strXL_RefStart":              strXL_RefStart = myVal
        Case "ETW_strXL_RefEnd":                strXL_RefEnd = myVal
        Case "ETW_bAftUpdPrint":                bAftUpdPrint = myVal
        Case "ETW_bAftUpdPDF":                  bAftUpdPDF = myVal
        Case "ETW_bAftUpdSave":                 bAftUpdSave = myVal
        Case "ETW_bAftUpdDelete":               bAftUpdDelete = myVal
        Case "ETW_strAftUpdEmail":              strAftUpdEmail = myVal
        Case "ETW_bAftUpdPreview":              bAftUpdPreview = myVal
        Case "ETW_strWD_DocPath":               strWD_DocPath = myVal
        Case "ETW_strWD_DocFile":               strWD_DocFile = myVal
        Case "ETW_bSaveConfig":                 bSaveConfig = myVal
    End Select
    On Error GoTo 0
End Function
Private Function setVarShapePaste(strOpt As Variant) As Integer
'I selected what I thought the most relevant of paste options in Word parlance, with several physical picture options, and a link option to the original workbook
    Select Case strOpt
        Case "wdPasteBitmap":                   setVarShapePaste = wdPasteBitmap
        Case "wdPasteDeviceIndependentBitmap":  setVarShapePaste = wdPasteDeviceIndependentBitmap
        Case "wdPasteEnhancedMetafile":         setVarShapePaste = wdPasteEnhancedMetafile
        Case "wdPasteMetafilePicture":          setVarShapePaste = wdPasteMetaFilePicture
        Case "wdPasteOLEObject":                setVarShapePaste = wdPasteOLEObject
    End Select
End Function
Public Sub resetConfigurator()
Dim i As Integer
    'deletes all Configurator references in Workbook - at Workbook and Sheet-level
    ActiveWorkbook.Names(CONFIG_SCOPE).Delete
    ActiveWorkbook.Names(WORDDOC_PATH).Delete
    ActiveWorkbook.Names(WORDTMPL_PATH).Delete
    'delete at Workbook Scope, if any
        ActiveWorkbook.Names(varConfig(i)).Delete
    Next i
    'delete at Worksheet Scope, if any
    For Each wks In ActiveWorkbook.Worksheets
        wks.Names(CONFIG_SHEET).Delete
            wks.Names(varConfig(i)).Delete
        Next i
    Next wks
    On Error GoTo 0
End Sub
Credits:  I've cited anything I "retooled" off the web in the source code, but I would draw out a couple special acknowledgements as the following sources were instrumental in enabling a more robust result (without having to build from scratch):
Exporting Excel Range to Picture:
Emailing Attachments via Outlook - Ron deBruin @ http://www.rondebruin.nl/mail/folder2/files.htm
I learned a lot in the development process:  from the initial three building-block solutions with LANCE_S_P and creativefusion, through to developing this complete, automated solution which I hope you will find useful.  The tool is feature-rich with more bells and whistles than I had originally anticipated, but as I was writing the article and enhancing the code, new ideas that came to mind that just had to be developed (at times, I found myself documenting features ahead of tool development!).
Enjoy!
Attachment I:   Attached, please find the ExcelToWord! Add-In which provides the functionality described in this article to your existing projects. The .xla is for all users (tested Office 2002+), while the .xlam is for Excel 2007+ users, and leverages the Ribbon for menu options.
  ExcelToWordv011.xlam ExcelToWordv011.xla
Attachment II:    Also attached, please a cadre of Word and Excel templates used for testing, as well as the demo Word and Excel templates used in this article.  You can learn ExcelToWord! starting with these example templates, today!
 Test-Examples---Excel-and-Word-t.zip
Kudos to matthewspatrick for his Word template, used in the writing of this article.  (and aikimark for spreading the word!)
If you liked this article and want to see more from this author,  please click here.
If you found this article helpful, please click the Yes button near the:
      Was this article helpful?
59
Author:dlmille
32 Comments
LVL 38
Expert Comment
by:younghv
Very well written article.
Voted "Yes" above and looking forward to more from this author.
LVL 18
Expert Comment
by:WaterStreet
Voted Yes, above.
Something I could have used years ago.  Should be help to others now.
LVL 42
Author Comment
by:dlmille
Many thanks.  As a matter of fact, I've got a working prototype for ExcelToPPT! working right now.  Its more straightforward given the nature of the beast, but much the same flavor.
Cloud Class® Course: Amazon Web Services - Basic
Are you thinking about creating an Amazon Web Services account for your business? Not sure where to start? In this course you’ll get an overview of the history of AWS and take a tour of their user interface.
Expert Comment
by:LFROEH2
This has been very very helpful! I have to generate hundreds of offer letters to new hires at my job. Now I've created an offer letter word template with bookmarks in the fields that need to be personalized and I've been able to use a row of data from the excel spread sheet to generate a completely filled out offer letter with this method. HOWEVER, I can only get it to work with the top row of data. I can't seem to figure out how to generate a populated word template with the subsequent rows with other people's information; only the first row of data appears functional. Any ideas how to get around this??
Thanks!!!
Expert Comment
by:DMurray3
Great Article and code... Saved me a bundle of manual work. I have your add-in working fine. One question: I am trying to automate invoice generation leveraging on your code. I was wondering if you could advise how to include the "Update Word with Excel Data" in a macro so that my users can use a "button" to run the "Update Word..." instead of having to open the ribbon.
Again, many thanks for your contribution.
Expert Comment
by:dannyjoer
This is a real nice article, very helpful. Thx for posting David.
However, I run into a problem that I don't have the skills to debug, and I can't see the system in the error occuring. Sometimes the ExcelToWord! works, and other times it don't.
The error occurs after I have done my Configuration Options. I have manually inserted Bookmarks in my Word Doc Template, so I jump directly to Update Word!. Then the system (sometimes) tells me that I haven't done the configuration part of the process and therefor jumps to that userform. And other times it jumps right through and updates the word doc perfectly.
Can any of you guys tell out of the blue sky what is wrong? I will attach the two files I am trying to get to talk to each other. The Bookmarks in the Excel file is in the RowToCopy sheet..
Best Regards
Danny
OrderFormRev5.xlsm
Order-FormRev2.dotx
Expert Comment
by:Jakob Løve
This is what we have been waiting for!:-)
Anyhow, an introduction the configuration settings may be useful. I cannot get the Word doc path working...I keep getting an error message from the configurator.
Please assist with!
Could you make a video?
Thanks!
BR Jakob
Expert Comment
by:jamesbunnett
Does anyone know how to amend the code to get around the 255 character limit?
I'm getting an error as soon as my source data in the excel is over this size.  I can post the debugger if that helps.
J
Expert Comment
by:mkrahulec
Very well written article! I only found one drawback to this implementation, it does not appear that 'bookmarks' entered into the footer or header are found during the replacement process...
My suspicion is that Word does not accept bookmarks in the header or footer and this is preventing the process from working but if that is not the case, this might be a logical enhancement.
Expert Comment
by:V B
i was looking for something like this and this article/solution delivers just that and even more
VB
Expert Comment
by:Ricardo Coghlan
Great solution to a very special problem! I am working out some reporting that has some graphics in it. The graphic itself must be incremental on each report. Do you have a proposal for the graphic generation? I also want to add an image corresponding to the report I am generating, which will vary from report to report.
Thanks a lot in advance!
RC
Expert Comment
by:CallMeMaybe
Many thanks, this is the perfect solution that I needed. But, is there a way to add my clients logo into an excel cell, and have that populate into my word documents? Or is this strictly for text?
Expert Comment
by:MareAngerjarv
I have been looking for a solution to replace copy-paste from excel to word and it seems that I have found it! Unfortunately I can't get it to work. I downloaded the example files and managed to go through some of the examples. But as I start changing any content with my own, then even the simplest test fails.
I am using Excel 2016. The problem is the same every time - I save the configuration, but the info doesn't save itself - if I try to generate word bookmarks, the add-in gives an error message that the configuration settings are not saved. I added some print screens about what settings I tried to save and what error message I get.
Expert Comment
by:RdA
Great job, found a problem with the Excel named range bookmarks.
When a named range refers to a cell in a table the bookmark data in excel cannot be found.
This problem could be resolved by changing the formula of the named range from:
=Requirements[[#Kopteksten];[Description]]
to:
=INDIRECT("Requirements[[#Kopteksten];[Description]]")
Note: this is an example formula from a Dutch Excel version.
LVL 3
Expert Comment
by:Anthony Minnocci
Hi there,
I have been trying to use the cycle thru functionality and i have not been able to get it to function properly. Is there any article/post that I could be sent to to get it working?
Expert Comment
by:aerend
This seems like a very useful article. Only thing is that once I load the add-in into Excel, it tells me that there is a compile error: variable not defined. Could I be doing something wrong? See screenshot attached.
Many thanks,
Arend
Expert Comment
by:Justin Tudor
Any assistance on an error that stalls Excel when Update Word with Excel Data is pressed? It get's stuck on initializin and an error prompt advises Microsoft Excel is waiting for another application to complete OLE action?
Much appreciated!
LVL 3
Expert Comment
by:DJNafey
This was an extremely helpful article. We'd been trying to find a simple way to do this for over a year at work (it was a low priority issue) and I was so happy when I came across this, and after testing I've found that it does exactly as I want! However, my boss now wants me to verify that it would work on all of our versions of Office (I'm on 2013, he's on 2016 and we have a spare one on 2010). Does anyone either know the answer to this or have a link to the Add-in programmers' website? Many thanks in advance.
LVL 3
Expert Comment
by:Anthony Minnocci
DJNafey,
I have used this on Office 2016 and it worked as expected. I have not tested on 2010, but it should work.
Hope this helps.
LVL 3
Expert Comment
by:DJNafey
Anthony,
Thank you very much. He will be a happy man!
Kind regards.
Expert Comment
by:alex wit
It seems like a beautifull application. But i can't manage to install / get it working with an Windows 10 computer and neither on a Mac. Could it be that Word v16 doesn't work with ExceltoWord!  ?
On both laptops it gives the same error as @aerend  , allready pointed out, that a variable is not defined.
I hope this problem is allready solved.
Thank you for your time and sharing the add -in
LVL 47
Expert Comment
by:aikimark
See if adding this to the routine fixes the problem.
Const xlAddIn = 18
This instrinsic value comes from xlFileFormat constants.  If you press F2, you might be able to search for this value and may be able to get to it through the code window's intellisense functionality (type "xlFileFormat" and then a period)
LVL 47
Expert Comment
by:aikimark
Note to future commenters in this article thread.  The author passed away a couple of years ago.  He isn't able to respond or tweak the code.  You are welcome to tweak the code yourself.  If you do, please post your tweaked code in a comment here for future readers.
Expert Comment
by:Joel Lim
i have identified the configuration settings not saved error to be due to unticked option "Bookmark Indicators span the entire workbook". Keep the option enabled and it should work fine.
Expert Comment
by:Lyra W
This worked amazing on my windows. However, my current employer (at a financial firm, mind you) runs solely on Macs. Is there a mac version of this add-on? It would be much appreciated, and much loved.
Expert Comment
by:Foco Exato
This post is amazing, what a great job!
However what is the security of this utility? I mean, How can I know that data  will not be harvested on my computer???
I did some tests and the word "EXXONMOBIL" was presented on my report???? This is very VERY ODD!
I hadn't type EXONMOBIL in any place whasoever.
Please Could someone explain that?
Expert Comment
by:Regan Harrison
HI,
Anyone in this article been able to get this working in Word/Excel 2016? I have a one page report template in Word with ever changing data in Excel. Anyone able to help?
Expert Comment
by:Duncan O'Donnell
Excellent article thanks so much!!
Expert Comment
by:Jandre Dippenaar
@JamesBunnet on 2015-03-03:
I've found a solution for the 255 character limit. I know nothing about script programming, but I have some programming knowledge in C.
Go to the following area of code:
                        Else
                        End If
All you have to do is comment out the following by adding a ' before two lines:
                            'BkMk.Range.Text = Application.WorksheetFunction.Text(myObjCopy.Value, myObjCopy.NumberFormat)
                        'Else
                        End If
The "Application.WorksheetFunction.Text" function has the 255 limit, by bypassing it you can add more characters. I am not sure what effect removing this will have, but if you are only copying text, I think it will work fine :)
Regards from South Africa,
Jandré Dippenaar
Expert Comment
by:Clarissa Peterson
I can't get the add-in to work. I have Office 2013 so I am using the .xla. Is the link broken?
Expert Comment
by:Adriaan Van Nuffel
I love it! Would be great to have the possibility to change the filename, based on the value of a bookmark.
For example if you add [[bookmark]] in the standard file name. Anyone adding that feature? :-)
Expert Comment
by:فروشگاه اینترنتی
Keep the option enabled and it should work fine. I'm getting an error as soon as my source data in the excel is over this size.
بانه
thanks alot
Get your problem seen by more experts
Be seen. Boost your question’s priority for more expert views and faster solutions
Join & Write a Comment
This Micro Tutorial demonstrates using Microsoft Excel pivot tables, how to reverse engineer competitors' marketing strategies through backlinks.
This Micro Tutorial will demonstrate the scrolling table in Microsoft Excel using the INDEX function.
