List of available Hotfixes 2012-02-20
I was reading through all the hotfixes available for XenApp 6.5, to decide what to add to my new lab environment.
I compiled this quick reference to get access to all important information about the available hofixes and the problems they will solve.
Conclusion:
Don't publish all of the listed updates !
I recommend installing the Hotfixes
GPMx150WX64002 and
GPMx150WX64001by default, you don't like loose any configured polices.
If you like to publish "Additional Communications Software" like Citrix GoToMeeting, Skype, Adobe Connect roll out
XA650W2K8R2X64002 by default.
Public Hotfixes for XenApp 6.5 for Windows Server 2008 R2
Hotfix XA650W2K8R2X64014
1. Reconnect/disconnected to a session is interrupted by a license error and fails.
2. Reconnection to a locked published desktop fails:
"Element Not Found"
"The Network Connection Doesn't Exist"
3. RDP session with a XenApp 6.5 from a Win XP fail when using 29+ char UPN
Link:
http://support.citrix.com/article/CTX131837
Hotfix XA650W2K8R2X64004
1. Apps fail to update time stamp on client files
2. Custom apps fail to overwrite existing files
Link:
http://support.citrix.com/article/CTX130989
Hotfix GPMx150WX64002 (Group Policy Management)
1. GPO priority is not retained after editing/saving
Link:
http://support.citrix.com/article/CTX131456
Hotfix XA650W2K8R2X64011
1. Reconnecting to a disconnected session where the wall paper is set using a GPO, wallpaper is no longer set.
2. No connection to XenApp 6 using a NOERROR lic file
3. When shadowing, win32k.sys, vdtw30.dll files leave the session unresponsive. Session cannot be reset.
Link:
http://support.citrix.com/article/CTX131486
Hotfix HDXWMIPROV620W2K8R2X64001 (For Citrix HDX WMI Provider 2.0)
1. Poor performance when querying HDX WMI Provider on XenApp with 50+ sessions.
Link:
http://support.citrix.com/article/CTX131221
Hotfix XD200DDirector001 (Citrix Desktop Director 2.0)
New Fixes in This Release:
1. Poor performance when querying the HDX WMI Provider on XenApp with 50+ sessions.
2. Shadowing Windows XP (32-bit Edition) fails
Link:
http://support.citrix.com/article/CTX131199
Hotfix XA650W2K8R2X64002 (Support for Additional Communications Software)
In addition to Microsoft Communicator and Lync, this hotfix adds webcam support:
Link:
http://support.citrix.com/article/CTX130971
Hotfix XA650W2K8R2X64001
1. Pass-through authentication fails
Link:
http://support.citrix.com/article/CTX130794
Limited Release Hotfixes for XenApp 6.5 for Windows Server 2008 R2 (Login required!)
LIMITED RELEASE - Hotfix XA650W2K8R2X64012
1. After user's logoff, IMA Service fails
Link:
http://support.citrix.com/article/CTX131702
LIMITED RELEASE - Hotfix XA650W2K8R2X64015
1. Kerberos Pass-through fails using "Unconstrained Delegation".
Unconstrained delegation illustrated
Link:
http://support.citrix.com/article/CTX131911
LIMITED RELEASE - Hotfix XA650W2K8R2X64009
1. In double-hop scenarios, the use of a smart card certificate fails
Link:
http://support.citrix.com/article/CTX131393
LIMITED RELEASE - Hotfix XA650W2K8R2X64006
1. When the "Reboot Schedule randomization interval" GPO is configured, MFCOM service fails and IMA Service fails to start
-> same can happen on pre-staged server, for other reasons!!! See EE Thread
https://www.experts-exchange.com/questions/27591763/IMA-Service-not-starting-on-a-cloned-XenApp-server.html
Link:
http://support.citrix.com/article/CTX131121
LIMITED RELEASE - Hotfix XA650W2K8R2X64005
1. Custom per-window exception-/Seamless per application window registry flags wont' work on XenApp 6 Server 2008 R2.
Link:
http://support.citrix.com/article/CTX131120
LIMITED RELEASE - Hotfix GPMx150WX64001 (Group Policy Management)
1. Existing GPO's are not retained after editing and saving
Link:
http://support.citrix.com/article/CTX131175
LIMITED RELEASE - Hotfix XA650W2K8R2X64008
1. Creation of printers us delayed 2 min. + per printer. Check GPO "Direct connections to print servers."
Link:
http://support.citrix.com/article/CTX131318
LIMITED RELEASE - Hotfix XA650W2K8R2X64007
1. If smart card is present in the card reader, the PIN prompt fails
Link:
http://support.citrix.com/article/CTX131293
LIMITED RELEASE - Hotfix XA650W2K8R2X64017
1. Toolbars of published Apps are only partly visible or not visible at all
Link:
http://support.citrix.com/article/CTX132223
Comments (4)
Commented:Commented:
A frequent form of feedback is users is to vote Yes or No (near the bottom of the article) as to whether the user found the article helpful or not. I'm sure when most users find a helpful article they don't even know or remember to give it a Yes vote for encouraging the author (each Yes also gives 50 points, and every 10 net Yes votes gives and additional 500 points to the author). We Page Editors track Yes votes and No votes, as I believe EE also does.
WaterStreet,
EE volunteer Page Editor
