Solved
sound.sys problem
Posted on 1997-01-15
Last Modified: 2013-12-16
When I boot up my computer I get the message DMA error!  Sound.sys not installed!  Press any key to continue.  If I press a key the system boots up fine, but my sound card doesn't work.  This all started when I unplugged my speakers from the sound card sockets, for some reason this caused the keyboard and mouse to stop responding.  I pressed reset and I've been getting this error message ever since.  I can't find any conflicts (DMA or IRQ), and sound.sys IS in my config.sys file.  What can I do to get my sound card (Sound Blaster Pro) working again?
Question by:Kat010897
1 Comment
LVL 3
Accepted Solution
by:
nedell earned 200 total points
go into device manager and select your sound card and select properties. select the resources tab.
pick a configuration from those available which does not have a high dma value. choose that setting-reboot and see what happens.
also make sure you have a path statement in your autoexec.bat which points to the location of the sound.sys file.
Free Tool: Subnet Calculator
The subnet calculator helps you design networks by taking an IP address and network mask and returning information such as network, broadcast address, and host range.
Recently, I read that Microsoft has analysed statistics for their security intelligence report. It revealed: still, the clear majority of windows users do their daily work as administrator. An administrative account is a burden, security-wise. My ar…
In this modest contribution, I want to share with the IT community (especially system administrators, IT Support Engineers and IT Help Desks) about Windows crashes/hangs and how to deal with these particular problems.
The viewer will learn how to successfully create a multiboot device using the SARDU utility on Windows 7. Start the SARDU utility: Change the image directory to wherever you store your ISOs, this will prevent you from having 2 copies of an ISO wit…
This Micro Tutorial hows how you can integrate  Mac OSX to a Windows Active Directory Domain. Apple has made it easy to allow users to bind their macs to a windows domain with relative ease. The following video show how to bind OSX Mavericks to …
Suggested Courses
571 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
