Check out this week's podcast, "Dairy Farms to Databases: Community's Hand in Technology"Listen Now
Problems with double / multiple buffering for low level wave input
kingpie
kingpie asked
on
Last Modified: 2013-12-04
I am trying to get realtime throughput of the wave input to the wave output in full duplex.  I am using the code suggested by Creative Lab examples.  It works , except that in my MM_WIM_DATA  when I have passed on the buffer to the output, and unprepared the input header, preparing the just received buffer to recycle it for adding into the input queue seems to give problems. Error no. 7 memory alloc error.
here is the code for my mem allocation, start of input, and the function for processing MM_WIM_DATA.
      for (int i = 0; i < MAX_BUFFERS; i++)
            hWaveInHdr[i] = GlobalAlloc(GHND | GMEM_SHARE, sizeof(WAVEHDR));
            lpWaveInHdr[i] = (LPWAVEHDR) GlobalLock(hWaveInHdr[i]);
            hWaveInBuffer[i] = GlobalAlloc(GHND | GMEM_SHARE, BUFFER_SIZE);
            lpWaveInBuffer[i] = (LPSTR) GlobalLock(hWaveInBuffer[i]);
            lpWaveInHdr[i]->lpData = lpWaveInBuffer[i];
            lpWaveInHdr[i]->dwBufferLength = BUFFER_SIZE;
            hWaveOutBuffer[i] = GlobalAlloc(GHND | GMEM_SHARE, BUFFER_SIZE);
            lpWaveOutBuffer[i] = (LPSTR) GlobalLock(hWaveOutBuffer[i]);
            hWaveOutHdr[i] = GlobalAlloc(GHND | GMEM_SHARE, sizeof(WAVEHDR));
            lpWaveOutHdr[i] = (LPWAVEHDR) GlobalLock(hWaveOutHdr[i]);
            lpWaveOutHdr[i]->lpData = lpWaveInBuffer[i];
            lpWaveOutHdr[i]->dwBufferLength = BUFFER_SIZE;
      // Prepare and send input buffers to input device
      nBufferIn = 0;
      nBufferOut = 0;
      for(int i=0; i<MAX_BUFFERS; i++)
            // Prepare wave in header
            if (waveInPrepareHeader(hWaveIn, lpWaveInHdr[i], sizeof(WAVEHDR)))
                  AfxMessageBox("OnPlay-error preparing header");
            // Add buffer to recording queue
            if (waveInAddBuffer(hWaveIn, lpWaveInHdr[i], sizeof(WAVEHDR)))
                  AfxMessageBox("OnPlay-error adding buffer");
            else nBufferIn++;
      // Start the wave input - begin sampling
      waveInStart(hWaveIn);
      CDC* pDC = GetDC();
      pDC->TextOut(100,100,"Wave Started");
      ReleaseDC(pDC);
LONG CCreativeAudioView::OnMMWIMDATA (UINT wParam, LONG lParam)
//  Procedure to handle message from device driver saying it has filled a buffer
//  code from creative labs sample code
 nBufferIn--;
LPWAVEHDR lpWaveHdrTmp;
 lpWaveHdrTemp = (LPWAVEHDR) lParam;
lpWaveHdrTempOut = (LPWAVEHDR) lParam;
waveInUnprepareHeader(hWaveIn, lpWaveHdrTemp, sizeof(WAVEHDR));
// Send received buffer to output queue
    waveOutPrepareHeader(hWaveOut, ((LPWAVEHDR) lParam),sizeof(WAVEHDR));
    waveOutWrite(hWaveOut, ((LPWAVEHDR) lParam), sizeof(WAVEHDR));
      //add another buffer to input queue
//////   THIS IS WHERE THE PROBLEMS COME IN, IT WORKS FOR 16 BUFFERS AND THEN SOUND STOPS AND I GET ERROR 7 EACH TIME I TRY TO PREPARE THE HEADER///////////      ////////////////////////////////////////////////////////
nError = waveInPrepareHeader( hWaveIn, lpWaveHdrTmp, sizeof(WAVEHDR));
if (nError != 0)
      strMessageText.Format("Error preparing next input header %d", nError);
      AfxMessageBox(strMessageText);
waveInAddBuffer(hWaveIn, lpWaveHdrTemp, sizeof(WAVEHDR));
nBufferIn++;
      return 0L;
i'D BE GRATEFUL FOR ANY HELP
Kingpie
Watch Question
Does the waveinunprepareheader always succeed? Do you unprepare the waveout buffers?
This one is on us!
(Get your first solution completely free - no credit card required)
UNLOCK SOLUTION
It seems that waveInUnprepareHeader does always work.  The wave out buffers are unprepared in OnMM_WOM_DONE:
LONG CCreativeAudioView::OnMMWOMDONE (UINT wParam, LONG lParam)
      waveOutUnprepareHeader(hWaveOut, lpWaveHdrTempOut,         sizeof(WAVEHDR));
      return 0L;
      return 0L;
So add buffers to Wave In on MM_WOM_DONE too and everything should be OK.
Good luck!
It works!  thanks very much. (and it makes sense!)
KingPie
Gain unlimited access to on-demand training courses with an Experts Exchange subscription.
Get Access
Why Experts Exchange?
Experts Exchange always has the answer, or at the least points me in the correct direction! It is like having another employee that is extremely experienced.
Jim Murphy
Programmer at Smart IT Solutions
When asked, what has been your best career decision?
Deciding to stick with EE.
Mohamed Asif
Technical Department Head
Being involved with EE helped me to grow personally and professionally.
Carl Webster
CTP, Sr Infrastructure Consultant
Empower Your Career
Did You Know?
We've partnered with two important charities to provide clean water and computer science education to those who need it most. READ MORE
Ask ANY Question
Connect with Certified Experts to gain insight and support on specific technology challenges including:
  • Troubleshooting
  • Research
  • Professional Opinions
Join our community and discover your potential
Experts Exchange is the only place where you can interact directly with leading experts in the technology field. Become a member today and access the collective knowledge of thousands of technology experts.
OR
Please enter a first name
Please enter a last name
