Start Free TrialLog in
Avatar of tomasupp
tomasupp
Finding parts of strings in http stream
I would like to find a way to extract strings from a stream returned from a http component. The strings i am looking for consists of unknown decimal numbers and there exact location is also unknown. The only thing that is known is a short string tag a unknown number av charcters before the wanted stringsegment.
Avatar of Pegasus100397
Pegasus100397
Tommasupp,
Could you post an example of what this string looks like? In general, the more "unknowns" when parsing a string, the more logic has to be built in to make it understandable to the application.
Also, the type of component your using might be relevant here. I have some code that parses strings from an NNTP component if that might be of value to you.
regards,
Pegasus
Avatar of tomasupp
To be more specific I want to find numerical data from html documents to put in my own database. A typical line (not necessairily in the begining of the stream) would be:
306 | <!-- plugg -->AGA A                |  -0.50 |  123.00 | 123.50 | 123.00 | 123.50 | 122.00 |  183025 |  22515630 |  0.38
where the text 'AGA A' is the known 'code' and the wanted numerical value is 123.00 (the first one). The problem is not with the http component. I am able to 'see' the text stream and put it in a memo-component or a textfile etc. I just need som intelligent way to extract the data I want.
Tomas
Pegasus100397
For a quick and relevant answer I give everything I've got...
