Check out our new AWS podcast with Certified Expert, Phil Phillips! Listen to "How to Execute a Seamless AWS Migration" on EE or on your favorite podcast platform. Listen Now
Volume Control Problem with SB64
ap9
ap9 asked
on
Last Modified: 2013-12-16
Hi!  I'm currently using a Sound Blaster 64 and the volume
control seems to be somewhat buggy.  In particular, whenever I restart Windows or reboot the system, the volume setting for Wave is always reset to default (midline).  I checked Creative Labs' site but couldn't seem to find anything specific to the SB64, as far as patches and drivers are concerned.  Any ideas?  It's not a crippling problem, but it is annoying.  Thanks for any help!
Watch Question
Probably not relevant but check autoexec.bat / config sys ????
go to control panal and add/remove program and the on tab windows setup remove de multimedia group. After reboot reinstall it the same way.
You couls also check in the sb setup.
ap9
Sorry, it didn't work.  The WAVE setting still gets reset to
midline when I restart or reboot.  Now I no longer get the
Volume Control icon in the system tray, though, after I reinstalled it.
Unlock this solution and get a sample of our free trial.
(No credit card required)
UNLOCK SOLUTION
ap9
Hmmm, when I installed Win95, I also installed DirectX 5 shortly afterwards.  I'll try again.
Please provide your email to receive a sample view!
OR
Please enter a first name
Please enter a last name
