Check out our new AWS podcast with Certified Expert, Phil Phillips! Listen to "How to Execute a Seamless AWS Migration" on EE or on your favorite podcast platform. Listen Now
Upgrade problem: - ValidateDrive():ERROR: Problem accessing path: H:\*.* (Ldid = 1, Flags = 0)
the_boomerang
on
Last Modified: 2013-12-16
I am currently runing WFW 3.11 and am trying to upgrade to W95. I have tried all sorts of things but keep getting an SU-0014 error in the "Analyzing yout computer" section. I restart and continue in recovery mode but W95 won't start up, I get a eindows protection error and am told I must restart my computer. I can only restart it in Safe Mode.
The only problem I can find in the Control Panel is an unknown monitor type. I have tried setting this to Standard VGA and also tried another monitor but to no avail. I don't even know if the monitor is the problem.
I have tried everything I can think of including reformatting my hard drive and installing on to that but still get the same error.
The last few lines of setuplog.txt (before I retry in recovery mode) are
[Detection]
Detection=Passed
Detection Passed
User chose Continue from DetEr Dlg()
User chose Exit from DetEr Dlg()
Restart=Failed
[Dummy]
Watch Question
boomerang,
I found this in the Microsoft knowledgebase. Not much help, but it's the only reference to SU-0014 I could find.
Windows 95 Setup Err Msg: Warning
                SU-0014...
        Last reviewed: August 21, 1995
        Article ID: Q120388
     The information in this article applies to:
         Microsoft Windows 95
     SYMPTOMS
     During the installation of Windows 95, you receive the following error message:
        Setup Detection Warning
        Warning SU-0014
        Setup has found a hardware device on your computer that is not
        responding. Click Continue to try this device again.
        If problems persist, click Exit Setup, quit all programs, remove
        floppy disks from their drives, and turn your computer off. Then,
        turn your computer on and run Setup again (choose Safe Recovery
        when prompted).
     CAUSE
     This error message can be caused by any of the following conditions:
         The network has stopped responding.
         The CD-ROM has stopped responding.
         The floppy disk drive has stopped responding.
         You no longer have access to the hard disk to complete the installation process.
         An unsupported device has been detected.
     WORKAROUND
     Following the recommendation in the error message (that is, turning off your computer, turning on your computer, and then rerunning Setup selecting Safe Recovery) may correct this problem. If it does not, you must determine which of the above conditions exists and then correct the problem (or problems).
I see the problem seems to be with drive "H". What is the configuration of you drive assignments. In particular, what is your drive H ?
Steve
I recommend to try small thing first: add LASTDRIVE statement to
CONFIG.SYS file (or check its validity). Usually it looks like:
LASTDRIVE=F
where F is your last HD letter+2 (or CD-ROM letter+1).
Unlock this solution and get a sample of our free trial.
(No credit card required)
UNLOCK SOLUTION
It sounds like you are or were using some kind of drive compression software.
From a boot floppy run FDISK to re-partition before re-formatting the hard drive.
Regards,
Ralph
boomerang,
It seems clear that it is your H (cdrom) drive which Windows cannot access.
I found this article in the MS Knowledgebase.
This article lists specific CDROM's that can have problems with Windows 95.
     http://support.microsoft.com/support/kb/articles/q131/4/99.asp
Check to see if your cdrom is listed there. What kind of cdrom do you have ?
Posting your autoexec.bat and config.sys files might help give us a clue.
Steve
Thanks Harley, your suggestion got round my su-0014 problem
Jon
Please provide your email to receive a sample view!
OR
Please enter a first name
Please enter a last name
