How to Control sound card output using VB
I need to be able to turn my sound card on or off depending on the time of day. I can do the time part of the project but I don't know how to control the operation of the soundcard from VB.??
stingrayConnect With a Mentor Commented:
why not try out the control at:
it allows you to actually set the mute of the sound card or set the master volume.
If you are using the Sound Card to do playback MIDI and WAVE files only, thne you can use the API function "waveSetVolume" and "midiSetVolume" found in winmm.dll to set the volume to zero. THis should mute out the Sound Card.
I am still searching for a way to control the master volume myself.  Please update me if you found out anything. Thanks.
Sorry, but it should be "midiOutSetVolume" and "waveOutSetVolume".
You can also use "mmsystem.dll" for the API call. But the arguments seems to be slightly changes.
rfbAuthor Commented:
sorry...this is audio that is fed into the soundcard from another source. Precisely, I'm feeding a radio into the soundcard and broadcasting it on the Internet using a Real Audio Server. There are certain shows on the Radio that I do Not want to broadcast and I want to automate shutting the audio off and turning it on by writing a VB routine that looks at the time and day and makes the decision to allow the broadcast or not.
