Solved
Y2K problem and FIX2000Pro
Posted on 1998-10-16
Last Modified: 2010-04-26
Fix2000Pro by Intelliquis claims that it can solve Y2K problems even for software. this is the claim (an excerp of the advert) :
"In order to do this, Fix2000 analyzes the code in a machine language - a language common to all computer applications. It can then repair the non-compliant code forcing it to properly process dates from any century."
is it possible to alter codes of executables ?
what about command.com and such files ?
how does it actually alter the file itself ?
Question by:ireeny
  • 2
3 Comments
LVL 10
Accepted Solution
by:
rbr earned 40 total points
No, I can't believe that this is possible for all kind of executables. First it is hard to check if a piece of code is valid for the Y2K problem. Second what should be changed: If it is a layout how should the programm know how the data of the layout is stored since any different programming language uses a different way. Third it's a legal problem. You alter a programm and after this you loose any warranty for this programm.
Author Comment
by:ireeny
any idea how Fix2000 can make this claim ? and how do they
actually 'alter' or 'fix' the Y2K problem ?
LVL 10
Expert Comment
by:rbr
Sorry, i don't know the programm.
Will You Be GDPR Compliant by 5/28/2018?
GDPR? That's a regulation for the European Union. But, if you collect data from customers or employees within the EU, then you need to know about GDPR and make sure your organization is compliant by May 2018. Check out our preparation checklist to make sure you're on track today!
This article will show how Aten was able to supply easy management and control for Artear's video walls and wide range display configurations of their newsroom.
For years I have put up with a wireless mouse that consistently disappears or is non-responsive.  This is the story of how I discovered it wasn't really the mouse!
Kernel Data Recovery is a renowned Data Recovery solution provider which offers wide range of softwares for both enterprise and home users with its cost-effective solutions. Let's have a quick overview of the journey and data recovery tools range he…
Suggested Courses
590 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
