Solved
Problem with Print Info box....!
Posted on 1998-11-05
Last Modified: 2010-04-30
  When printing, I have a pop up print info box and shows the progress and also a CANCEL button to cancel printing.
Code :
     frmPrint.show
     ' print coding
     unload frmprint
My problem is that the frmprint shows up like it is suspended and it doesn't respond to any input/clicks until it is unloaded. This might be because the main form is geting the focus since the printing code loop is executing.
So I showed frmPrint as vbmodal as it pops up clearly and accepts all clicks ( eg. cancel) BUT it doesn't close down at all by itself. I believe this is becasue control is tranferred to the frmPrint (vbmodal  and the code doesn't resume back to the main form until the vbmodal form is closed. How do I solve this?
I tried Winapi's like Bringwindowtotop but there is no diff.
Thanks!! ( and sorry, lack of points )
Question by:Haho2
[X]
Welcome to Experts Exchange
Add your voice to the tech community where 5M+ people just like you are talking about what matters.
  • Help others & share knowledge
  • Earn cash & points
  • Learn & ask questions
2 Comments
Accepted Solution
by:
qizhizhu earned 10 total points
Try WINAPI32 to get the frmPrint.show active first, then get the button focus. I need WINAPI32 somthing like GetActiveWindows or CurrentWindows function (Look for VB Help for detail) to get active window.
Regards
Qizhi zhu
Expert Comment
by:sonalchouhan
hi
does the print coding tell yiou how MANY PAGES WERE PRINTED
IF SO PL SEND THE CODE TO ME
I AM IN NEED I WANT TO KNOW THE NO OF PAGES PRINTED BY THE PRINTER
THANKS
U CAN MAIL ME AT
sonal_chouhan@hotmail.com
Enroll in June's Course of the Month
June's Course of the Month is now available! Every 10 seconds, a consumer gets hit with ransomware. Refresh your knowledge of ransomware best practices by enrolling in this month's complimentary course for Premium Members, Team Accounts, and Qualified Experts.
When designing a form there are several BorderStyles to choose from, all of which can be classified as either 'Fixed' or 'Sizable' and I'd guess that 'Fixed Single' or one of the other fixed types is the most popular choice. I assume it's the most p…
I was working on a PowerPoint add-in the other day and a client asked me "can you implement a feature which processes a chart when it's pasted into a slide from another deck?". It got me wondering how to hook into built-in ribbon events in Office.
Get people started with the process of using Access VBA to control Excel using automation, Microsoft Access can control other applications. An example is the ability to programmatically talk to Excel. Using automation, an Access application can laun…
This lesson covers basic error handling code in Microsoft Excel using VBA. This is the first lesson in a 3-part series that uses code to loop through an Excel spreadsheet in VBA and then fix errors, taking advantage of error handling code. This l…
695 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
