Solved
JTable
Posted on 1998-12-01
7
Last Modified: 2009-12-27
I am displaying a sql query in a JTable.  My gui has two buttons: one to clear the table and the other to select which query the user wants to run. (I am using combo boxes to allow the choice.  I am using the following loop to clear the table:
int numRows = sdfTableModel.getRowCount();
if numRows>0)
    for(int i = numRows-1; i>=0; i--)
        defaultTableModel.removeRow(i);
The problem is I have two seperate tables.  The first table works fine, the second table is funky.  When you push the clear button the textfields will clear(I added that in to see if it was reaching the method) but the table wont clear..Unless you switch to another screan and then go back, the table is clear.  Or if you move the scrollbar the table clears what is not visible.  Please help.  Any Ideas??????
Thanks.....
Question by:psteph
  • 2
  • 2
  • 2
  • +1
7 Comments
LVL 16
Expert Comment
by:heyhey_
it looks like you have one model with two views or some other related problem (your model cleares, but it does not informs the view)
we can help you better if post the whole UI related code ... (or even better if you post the whole code :) - please isolated COMILABLE example
LVL 16
Expert Comment
by:heyhey_
and maybe it will be much more effective if you use
 public void setDataVector(Object newData[][], Object columnIds[])
for clearing the table model
hope this helps
  heyhey
Expert Comment
by:marss
sounds like you need the AbstractTableModel:
  void fireTableChanged(TableModelEvent e)
or somthing like that...
We value your feedback.
Author Comment
by:psteph
Im a little confused could you give me some code ex, with these methods?
Author Comment
by:psteph
Here is how I am setting up both of my tables:
String ColumnNames[] ={"one", "two", "three"}
DefaultTableModel TableModel = new DefaultTableModel(ColumnNames, 0);
JTable table = new JTable(TableModel);
Accepted Solution
by:
marss earned 400 total points
import java.util.*;
import java.sql.*;
import javax.swing.table.AbstractTableModel;
import javax.swing.event.TableModelEvent;
    This Adapter is used as a 'bridge' between some database and
    JTable.
    usage is
        JTable table = new JTable(MyAdapter);
public class MyAdapter extends AbstractTableModel {
      int numberOfColumns;
    String[] columnNames = {};
    Vector dataRows = new Vector();
    String defaultQuery;
    public MyAdapter(String url, String driverName, String user, String passwd, String query)
            toolkit = Toolkit.getDefaultToolkit();
        try {
            Class.forName(driverName);
            connection = (OracleConnection) java.sql.DriverManager.getConnection(url, user, passwd);
            statement = (OracleStatement) connection.createStatement();
        catch (ClassNotFoundException ex) {
        catch (java.sql.SQLException ex) {
    public void executeQuery(String query) {
        try {
            resultSet = statement.executeQuery(query);
            metaData = resultSet.getMetaData();
            numberOfColumns =  metaData.getColumnCount();
            columnNames = new String[numberOfColumns];
            // Get the column names and cache them.
            // Then we can close the connection.
            for(int column = 0; column < numberOfColumns; column++) {
                columnNames[column] = metaData.getColumnLabel(column+1);
            //clear current
                currentRow.addElement(null);
            // Get all rows.
            rows = new Vector();
            while (resultSet.next()) {
                  Vector newRow = new Vector();
                for (int i = 1; i <= numberOfColumns; i++)
                        Object o = resultSet.getObject(i);
                          newRow.addElement(o);
                  rows.addElement(newRow);
// THIS IS IT !!!
            fireTableChanged(null);
    //             Implementation of the TableModel Interface
    // MetaData
    public String getColumnName(int column) {
        if (columnNames[column] != null) {
            return columnNames[column];
        } else {
            return "";
    public Class getColumnClass(int column) {
        int type;
        try {
            type = metaData.getColumnType(column+1);
        catch (java.sql.SQLException e) {
            return super.getColumnClass(column);
        switch(type) {
              case Types.CHAR:
              case Types.VARCHAR:
              case Types.LONGVARCHAR:
                  return String.class;
              case Types.BIT:
                  return Boolean.class;
              case Types.TINYINT:
              case Types.SMALLINT:
              case Types.INTEGER:
                  return Integer.class;
              case Types.BIGINT:
                  return Long.class;
              case Types.FLOAT:
              case Types.DOUBLE:
                  return Double.class;
                  case Types.DATE:
                  return java.sql.Date.class;
              default:
                  return Object.class;
    public boolean isCellEditable(int row, int column) {
        try {
            return (metaData.isWritable(column+1) && (row == 0));
        catch (SQLException e) {
            return false;
    public int getColumnCount() {
        return (columnNames.length-extraColumns.length);
    // Data methods
    public int getRowCount() {
        return rows.size();
    public Object getValueAt(int aRow, int aColumn) {
        try {
              Vector row = (Vector)rows.elementAt(aRow);
              return row.elementAt(aColumn);
        } catch (ArrayIndexOutOfBoundsException e) {
            return null;
    public void setValueAt(Object value, int row, int column) {
        String t = dbRepresentation(column, value);
        if ((t.equals("")) || (t.equals("''")))
                  currentRow.setElementAt(null, column);
        else
                  currentRow.setElementAt(value, column);
        rows.setElementAt(currentRow.clone(), 0);
// THIS IS IT !!!
            fireTableCellUpdated(row, column);
Expert Comment
by:tienthinh
 DefaultTableModel  a=new DefaultTableModel();
        a=      (DefaultTableModel) table.getModel();
        int numRows = table.getRowCount();
        if (numRows>0)
        a.removeRow(i);
[Webinar] Database Backup and Recovery
Does your company store data on premises, off site, in the cloud, or a combination of these? If you answered “yes”, you need a data backup recovery plan that fits each and every platform. Watch now as as Percona teaches us how to build agile data backup recovery plan.
Are you developing a Java application and want to create Excel Spreadsheets? You have come to the right place, this article will describe how you can create Excel Spreadsheets from a Java Application. For the purposes of this article, I will be u…
Introduction This article is the last of three articles that explain why and how the Experts Exchange QA Team does test automation for our web site. This article covers our test design approach and then goes through a simple test case example, how …
This theoretical tutorial explains exceptions, reasons for exceptions, different categories of exception and exception hierarchy.
How to fix incompatible JVM issue while installing Eclipse While installing Eclipse in windows, got one error like above and unable to proceed with the installation. This video describes how to successfully install Eclipse. How to solve incompa…
Suggested Courses
Course of the Month8 days, 13 hours left to enroll
621 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
