HELP!!! Problems with Edit Control!! urgent!!
Hi all!!!
I have the following problem.... my main form has a lot of Edit controls... some of them are 22 units width (which accept 2 characters), and others 14 units (which accept 1 character). The font used is Courier New, 8 pts. The problem I have only with the Edit controls 14 units width. In my PC the text I want to display is shown correctly but only in the 1024x768x32 resolution (in other resolutions the controls appear in blank). When I ran the program in other PC, it was impossible for me to make the control show the text properly (the controls appear in blank again). I realized that the text is there, but too left justified, so the control doesn't show it. To make it work, I have to change either the width (to 21 units at least) or the font (small font, 7 pts, only).
What the hell can I do!!!!!! I HAVE to use Courier New font and that width. Is it a control problem? windows problem? If I would install a new edit control, would I solve the problem? where can I download a new one?
THANKS a lot in advance
Jaime
skelAsked:
rwilson032697Connect With a Mentor Commented:
The problem lies in that the font size is fixed number of points (where one point = 1/72 inches) and the number of screen pixels taken by a character of a fixed point size depends on the physical dots per inch of the particular screen resolution.
Effectively your only solution is to modify the point size, or to force the form to scale with changes in resolution.
Here is a component that will do this (written by Viktornet I believe...):
unit Scaler;
         interface
         uses
           Windows, Messages, SysUtils, Classes, Graphics, Controls,
Forms,
         Dialogs;
         const
            ScreenWidth  : Integer = 800; //If you don't want to declare
    constants
                                         //you'd have to have a
            ScreenHeight : Integer = 600;//property for each of these
two so
    you can
        // declare it at //designtime
         type
           TScaler = class(TComponent)
           private
             FAllScaled : Boolean;
           protected
             { Protected declarations }
           public
             constructor Create(AOwner : TComponent);override;
             procedure Loaded;override;
           published
             { Published declarations }
           end;
         procedure Register;
         implementation
    constructor TScaler.Create(AOwner : TComponent);
    begin
      Inherited Create(AOwner);
      fAllScaled := False;
    end;
    procedure TScaler.Loaded;
    begin
      Inherited;
      if not(csDesigning in ComponentState) then
        if Owner is TForm then
        with TForm(Owner) do begin
          Font.Pitch := fpVariable;
          if (not
fAllScaled)and((Screen.Width<>ScreenWidth)or(Screen.Height<>ScreenHeight))then
           begin
             Scaled := True;
             AutoScroll := False;
              if Screen.Width < ScreenWidth then
             ScaleBy(Screen.Width, ScreenWidth)
             else ScaleBy(ScreenWidth, Screen.Width);
             fAllScaled := True;
           end;
         end;
    end;
    procedure Register;
    begin
      RegisterComponents('System', [TScaler]);
    end;
    end.
philipleighsCommented:
Instead of hard wiring 14, why not (in FormCreate) set the width property of the edit control to [YourForm.]Canvas.TextWidth('A');
You might like to add another 3 or 4 pixels to account for the edit's border maybe.
