Need help with a hardware problem........
what is a static resource conflict? How do you fix it?
robbyb98
robbyb98
jhanceCommented:
A static resouce conflict happens when two or more devices in your system are setup to use the same resource.  For example, if you have a network card and a sound card setup to use IRQ 5, then you have a static resource conflict.
How do you fix it?  It's easy in theory.  Change one of the devices to another resource.
If you post additional information about what resource and what devices are in conflict, I'm sure additional advice could be offered.
robbyb98Author Commented:
jhance,
     I tried changing the irq and it didn't resolve the problem.. Do you have any other ideas?  Please let me know.
robbyb
SMB Security Just Got a Layer Stronger
WatchGuard acquires Percipient Networks to extend protection to the DNS layer, further increasing the value of Total Security Suite.  Learn more about what this means for you and how you can improve your security with WatchGuard today!
