jamiguel
i am need help with a Electronic Modular Switching System..
i am need help with a Electronic Modular Switching System (for receive an distributing calls of phones)
then these Electronic Modular Switching System have a port for print calls enter and print calls out, (actually for the printer), then i need capture these calls but in my Pc with a program in delphi.
mmm the MSS have a serial port conectted a an converter Serial to paralel port and these are coneccted to a printer (in paralel port)
actually the calls are printer in a printer :)
can anybody help me?
i am need buy a target(for PC) for MSS?
or what
thanks
or what
thanks
why not turbopower?
because it is about 10 times more expensive(async pro at $300.00 ish).. sure they are good but too much for just components.
Thanks is good the answer
Good look
Good look
glad to hear it helps :-)
GREETINGS!
This question was awarded, but never cleared due to the JSP-500 errors of that time. It was "stuck" against userID -1 versus the intended expert whom you awarded. This corrects the problem and the expert will now receive these points; points verified.
Please click on your Member Profile and select "View Question History" to navigate through any open or locked questions you may have to update and finalize them. If you are an EE Pro user, you can also choose Power Search to find all your open questions.
This is the Community Support link, if help is needed, along with the link to All Topics which reflects many TAs recently added.
https://www.experts-exchange.com/jsp/qList.jsp?ta=commspt
https://www.experts-exchange.com/jsp/zonesAll.jsp
Thank you,
Moondancer
Moderator @ Experts Exchange
Thank you,
Moondancer
http://www.exceletel.com/
they have components for tapi (activex or component)depending on what version you buy.
the examples are good annd show how to moniter incoming calls etc,callerid etc..
