pablocasta
Right, Left and First Indent problem
I'm trying to set the Right and Left indent of a paragraph. For that I'm using the following code:
procedure TfrmParrafo.Clicks(Sender: TObject; Button: TUDBtnType);
begin
if Sender = UpDown1 then
begin
Edit1.Text := FloatToStr(UpDown1.Positio n) + ' (mm)';
reEjemplo.Paragraph.LeftIn dent := UpDown1.Position;
end
else if Sender = UpDown2 then
begin
Edit2.Text := FloatToStr(UpDown2.Positio n) + ' (mm)';
reEjemplo.Paragraph.RightI ndent := UpDown1.Position
end
else if Sender = UpDown3 then
begin
Edit3.Text := FloatToStr(UpDown3.Positio n) + ' (mm)';
reEjemplo.Paragraph.FirstI ndent := UpDown1.Position
end
end;
What am I doing wrong? 'cause it doesn't work.
PS: I'm also trying to do an undo/redo command. Redo is the problem, is there any way to do it?
Thanks in advance.
begin
begin
end
begin
end
begin
end
end;
Thanks in advance.
You can redo by calling updo again.
Cheers,
Phil.
Cheers,
Phil.
I knew some of the things you are telling me, but though, there are some good points you mention I haven't really taken into account.
On one side I wanted to ask what was exactly a pixel, but sbruck has already done that.
On the other one, I corrected the problem Phil mentions, but though the thing works not as I expected.
I'll explain ...
When I change values, text appears like this:
Example text.Example text.Example text.Example
text.
Example text.Example text.Example text.Example text.Example text.Example text.
I mean some words that could be placed in the line before are put down one line. Why does this happen?
I'll explain ...
text.
Cheers,
Phil.
