John500
Question For Todd Niec - Need help on various functions that will read and transfer files to an SQL database
The following code is complete, there is no single question to post. As stated in the question title, this code covers a range of questions I had regarding processing a directory and all of its files. Another concern was how to make the SQL API calls so that I could transfer the data to an SQL Server database.
10/20/99
This program will establish an SQL connection and process the specified
directory by scrolling through each file to extract the file's contents.
As each line of the file is extracted, the data is stored in variables.
Those variables are then passed to an SQL stored procedure which inserts
the data into the database.
Six routines including main(), are used to facilitate the above procedure.
These routines are:
Check_ODBC_Errors()
CountFields()
StrTok()
ProcessFile()
ProcessDirectory()
main()
The flow of the program begins by establishing an SQL connection in main().
The Check_ODBC_Errors()functio n ensures an SQL connection is established.
CountFields() verifies that each line of a file contains the proper number of
fields. Once the number of fields are verified, StrTok() extracts each
field of the line and places the value into a variable to await the call
which dumps the data to the database. Additional checks on each field format,
length and type are not included in this program.
This program was developed under the assumption that valid files are placed
into the appropriate directory for processing. Although errors in file content
are checked, this program will process any file with a 'dat' extension.
Therefore, no error reporting is done for files which should not be in the
specified directory.
#include <windows.h>
#include <sql.h>
#include <sqlext.h>
#include <string>
#include <iostream>
#include <fstream>
#include <conio.h>
using namespace std ;
/********************** ODBC Error Check ************************** ****
* desc : This function is called after each request for an SQL handle
* within main(). If the request fails, this function provides the
* error information of the SQL environment as stated above.
* input : The handle type to be checked and the actual handle value.
* The calling function also passes to this function the return code
* which the calling function received for the handle type.
* output : Prints to the screen the SQL State, Native Error and a
* diagnostic message text string if available
* returns : Returns a bool to the caller if necessary, but the return value
* is not used in this program since this function also provides
* various error info printed to the screen.
BOOL CHECK_ODBC_ERRORS(SQLSMALL INT HandType, SQLHANDLE HandValue, RETCODE rc)
// Helper function for debugging those cryptic ODBC errors.
SQLSMALLINT RecNum = 1; // then 2, then 3....
SQLCHAR State[5];
SQLINTEGER NativeError;
SQLSMALLINT MsgLen;
const SQLINTEGER ErrorMsgMax = 1024;
SQLCHAR MsgTxt[ErrorMsgMax];
if ( SQL_SUCCEEDED(rc) )
return FALSE; // Skip if everything is ok.
if(HandValue == SQL_INVALID_HANDLE){
printf("SQLAllocHandle() failed to obtain a handle!\n");
return FALSE;
printf( "******************** ODBC Errors ********************\n" );
printf( "Return code = %d.\n", rc );
for ( ; ; )
rc = SQLGetDiagRec(HandType, HandValue,RecNum, State, &NativeError,
MsgTxt, ErrorMsgMax, &MsgLen);
if ( ( rc != SQL_SUCCESS ) && ( rc != SQL_SUCCESS_WITH_INFO) ) break;
printf("MsgTxt[%02d] SQLState '%s'\n",RecNum, State);
printf("MsgTxt[%02d] NativeError %lu\n",RecNum, NativeError);
printf("MsgTxt[%02d] Message '%s'\n", RecNum, MsgLen);
RecNum++;
if (RecNum == 1)
printf("First call to SQLGetDiagRec failed, unidentified RETCODE = %d\n",rc);
if ( rc == SQL_NO_DATA_FOUND )
printf("First call to SQLGetDiagRec failed with RETCODE");
printf(" = SQL_NO_DATA_FOUND, See SQLError documentation\n");
printf("SQLState - '%s'\n", State);
if ( rc == SQL_ERROR )
printf(" = SQL_ERROR, See SQLError documentation\n");
if ( rc == SQL_INVALID_HANDLE )
printf(" = SQL_INVALID_HANDLE, See SQLError documentation\n");
return TRUE;
} // End of BOOL CHECK_ODBC_ERRORS()
/************************* **** StrTok ************************** **
* desc : This procedure is called from the ProcessFile() function. It's
* purpose is to return each field of data within the line it
* receives.
* input : Accepts two const strings and an integer. The 1st string is the
* entire line in the file to be tokenized, and the 2nd is the
* delimiter(s) which mark the separation of each field in the file.
* The int is used to control which token is return and where the
* following call to StrTok() should proceed from.
* output : -
* returns : Returns the extracted field of data from the file. Regarding
* '&StartPos', after receiving the initial starting point of '0'
* from the caller, StrTok() will set the value of 'StartPos' as
* needed to get the next token and returns 0 when last element is
* obtained.
string StrTok(const string &Str, const string &Dlm, int &StartPos)
StartPos = Str.find_first_not_of(' ',StartPos); // Skip initial spaces.
int BgnPos = StartPos;
int NxtPos = Str.find_first_of(Dlm,Star tPos);
const int StrLen = Str.length();
if (NxtPos == basic_string<char>::npos) // if no delimiter was found, then
NxtPos = StrLen; // Set token end position to 1 past end of string.
StartPos = NxtPos + 1;
if (StartPos >= StrLen) // If token is at end of ths tring.
StartPos = 0; // Indicate this is the last token
return Str.substr(BgnPos,NxtPos - BgnPos); // Return token found.
/************************* **** CountFields ************************** **
* desc : This procedure is called by ProcessFile() and uses StrTok() to
* check a line of the file for the correct number of fields.
* Unlike ProcessFile(), CheckFields() does not use the return value
* of StrTok(), but rather uses StrTok() to traverse the line. Thus
* proving the number of fields within the line.
* input : Receives a string which is one line of the file.
* output : -
* returns : Returns the number of fields found.
int CountFields(const string &StrLine)
string DlmReg = " ";
string LastDlm = "\n";
string Dlm = DlmReg;
int StartPos = 0; // starting point to check non-empty lines
int FieldCount = 0;
while(TRUE){
if(FieldCount == 7)
Dlm = LastDlm;
StrTok(StrLine,Dlm,StartPo s);
FieldCount++;
if((StartPos == 0) || (FieldCount > 8)) // end the loop
return FieldCount;
return FieldCount;
/************************* * ProcessFile **************************
* desc : This procedure is called by ProcessDirectory() and uses StrTok()
* to extract each field in each line of the file it receives.
* The values returned by StrTok() are used as parameters for
* SQLExecDirect() which in turn passes the data to the SQL data
* source as a stored procedure.
* input : Receives the HDBC environment handle obtained within main(), and
* a string which is the path of a file.
* output : This procedure will currently send error messages to the screen
* if a file cannot be read or if the call to SQLExecDirect() fails.
* In the future, these errors will be printed to a log only.
* returns : -
void ProcessFile(HSTMT hstmt, string FileName)
RETCODE rc;
int lineCheck = 0; // starting point to check for empty line
int lineResult;
int line = 0; // used to report error location
int FieldCount;
char szSQL[1024];
string StrLine;
string Dlm = " \t";
fstream LoadFile;
LoadFile.open(FileName.c_s tr(), ios::in);
if(LoadFile.fail()){
printf("Error reading file %s\n", FileName);
return;
while (!LoadFile.eof()){
getline(LoadFile, StrLine, LoadFile.widen('\n'));
lineResult = StrLine.find_first_not_of( ' ', lineCheck);
if(lineResult == -1)
return;
FieldCount = CountFields(StrLine);
if(FieldCount != 8)
continue;
StartPos = 0; // reset StartPos parameter
string Field1 = StrTok(StrLine,Dlm,StartPo s);
string Field2 = StrTok(StrLine,Dlm,StartPo s);
string Field3 = StrTok(StrLine,Dlm,StartPo s);
string Field4 = StrTok(StrLine,Dlm,StartPo s);
string Field5 = StrTok(StrLine,Dlm,StartPo s);
string Field6 = StrTok(StrLine,Dlm,StartPo s);
Field5 = Field5 + " " + Field6; //combines the date & time
string Field7 = StrTok(StrLine,Dlm,StartPo s);
string Field8 = StrTok(StrLine,"\n",StartP os);
sprintf( szSQL,
"execute LoadData '%s', '%s', '%s', '%s', '%s','%s', '%s'",
Field1.c_str(), Field2.c_str(), Field3.c_str(), Field4.c_str(),
Field5.c_str(), Field7.c_str(), Field8.c_str());
rc = SQLExecDirect( hstmt, (SQLCHAR*) szSQL, SQL_NTS );
CHECK_ODBC_ERRORS(SQL_HAND LE_STMT, hstmt, rc);
SQLFreeStmt(hstmt, SQL_CLOSE);
if (( rc != SQL_SUCCESS ) && ( rc != SQL_SUCCESS_WITH_INFO))
printf( "Error processing file %s line %d\n", FileName.c_str(), line );
break;
line++;
} // end of while loop
return;
/************************* ** Process Directory **************************
* desc : This procedure is called from main(). It's purpose is to scroll
* through the specified directory passing each file's location
* to ProcessFile(). FindFirstFile() and FindNextFile() are used
* to traverse the directory.
* output : -
* returns : -
void ProcessDirectory(HSTMT hstmt)
BOOL Done; // used for searching the directory for files
HANDLE FndHnd; // used for FindFirstFile()
WIN32_FIND_DATA FindDat; // allocate a local structure.
string Fname;
string FilePath = "C:\\Dats\\TestDats\\";
string FullFilePath = "C:\\Dats\\TestDats\\*.dat ";
string TempFilePath = "C:\\Dats\\TestDats\\TempD ats\\";
FndHnd = FindFirstFile(FullFilePath .c_str(), &FindDat);
Done = (FndHnd == INVALID_HANDLE_VALUE);
while (!Done){
Fname = FindDat.cFileName;
FilePath = FilePath + Fname;
ProcessFile(hstmt, FilePath);
TempFilePath = TempFilePath + Fname;
MoveFile(FilePath.c_str(), TempFilePath.c_str());
FilePath = "C:\\Dats\\TestDats\\"; // Reset File Path
TempFilePath = "C:\\Dats\\TestDats\\TempD ats\\"; // Reset Temp Directory Path
Done = !FindNextFile(FndHnd, &FindDat); // Pass pointer to local structure
if (FndHnd)
FindClose(FndHnd);
return;
/************************* **** Main ************************** ******
* desc : main() establishes a connection to the SQL data source. After
* the connection is made, ProcessDirectory() is called to extract
* files from a specified directory
* output : Prints to the screen the error information obtained by
* Check_ODBC_Errors(). Or, if no errors were incurred, the only
* messages which appear are those verifying a connection was
* made and that the program has terminated.
void main(void)
RETCODE rc;
HENV henv = SQL_NULL_HENV;
HDBC hdbc = SQL_NULL_HDBC;
HSTMT hstmt = SQL_NULL_HSTMT;
const DWORD TimeOut = 5;
rc = SQLAllocHandle(SQL_HANDLE_ ENV,SQL_NU LL_HANDLE, &henv);
CHECK_ODBC_ERRORS(SQL_HAND LE_ENV, henv, rc);
if (rc == SQL_SUCCESS)
rc = SQLSetEnvAttr(henv,SQL_ATT R_ODBC_VER SION,(SQLP OINTER)SQL _OV_ODBC3, 0);
rc = SQLAllocHandle(SQL_HANDLE_ DBC,henv,& hdbc);
if(rc == SQL_SUCCESS)
printf( "Connecting to data source..." );
rc = SQLConnect(hdbc, (SQLCHAR *)"DSN", SQL_NTS, (SQLCHAR *)"sa", SQL_NTS,
(SQLCHAR *)"", SQL_NTS);
CHECK_ODBC_ERRORS(SQL_HAND LE_DBC, hdbc, rc);
printf( "Done.\n" );
if (rc == SQL_SUCCESS || rc == SQL_SUCCESS_WITH_INFO)
rc = SQLAllocHandle(SQL_HANDLE_ STMT,hdbc, &hstmt);
ProcessDirectory(hstmt);
// Clean up all ODBC handles.
if (hstmt)
rc = SQLFreeStmt( hstmt, SQL_CLOSE);
if (hdbc)
rc = SQLDisconnect( hdbc );
rc = SQLFreeConnect( hdbc );
if (henv)
rc = SQLFreeEnv( henv );
printf( "\nTest complete. Press any key to exit.\n" );
_getch();
Thanks Tod
10/20/99
These routines are:
Check_ODBC_Errors()
CountFields()
StrTok()
ProcessFile()
ProcessDirectory()
main()
#include <sql.h>
#include <sqlext.h>
#include <string>
#include <iostream>
#include <fstream>
#include <conio.h>
SQLCHAR State[5];
SQLSMALLINT MsgLen;
return FALSE;
for ( ; ; )
RecNum++;
if (RecNum == 1)
return TRUE;
* receives.
* output : -
* obtained.
* output : -
int FieldCount = 0;
while(TRUE){
if(FieldCount == 7)
Dlm = LastDlm;
FieldCount++;
return FieldCount;
return FieldCount;
* returns : -
RETCODE rc;
int lineResult;
int FieldCount;
char szSQL[1024];
string StrLine;
string Dlm = " \t";
fstream LoadFile;
return;
return;
if(FieldCount != 8)
continue;
sprintf( szSQL,
break;
line++;
return;
* output : -
* returns : -
string Fname;
while (!Done){
if (FndHnd)
FindClose(FndHnd);
return;
void main(void)
RETCODE rc;
if (hstmt)
if (hdbc)
if (henv)
_getch();
Thanks Tod
John is learning to program and had a project for his work (where he is not working as a programmer) that I was helping him on via e-mail. This is the result of about a million e-mails.
EE is the forum for dialogues.
