right-click problem
my right-click button does not work
xtarheelAsked:
MrbreezeCommented:
Try using another mouse. If that fixes it the mouse went bad.
Gaetano010400Commented:
Buy yourself a new mouse.
MrbreezeCommented:
Good answer Gaetano, why didn't I think of that?                Mrbreeze
Cloud Class® Course: Ruby Fundamentals
This course will introduce you to Ruby, as well as teach you about classes, methods, variables, data structures, loops, enumerable methods, and finishing touches.
xtarheelAuthor Commented:
how do I know that it is not a software problem
MrbreezeCommented:
If the rest of rhe mouse functions work it is probably not. Check device manager for the mouse, remove it , reboot and let Windows reload it and see what happens.        Mrbreeze
I would still buy a new mouse.
They are not the most expensive things in the these days.
Davy070599Commented:
You can know by swapping the two buttons.  It's somewhere in the properties of your mouse (Configuration screen).
Byeee...
phil_millerCommented:
Go to the web site of the manufacturer and download the most updated drivers...see if that works.
MrbreezeCommented:
I think he left. Probably got a new mouse and everythings fine now...LOL
                           Mrbreeze
Hmm......
Thats sad....
He asks a Q but doesn't wan't an answer.
It is of course an easy way to spare the points....
MrbreezeCommented:
Yeah so let's lock the question so my bell stops ringing...hehehehe
I bot a new mouse, sorry 4 the delay
MrbreezeCommented:
Xtarheel,
Glad the problem is solved for you. Come back if we can help again
                           Mrbreeze
Ahhhh........Crist....
That was easy points for you....
Windows OS
