mikedeeznutz
Linux Modem Problem
I am very new to linux and am having a problem seting up my modem. When I try to connect to my ISP, I get a modem busy response. It is a Rockwell HCF 56K data/fax PCI modem. It currently resides on COM2.
Invest in a real HARDWARE modem. It should solve all your problems. What you have is also known as a WinModem. That's because it depends on Windows OS and the computers CPU to run.
And also since the "HCF" is a soft-modem, it will not work even when the PCI modem-bit is supported. Since this isnt a 'real' modem, but relies on the CPU (what is abit incorrectly referred to as a 'WinModem')
