hiding and showing parts of a page using <DIV>
hi,
i'm designing a webpage with a lot of info on it and i want to hide most of it until somebody clicks a link, then it should expand en show the details
format
<a href=# onClick="ShowDiv(1);">link 1</a>
<div name=x1 class=mydivclass>info</div>
<a href=# onClick="ShowDiv(2);">link 2</a>
<div name=x2 class=mydivclass>info</div>
<a href=# onClick="ShowDiv(3);">link 3</a>
<div name=x3 class=mydivclass>info</div>
the info in the divs is initially hidden using document.mydivclass.style.display="none"
how do i
-refer to one specific div, how can i turn a variable into an object (ie divname="SuchAndSo" and then i want to set properties in the way of document.divname.property etc)
- make this div visible
heitAsked:
xabiCommented:
Hi there:
You must use this code:
<script LANGUAGE="javascript">
var ns = (document.layers)? true:false;
var ie = (document.all)? true:false;
function show(id) {
  if (ns) document.layers[id].visibility = "show"
      else if (ie) document.all[id].style.visibility = "visible"
function hide(id) {
  if (ns) document.layers[id].visibility = "hide"
      else if (ie) document.all[id].style.visibility = "hidden"
</script>
and declare ths divs this way:
<style TYPE="text/css">
#menu1layerDIV {position:absolute; left:1; top:140; visibility:hidden;}-->
</style>
<body>
<div id="menu0layerDIV">
</div>
If you want to hide it just do this:
 hide("menu0layerDIV")
and if you want to show it:
 show("menu0layerDIV")
Now if you wanto to convert a variable into an object just do this:
divname="SuchAndSo"
eval("document." + divname + ".property = fooo")
xabi
heitAuthor Commented:
xabi, code works fine, thanx!
i've increased the points because i have an additional question:
i can't use the absolute positioning because i don't know how much text should be above the div ... what i would like to do is design it in a way that it really pops up between the lines, so that first i've got a lot of text, then i press a link and then the text separates and a div show in between. Now i use relative divs, but when it is invisible it still takes the place between the lines, only the divtext is hidden.
Do you know how to solve this?
i use ie 4.0
xabiCommented:
Here goes the IE code:
--------- 8< -------- 8< ----
<html>
<head>
<title>Example</title>
function clikker(a) {
  if (a.style.display =='') a.style.display = 'none'
  else a.style.display=''
</script>
</head>
<body marginheight="0" marginwidth="0" topmargin="0" leftmargin="0">
text<br>
text<br>
<a href="javascript:clikker(menu)">click</a><br>
end of text--------------<br>
<div <div ID="menu" STYLE="DISPLAY: none" >
ini ------<br>
dfghfgh<br>
end ----
</div>
continue---------------<br>
sfdgsdfgsdfgsdfgsdfg
</body>
</html>
--------- 8< ------ 8< ------
xabi
PS: Only IE
great, it works just fine!
HTML
